Q451990 »
https://forums.nicoclub.com/q451990-u142.html
Sat May 13, 2006 4:23 am
The EGR valve is located on the left (driver's side) of the engine near the firewall and master cylinder. I suspect you have a CA Q if you're getting a code for EGR function on a 91? (EDIT: Just notice the A50/P28 sticker in your picture. You have an ECU for an Active CA Q ) The valve itself looks like a flying saucer landed on a pipe that bolts into the plenum. You should be able to push it closed by pushing upward on the valve from the bottom... At idle this should slow the RPMs or even kill the engine... If there's no change you have a major carbon blockage.
In your case, I suspect that there's a sensor bolted into the plenum that fits into the port that leads from the EGR to the intake. This is the sensor that is not sensing the hot gases at the appropriate time... so you now get to figure out why! Typically the port in the plenum will gunk up with carbon to restrict the air flow. Since it looks like you're on the way to pulling the plenum to replace knock sensors anyway - plan on spending some time with a dental pick and bottle brushes getting everything decrusted and back to new looking!
Now... rev the car from idle to about 3000 rpms, while touching the bottom of the EGR valve (the part you pushed upward earlier). It should rise and flutter as the RPM increases, and then cut out quickly at about 3000 RPM. If it doesn't move, start checking your vacuum connections for broken hoses, and make sure the terminals on the control solenoid are not corroded.
In case you're wondering... the EGR Valve (short for Exhaust Gas Recirculating) introduces exhaust gases into the combustion chamber during cruise. The idea is to slow combustion and prevent spark knock. It also reduces emissions.
Good luck!
Heath
