sil80drifter wrote:Hey, that is a very similar setup to mine you have. Except mine hasn't ran since last year. When I do get it to run, I've been considering the ECU tuning route, but never really got the software to work, although I've been in touch with Devious, it always was a work in progress for me. I am assuming you chipped the stock ECU, and then modded the bin files, right? What software did you end up going with? How do you datalog? Would it be ok for me to take a look at your base maps? I think they would probably be a good point for me to start from. Of course this would have to be cleared with Devious, he's the creator, but if he gives his ok, and he he has sent me maps in the past, I'd really like to see where I can take this ECU tuning thing.
And yes, I think we all wanna see dyno numbers, it's not too often a nice clean SOHC comes about and looks and works all nice.
Hope she keeps running well,
sil80
Well yes I did chip a stock ECU, but for a 92 Stanza so I'm able to have consult.
The base tune I used is from Gabe but the same tune, just with a Z32 MAFS is available from the ECCS TEC forum. But I should be posting mine up there when I get my cars final tuning done.
I use the 925style.com Rom Editor at the moment, it suits my needs and is user friendly. For datalog, I will be using DSCAN with maptrace to see exactly where the ECU is lookin gon the maps. Then in conjuction with my wideband I'll be able to easily fine tune everything to the right AFR's. But first I have to get my consult setup working, should be done with it tonight.
And I cannot wait to dyno and drag it. I want to see want kind of power I'm making.
