Having researched this for the past week all over the place, including other threads here, this is what I *think* I've learned for a Verizon Treo 650 (every carrier's Treo is potentially different, Verizon may be worse than some, but some of this may be useful even if you're not on Verizon, and reports have it that some other carrier's Treo 650s work fine with the Infiniti):
1. It may help to update to the latest version of the OS. For Verizon at the moment this is 1.04 of the Verizon specific OS. [ Go to
http://www.palm.com/us/ and click on the middle right link for "Treo Software Updates" and follow the instructions.
2. It may help (but the site doesn't seem to be 100% up to date) to poke around on Infiniti's Bluetooth page also:
http://www.infiniti.com/bluetooth/
3. For a Verizon Treo 650 at least, the pairing itself will be easy if you follow the instructions. However you will only get partial functionality, which means:
4. A Verizon 650 will let the Infiniti M answer the phone. No problem. (Though some have said call waiting etc. is a seperate issue - I haven't tested any of this.)
5. To make a call is more complicated: A. You first have to force a reconnection to the phone by hitting the "Phone" button on the dash or steering wheel. Then B. you have to hit the call button a second time and then have about 12 seconds to complete the calling procedure. The problem seems to be that the Treo disconnects again after 12 or so seconds unless it has received a complete dialing command. For Voice tags or a quick spin down the address book, the Infiniti will usually complete the command in time. For voice dialing a number one digit at a time, it won't.
6. However, using the just-updated Treo Voice Dial from the various Palm sites, you can certainly voice dial the Treo itself dirrectly and the car will then pick up the connected call automatically. In fact, it isn't much harder to pick up the phone itself and do this - and you have voice tag access to every contact, etc., etc. Still, it is a workaround where you're holding your phone and shouting into it for a second or two.
7. You can't send Verizon Treo contacts to the Infinity address book. In fact, retrying the operation reboots the Treo. It appears to be a big bug.
8. Usually you can work in the Infiniti's own phone book by selecting "Settings" and punching down to the address book. However, you must do this with the phone nowhere near the car - otherwise the car will connect to it, start to let you work, and suddenly dump you out of the phone book with a message announcing the phone has disconnected. In the abscence of the phone, however, things work smoothly. If you find you absolutely have to work on some menu setting in a "Connected" state, which, as I mentioned, only lasts to a count of twelve, there is a workaround that sometimes works and sometimes doesn't. Going to the Treo's Bluetooth application, and punching down through the menus to Trusted Devices / Details for the car connection while the phone is "connected" sometimes hangs the connection! Then you can work away as long as you please on the Infiniti's menus. (But sadly, no, although finally permanently connected, the Treo won't respond to a dial command from the car - and it may hang at some point requiring a soft reboot.) In all or almost all cases, however, you're better off working on the phone book with the Treo out of range.
9. When I called Verizon tech support the tech told me that Verizon does not support Bluetooth in cars! Only connections to headsets and computers. He gave me Palm's number to call. But the Palm number had a voice message saying to call Verizon. Yes, Verizon and Palm are being totally irresponsible since they won't even pretend to listen to the problem. OTOH, Verizon otherwise offers the best service in the business and the Palm is a little gem, if flawed. So what can one say?
10. Rumor has it that even the Verizon Treo 700p works much better. A Treo tech in a Verizon store who wasn't supposed to answer my question unofficially said that Treo enthusiasts were hoping Verizon would come out with an update for the 650s based on the Bluetooth modifications in the 700p, but he didn't know and Verizon wasn't telling him.
That's all I know and some or most of it may be wrong. Good luck!
Modified by CCEastlake at 3:56 PM 6/7/2006
Modified by CCEastlake at 3:57 PM 6/7/2006
Modified by CCEastlake at 3:59 PM 6/7/2006
Modified by CCEastlake at 11:18 PM 6/14/2006
