OriginalWheelman
85 F250 Diesel and a 95 S14
There is more than NYC in NY
4-27-2006
| « Re: co2 sprayer (corey240) | 2:26 PM 7/23/2006 |
Sexy diagram. You should add sound effects pfffffft WHOOOSH vrroooooooooom eeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeh! (mine would not be any better, no offense intended)Seriously though, good idea. I'd like to see pics when it's done!
| Quote, originally posted by Al Gore » | | science will not intrude on public policy | Statistics have proven everything.
shift_fuels - Natural Gas is 120 octane.
MeanGreenS13
1993 Nissan 240sx
Vero Beach FL
8-20-2005
| « Re: co2 sprayer (corey240) | 2:30 PM 7/23/2006 |
whats the fan for? liquid CO2 comes out FREEZING cold no matter what pretty much, unless its in an oven, I have system set up on my car, just not installed right nowPhil
 Phil - 1993 Nissan 240sx CA18DET
xckid
I didn't make dickie a CkY CD
1991 240sx
McAllen Texas
12-16-2004
If it comes out freezing then wont it crack what ever he is spraying. Because last i remember things from hot to suddenly cold tend to expand sometimes crack wont this freezing temp. on something above 200 deg F. Crack ......Just wondering havent heard of anything like this. Closes thing i have heard of is the water sprayer.......Just looking out for you bud. Dont want a cracked intercooler rad. or what ever you using it on. Asides from that sounds sweet. Being Cool FTW
MILESTONE: AVOIDED SIG POLICE SINCE SIG POLICY WAS IN PLACE.
| Quote, originally posted by dickie » | i want a fake id too, but i want mine to be from the local high school to make me seem YOUNGER. "yeah i just turned 19 sweetheart, let me get another beer for you and your friend." |
I AR I LEARNED'D
corey240
98 240sx SE
Cumberland MD
9-8-2005
| « Re: (xckid) | 3:13 PM 7/23/2006 |
well i decided im gona use this as an intercooler sprayer.here is alink to a ford thing where they used the cryo2 kit and got 8hp and 7 degree celcius cooler from using there intercooler sprayer. my main question is for people who have nitrous kits or know what is needed to install them. i need to know what i need besides lines and the bottles and im gona use a remote bottle opener. what els will i need?solenoid? this will be asimple setup and shouldnt cost much. i WILL do a write up on this if i cant get peoples help for a parts list.so keep the info coming guys i am serious about this.
OriginalWheelman
4-27-2006
| « Re: (corey240) | 6:01 PM 7/23/2006 |
Perhaps consider using a propane grill burner, that should get it atomized pretty well and on the cheap
DJButton
240SX Moderator
1919 In your face
Wherever May Roam
3-22-2005
| « Re: (OriginalWheelman) | 6:24 PM 7/23/2006 |
Paintball CO2's FTW! Hmmm, I should put mine to good use...
HIGH PRESSURE POWER STEERING LINES FOR SALENow carrying Nardi and Personal steering wheels and Works Bell hubs! Also new, SPLPARTS adjustable arms and much much more!
safxtacy
Lexus IS300
Barstow Ca
7-8-2006
ok i was thinking of something like this too heres what i think would work u can buy tops for ur tanks that u can turn on and off before u take the tank off so u dont lose valuble co2 so how about u get two of those and hook them onto ur tanks now u get 2 paintball guns that dont work or just get the thing where u insert the co2 tank and take the old line off get a longer line and run it to some sort of sprayer and when ur not using the co2 just unhook them and leave the lines and when u do want to use them u can hve them in ur car and turn the valve on and ur thing will be ready ill try to see if i can find the things u need i think itll work and its way cheaper
 For Sale: Greddy Turbo Timer - http://forums.nicoclub.com/zerothread/312324
safxtacy
Lexus IS300
Barstow Ca
7-8-2006
| « Re: (safxtacy) | 7:33 PM 7/23/2006 |
theres a diagram i made it now but if u made the lines a little longer and ound a descent sprayer i think it would work great using the parts off the paintball gun will be easier since u can just screw it on and off and the new valves can be used to turn it on and off so the fan wont be needed since u can just unhook the tanks that easily i think its a great idea and some tnks now adays come with the on/off valves already so its the parts for the paintball ull need which i think can be found really easily the hose and connections are probally going to be the hardest things to find and i can guarantee this will be cheaper than buying a system and the valves can be adjusted so u dont have to have all the air leaking at once if someone trys this let me know how it turns out this looks like a better diagram
Attachment: co2.JPG (32272 bytes, downloaded 184 times)
safxtacy
Lexus IS300
Barstow Ca
7-8-2006
| « Re: co2 sprayer (corey240) | 7:38 PM 7/23/2006 |
the pic isnt working for me so im uploading it agian using imageshack
also just checked u can get 2 valves for about 30 dollars
MeanGreenS13
1993 Nissan 240sx
Vero Beach FL
8-20-2005
| « Re: (safxtacy) | 7:39 PM 7/23/2006 |
intake spraying is iffy, but intercooler spraying is not... its done all the time actually. ive seen HP gains on the dyno up to 50whp before... it just supercools the air going in and makes the molecuels jump closer together making more air PSI enter the engine
spyro187
1990 240sx, ka24de swap, gutted rear, 17" motegi's, msd coil, injen intake, electric fan
Loganville Ga
3-22-2006
| « Re: (safxtacy) | 7:40 PM 7/23/2006 |
While looking at this I had another idea. It may have been tried but deals with co2 cooling. What if you made a device that wrapped around an intake that holds co2. Like a sleave. For instance, take the end of the intake nearest your throttle body and put another sleeve over it with space in the middle. Then inject co2 into it. Every once in a while purge the old and let the new cold co2 in. Would this work?
http://www.SecurityDistro.com Arm Your Toolbox
safxtacy
Lexus IS300
Barstow Ca
7-8-2006
| « Re: (spyro187) | 7:50 PM 7/23/2006 |
i| Quote, originally posted by spyro187 » | | While looking at this I had another idea. It may have been tried but deals with co2 cooling. What if you made a device that wrapped around an intake that holds co2. Like a sleave. For instance, take the end of the intake nearest your throttle body and put another sleeve over it with space in the middle. Then inject co2 into it. Every once in a while purge the old and let the new cold co2 in. Would this work? |
i see where ur gettin at here but intercooler spraying is less dangerous another update u can get co2 tank adapters for 10 dollars each and there from tippman one of the best guns out there so lets do the math valves-30 tank adapter-20 lines-??(anyone have a clue) sprayer-i saw one on ebay for 100 but im pretty sure u can make one tanks-depends how big u want the tank its 50 for 2 20oz tanks brackets-20 total-i would say around 200 for everything which is half as cheap and the amount of aire u want out can be adjusted like i said before the hardest thing will be the lines and hookups to fit the tank adapter to the sprayer
Sky240PWR
1991 Nissan 240SX
Jacksonville IL
2-27-2005
| « Re: (safxtacy) | 7:59 PM 7/23/2006 |
I'm getting the Sard cooing spray kit, comes with eveything you need for like $219 shipped!
Attachment: nengun-product-664.jpg (14774 bytes, downloaded 166 times)
91 240 hatch-widebody-rb25 03 track edition 350z-a must see! 06 s2000.... http://www.cardomain.com/ride/2524203
 the haters will hate!!
safxtacy
Lexus IS300
Barstow Ca
7-8-2006
| « Re: (Sky240PWR) | 8:01 PM 7/23/2006 |
| Quote, originally posted by Sky240PWR » | | I'm getting the Sard cooing spray kit, comes with eveything you need for like $219 shipped! |
u got a website i wanna check this out also one more ? what kind of tanks do they give with the kits and can u refill them anywhere
Sky240PWR
1991 Nissan 240SX
Jacksonville IL
2-27-2005
| « Re: (safxtacy) | 8:08 PM 7/23/2006 |
here is some info on it Introducing the Sard Cooling spray unit. Can be used to spray water onto the Radiator or Intercooler. The S.C.S consists of a Manuel or Automatic Mode.
Parts included Electronic Cooling Spray unit Plastic Tank Nosel & Stay Motor & Pump
you can get it at http://www.nengun.com/catalogue/product/424
Attachment: nengun-product-663.jpg (15885 bytes, downloaded 158 times)
safxtacy
Lexus IS300
Barstow Ca
7-8-2006
| « Re: (Sky240PWR) | 8:16 PM 7/23/2006 |
| Quote, originally posted by Sky240PWR » | | here is some info on it Introducing the Sard Cooling spray unit. Can be used to spray water onto the Radiator or Intercooler. The S.C.S consists of a Manuel or Automatic Mode.
you can get it at http://www.nengun.com/catalogue/product/424 |
i dont think that will work as good as the co2 becasue it sprays water i dont know though i think the co2 would be better ive been lookin at cryo2 kits and there not as expensive as ithought 300 will get u a good one with the tank and the thing about that is u have all the stuff electrical and what not but the tank on those are huge and its gonna be hard to store those massive things
Sky240PWR
1991 Nissan 240SX
Jacksonville IL
2-27-2005
| « Re: (safxtacy) | 8:25 PM 7/23/2006 |
yeah but this is prolly safer, and I was thinking you could prolly fill the jug up with water and ice, so it's colder.
safxtacy
Lexus IS300
Barstow Ca
7-8-2006
| « Re: (Sky240PWR) | 8:29 PM 7/23/2006 |
it probally is safer but with my method of using custom tanks its safer than having a big *** tank in the back but anyways instead of using ice and water get some dry ice in a bag and put it around the jug thing dont put dry ice inside because the tank will blow dry ice+water= KABOOOOOMMMM
Sky240PWR
1991 Nissan 240SX
Jacksonville IL
2-27-2005
| « Re: (safxtacy) | 9:10 PM 7/23/2006 |
i was thinking of doing something like that, what about fuel line, can you make a can(like a catch can) where the fuel line spirals in it so there's room for dry ice, will that work?
corey240
98 240sx SE
Cumberland MD
9-8-2005
| « Re: (safxtacy) | 9:14 PM 7/23/2006 |
i know about tippman i have 1 and a very custom spyder. im gona do it. and for anyone who says water would/could be colder then co2, go to a place that fills co2,fill up a small tank and then open the valve and let all the air blast your hand constatly until its all gone,and also then feel the tank, they can get to negative 0 degrees fast. oh and by the way if you are dumb enough to actualy do this make shore you have 3 hands first because youl be less one after words.
kamikazeee
1991 240sx
Tinley Park Il
7-7-2006
| « Re: (Sky240PWR) | 9:20 PM 7/23/2006 |
little fridge, put dry ice in it forever, run fuel lines through it+make a fogger system for air intake or inter cooler with co2 tanks+oil cooling system=cold *** engine gaining horsepower (I hope)
safxtacy
Lexus IS300
Barstow Ca
7-8-2006
hey corey i just found a cheaper way to do this buy this sprayer kit unless u want to make ur own http://cgi.ebay.com/ebaymotors...ZWDVW then buy this tank http://cgi.ebay.com/2-5-lb-Co2...wItem and all u need is a line the tank has a valve already on it so all ull need is the line and some custom brackets i think these two things would be easier than using the paintball co2 tanks becasue with that ull need an extra valve plus this is almost 3 times bigger so less refills plus u can still unhook it when u want im definetley gonna try this when i get my car but i think this tank is the perfesct size not to small but not to big check it out and tell me how it turns out
OriginalWheelman
4-27-2006
| « Re: (Sky240PWR) | 11:20 PM 7/23/2006 |
| Quote, originally posted by Sky240PWR » | | i was thinking of doing something like that, what about fuel line, can you make a can(like a catch can) where the fuel line spirals in it so there's room for dry ice, will that work? |
I've seen this on a demo derby car before. The owner claimed it worked wonders.
corey240
98 240sx SE
Cumberland MD
9-8-2005
| « Re: (OriginalWheelman) | 4:22 AM 7/24/2006 |
that tank looks cheap and i dont like it. im gona use my trusted tank brand. i forget what it is but i know they are good and wont explode at high temps, my friends was some cheap ebay thing and exploded under the seat of his car one day and it was only 97 degrees out. it put a small hole in the flore and blew the seat off the rails. this is one of thos things you dont wana ebay unless its name brand, i plan on running 2 24 oz tanks, and if i do the diy oil cooler il probly have another one for that too.im going to myrtle beach in 10 min keep this thread up for 5 days
tonynalli
3-15-2004
| « Re: (corey240) | 10:36 AM 7/24/2006 |
i used to have an intercooler sprayer on my old evo of mine and i sitll have it in my room and are planing to put it on my coupe...the whole idea is to cool the air in the intercooler...as we all kno denser air is better for the combustion process. xckid.....you are right about that...but cooling a radiator in a fast amount of time will not cause anything to become brittle..they are designed to get hot and cold in a fast period of time.. if you guys pay attention to any of the drift comps. youll see they have intercooler sprayers and i have seen some cars with radiator sprayers also. if you take a look at the attachment that i have included you will see what the "sprayer" bar looks like...well i was figuring if you made your own it would prove to have more surface area for better cooling..
Attachment: untitled.JPG (27589 bytes, downloaded 69 times)
