 Fuel Injector installation(KA24de) Pictures
vancouverbc
Online
1991 240sx
langley
10-30-2003
Decided to write this up as it was so effortless.
1. Unscrew your gas cap to relieve fuel pressure.
2. unfasten two philip head screws for each injector. you may need wd40
and impact screw driver if screws corroded.(you may want to unfasten 2 10mm bolts that hold the electical bar, first)
3. push in on fastener and pull off electrical connection at each injector.
4. take a very large(larger the better) flat head screw driver and twist screw driver to pop off fuel injector. cover point of srewdriver with cloth to minimize damage.DO NOT USE A VICE GRIP. something like a chisel might work better than large screw driver. See picture to see where to place screwdriver head .
5.be sure to coat the new injector o-rings with vaseline.
6. place new injector in hole. place the point of large screwdriver on the injector top(on safe place) , gripping the screw driver lean in with your weight and give a push. the injector will pop in. Or use a 10mm socket attached to nut drive.
7. if only replacing o-rings, clean injector tail piece before putting injector back.
I bought my new injectors(4) from http://www.Deatschwerks.com for a total of $207 U.S. shipped to Canada taxes included. You get a $50 core credit if you return old injectors so injectors cost about $35each. Dealer wanted $1000. They give you new o-rings and grease free.
part no.: INJ-NIS1-370-4
list of injectors:
http://forums.nicoclub.com/zerothread?id=109492
Modified by vancouverbc at 1:01 PM 11/30/2007
Modified by vancouverbc at 6:57 AM 8/10/2008
Modified by vancouverbc at 6:59 AM 8/10/2008
Attachment: 000_0840.JPG (164983 bytes, downloaded 2619 times)
1989-1998 240sx TUTORIALS
FACTORY SERVICE MANUAL
Factory service manual2
Factory service manual 1989
Old FAQ
INSTALLS
Pictures of parts
vancouverbc
Online
1991 240sx
langley
10-30-2003
 « Re: Fuel Injector installation(KA24de) Pictures (vancouverbc)
injector out
Modified by vancouverbc at 8:49 PM 6/10/2006
Attachment: bar.JPG (75412 bytes, downloaded 2482 times)
vancouverbc
Online
1991 240sx
langley
10-30-2003
FOund a ground close to the injector closest to front of engine. It was very corroded so I cleaned it.
Attachment: ground.JPG (41777 bytes, downloaded 2249 times)
vancouverbc
Online
1991 240sx
langley
10-30-2003
10 percent discount no longer available. they give free shipping instead. say you are nico member. also, if you damage the old fuel injector you wont get the core money back. Their site explains the procedure for shipping old injectors back for core money back.
Axel Grungy
240sx Tech Moderator
Online
01 G20
Cincinnati
7-8-2003
my injectors were a BEEEITCH to get out, not nice and easy like you explained.
vancouverbc
Online
1991 240sx
langley
10-30-2003
 « Re: (Axel Grungy)
Quote, originally posted by Axel Grungy »
If you use a large(very large) screw driver, they easily pop out. a large screw driver gives you lots of leverage(long handle) and the large head has more area in contact with injector.
Modified by vancouverbc at 7:42 PM 9/9/2006
Axel Grungy
Online
01 G20
Cincinnati
7-8-2003
yeah i know i did it just like you did, but mine just did not want to come out at all. my car was a slut.
rsmithdrift
1993 240sx fastback se.
Sarasota, FL/Chattanooga, TN FL/TN
1-27-2006
Ugh....So, I got my new injector and went to take out the old one.....I got out the phillips head thinking this was a mistake by Nissan to use a phillips head screw with such pressue......the top screw was tight but poped and came loose, Unfortunately the lower screw just seemed to turn to hot butter and completely rounded itself off with me only applying about 5 pounds of pressure on it. :angry7
How the **** do I get that god damn son of a ***** off of there now?? I'm so ****ing pissed I can't even think straighthsaftawofhaiop dghasiopdvgo awdjlczlse!!!!!!!!!!!!!!!!!!!!!!!!!!!!
93 240sx SE Fastback: Intake, Cams, hi-flow Cat, strut bars, Megan Coilovers
click on car name for more pictures.
My drifting movie.
http://forums.nicoclub.com/zerothread?id=216834
Axel Grungy
Online
01 G20
Cincinnati
7-8-2003
if your talking about the metal cap dealys on top of the injector, i guess its time to drill and tap it. pretty much the only way.
S0lid_Snake
shopping for a car
On
9-14-2006
 « Re: (Axel Grungy)
i realize this is an old thread, but im gonna post this in case someone searches with the same problem, is you strip the head off a screw, use an ez out first to see if you can get that sucker out
if that doesnt work, then next time try an impact screw driver all you have to do is hold it and give it a smack with a hammer and it spins and looses the stuborn suckers
Quote, originally posted by dickie »
if they sell apc parts, chances are youre in the wrong place.
You car can have speed, reliability, or be cheap, but only 2
it can be cheap and fast, but wont be reliable
it can be fast and reliable, but it wont be cheap
it can be cheap and reliable, but it wont be fast
SpuGen
1992 240sx SE
Vancouver BC
12-31-2006
Sorta off-topic with the thread, but are there any other grounds for the injectors? The dealership told me that my injector grounds are whack and that it's shorting out the #2 injector. The same injector they replaced 2 months ago.
any pic of the general area for the ground other than just a closeup? thanks!
btw, I'm in Vancouver and it'd be awesome if someone could help me figure this out.
vancouverbc
Online
1991 240sx
langley
10-30-2003
 « Re: (SpuGen)
The red wire is postive so the other wire is ground.
Soravia
1991 240SX Coupe 1992 240SX SE Coupe 2003 SE-R Spec V
Jacksonville FL
11-18-2005
Liquid-Wench is a necessity to pop the injectors from their holes.
I don't have an impact screw driver or a hammer. I used an electric drill and broke the magnic screw tip at the last one.
I resorted to cutting the washer out with a tiny saw.
For SALE: 2003 SE-R Spec V 6 Speed Manual with LSD Brakes =$150. Running Strong.
1991 - S13 Coupe KYB AGX + Eibach ProLine $475, Strut Mount $160, ClutchKit $150, ExhaustSet $300, WaterPump $50, Radiator $99, FanCluth $45, Clutch Master $30, Brake Kit $310, Chassis $150, Anti-Theft $XXX, Audio $250, Celica Seats $200, Alternator $115, Starter $130, NISMO Wheels, Stillen Strut Bar, RedCoupe Shell $1,500 NEXT>>Bushing, LSDStatus - Running Strong.
1992 S13 SE Coupe Being taken apart for VQ Swap VQ30DE $320, ECU $50, Harness $100, MAFS $50, Intake Manifold $99, Z33 6-Spd $380, Poly Mounts $125, Z33 Oil Pan $121
For Sale : FL, S13 Radiator, KA24DE, Automatic, ECU, Starter, EGR, FAN, Alternator, etc NEW LOW PRICES
CrypticScorpio
1992 240sx SE Hatch
barrie on
2-18-2007
nice write up man. if this dosent work to fix my buzzing EGi relay, prepare to see another 92 coupe FS
R.I.P. 1992 S13 Coupe LE
Just got a 1992 S13 Hatch SE
Quote, originally posted by srpowered240sx »
bras are for damaged front ends, or women with a set of healthy boobies.
ppctx
93 ka24de-t
Fort Worth TX
4-5-2007
No need to read me. think I found my answer. http://forums.nicoclub.com/zerothread?id=265570
Modified by ppctx at 7:44 PM 7/18/2007
nisssan-drive
1993 240sx
all over tx Texas
11-6-2007
Damn 200 bucks for all four injectors... I paid 150 bucks for a single injector this ***** better last me my whole life!
alkemyst
Florida
10-28-2003
 « Re: (S0lid_Snake)
Quote, originally posted by S0lid_Snake »
<image of impact screwdriver cut>
I had a very clean and non-corroded rail, I still used this tool. It's a great tool for anyone to own...the modern version is the impact gun.
You don't need to pound the hell out it it (I used a rubber mallet). Also give a practice whack on a screw in some wood to make sure you are loosening.
I was looking at a $5 one at harbor freight, but the $20 one at an Advance Auto Parts was much nicer and should last a lifetime.
Outside of that, I just used a wide long screwdriver and was I pryed sort of rotated the injector while pulling. Easy. Removing the vacuum block (just unbolt it and fold it away) between the back two injectors make the job easier back there.
Also I don't trust the fuel cap method to relieve pressure. Pull the 15amp fuel pump fuse, start the car...run it until it stalls and then give it another crank. Pressure *SHOULD* be out, but like any pressurized system, esp. one you are troubleshooting *EXPECT* pressure to be found.
Busy day for me, did my injectors and compress/dryer/expansion valve in my wife's day.
beer time now.
Now my Kensai, I curse you to be a Ronin and with the my remaining spirit I, beseech Chimata-No-Kami, to have you wander through time and distance lands, seeking a new master.
Copyright © 2000-2008 by NICO
 Car Specific Links
-  350Z
-  300ZX
-  Classic Z
-  240sx & Silvia
-  240sx Convertible
-  Skyline
-  Q45
-  M35/M45
-  EX35
-  G35
-  G37
-  Maxima/I30 & I35
-  Murano & FX35/45
-  J30/M30
-  Altima/Bluebird
-  Hybrid Altima
-  G20 & Sentra
-  200sx & Sunny
-  Armada/QX56
-  Pathfinder/QX4
-  Xterra/Titan & Frontier
-  Quest
-  Datsun
-  Versa
-  Rogue
-  Terranaut
-  Others
-  VIP Forum
-  SEARCH
-  NICO Banners
 General Forums
-  General Chat
-  Infiniti General
-  Multimedia
 No Parking
-  Sport Zone
-  Gaming
-  Computers
-  Media
-  Great Outdoors
-  Around the House
-  The Music Room
-  Politics Forum
 NICO Meets
-  Regional Meets
-  National Meets
 Motorsports
-  Team HLM
-  Drift Forum
-  Road Racing/Auto-X
-  Drag Racing
 Classifieds
-  Advertisers Specials
-  Nissans For Sale
-  Infinitis For Sale
-  Other Vehicles For Sale
-  Wheels/Tires
-  Brakes/Suspension
-  Engine/Drivetrain
-  Exterior
-  Interior
-  Electronics
-  Complete Part-Outs
-  Infiniti Parts
-  Parts WTB
-  Non-Car Related
-  Fabricators' Market
 Engine Forums
-  CA
-  KA
-  KA-T
-  RB
-  RWD-SR
-  Transverse SR
-  VQ
-  VG and VE
-  VH and VK
-  Hybrids
 Tech Forums
-  240sx Tech
-  Nissan Online Mechanic
-  Infiniti Online Mechanic
-  Engineering Talk
-  Audio and Security
-  Wheels and Tires
-  Brakes and Suspension
-  Interiors
-  Car Buying Advice
Home Photography Help
