Sockington »
https://forums.nicoclub.com/sockington-u28794.html
Mon Apr 17, 2006 10:29 am
First off, removal of driver's side strut/tension rod. Easily done.
Mr. Crossmember, you're next.
Jesus! I found a huge rot hole on the driver's side rail.
Clean up time.
The rust that was on the floor after the hour of grinding.
The front crossmember hanging out behind the car.
When I was shuffling around below the car, I noticed that the front wood blocks were no longer supporting any weight. Since the engine,transmission, and crossmember was removed, the car became VERY titly.
I jacked up the front and added some wood blocks for safety's sake.
That hole certainly looks nasty.
If you look at the hole, it's like the car is frowning about it's current condition of neglect.
Time to make some patches.
Now, please don't mock the following pictures. I'm using a 220volt stick welder for the welding, and this was my first time actually welding. Ever. Advert your eyes.
Test fitting.
Completed patch.
I must admit, welding on your back while trying to hold your head up, a trouble light on where you're welding, making sure you mask stays down, and trying to not burn holes through the rail was very difficult. At this point, I may have actually had about an hour since my first weld was done.
That nice flat spot gives me a good spot to jack from. I know it's not pretty, but I'll be damned if that isn't the toughest spot on the whole damn car.
I'm going to seal up the holes around the patch with Goop or Seal-All, and then undercoat my new patch. I don't think I did to bad for not knowing how to weld at the start of the day, using a stick welder, and trying to weld on my side for my first time welding.
