sr20det dyno results on stock t25
Z U L8R
Car: 78' DATSUN 280Z + RB20DET , 71' DATSUN 240Z + RB25DET
Sup I'm David. I've probably met most of you GA people. I just dyno'd my SR last week. As far as mods that would effect results: 3" exhaust, turbo xs mbc ( 14psi ), Front mount, everything else stock: t25, injectors, ka maf all stock.
Put down 237.9 RWHP ( ~5k-5.7k rpm ), 260.8 Torque ( ~3.6k-4.6k rpm )
boost @ 14 psi, timing @ ~15btc
I'll try to scan the printout so you can see the graphs. They're pretty smooth, I only took it to 6500 cause after that it falls down and there's no really no point in red lining ,but all in all I'm pretty pleased. I was expecting in the 220ish hp with the same in torque, so the torque impressed me. I'll be getting my safc2 this weekend, and whether or not the machine shop's done with my rear sump oil pan for my rb25 or not, will determine if i rob 4 of my 550's and z32 maf from that.
I'm curious to see some other dyno's on t25's, make sure you put @ how much boost. Z U L8R <=]
One_Love
Car: 1995 nissan 240sx
damn thats a torquey little guy
good numbers
namwons_240
Car: 97' 200sx ser
^was thinking the same thing
being closer to sea level helps too but i like those torque numbers
oneslow240se
Car: 91 240se
didn't realize you can put that much out with only upgrade exhaust, fmic and 14psi......
Nismo_Freak
Car: 89 Nissan 240SX
oneslow240se wrote:didn't realize you can put that much out with only upgrade exhaust, fmic and 14psi......
Those numbers are the a-typical standard for an SR with a stock turbo.
Nyteryder
Car: 90 240sx(sr20det), 98 altima(75 shot of n2o) 01 jetta 1.8t
Where did you dyno your car, mainstream, balance, topspeed..........
Z U L8R
Dyno lab right next to lethal injection.
llteddy4playll
Car: 240sx
I pretty much have the exact same setup and dyno my car at 15psi and made 233whp and 266wtq. But i was running rich and a big exhaust leak. Whenever i fix my exhaust leak and install my powerfc and tune i dont see why i wouldnt hit over 240 or 250whp range.
drifter_for_life06
Car: Daily: '16 WRX
Toys: '92 RPS13 400whp
Exocet
that definately seems like a feasable number
ive seen 250 @ 15psi
