OverBoosted180
89' 240sx
Miami Fl
1-17-2006
Ahh!!! See, this wat I like to see!! How much Power are you looking to build Datsunboy?
/<*Growing Slowly, But SURELY!*>\ OfficialJFyre@yahoo.com
namwons_240
97' 200sx ser
Wausau WI
10-22-2005
| « Re: (OverBoosted180) | 7:11 AM 3/25/2006 |
is it just me, or do ca's look like mini rb's?
rico05
I pwn.
Online
1992 RMS13 w/ CA18DET
Carrollton Texas
6-23-2003
They should like like mini RBs, because for all intents and purposes, they are. They share the same block and head design, as well as some internal components (lifters, etc). DAMN that is going to be a monster of a motor! If you could, get us as much info on the CA20 as you can, as I am sure that many are as interested as I am on how to go about doing it practically (damn you Tomei!). Knowing there are motors like that out there in the wide, wide world helps me sleep at night...
SR20DET = 189cc Wasted.
| Quote, originally posted by dickie » | | some hard gheyness in this thread. |
XTCshri2222
91 Nissan Silvia coupe, CA18DET powered
East Hanover NJ
11-23-2005
| « Re: CA20DET build!....pics (datsunboy) | 7:43 AM 3/25/2006 |
that is one beautifull machine
 CustomCarPerformance.com SiCrew.com PowerZamCam.com ** Official Nistune Dealer/ Installer **
datsunboy
Datsuns
New Zealand
3-29-2004
Its not mine....its a mates. his engine builder reckons he should get around 450RWHP from it.I'm back down there probably Monday after work, so will ask him some more questions on it. what do you want to know?
rico05
I pwn.
Online
Carrollton Texas
6-23-2003
Mostly, what crank modifications, rod modifications, and piston specs. Also, any info as to where he got his parts, and if they will ship to the US
Zero260
91 240sx coupe
Madison WI
11-6-2005
| « Re: (rico05) | 5:41 PM 3/25/2006 |
I just read someone the other day that was posted here that said the CA motor was basically an RB with 2 cyls. copped off
Zero260 --- can never be fast enough
rico05
I pwn.
Online
Carrollton Texas
6-23-2003
Close enough that I tell n00bs that very thing."WTF? Where is the SR?" "SR? I have a baby RB."
CA19DET
Trinidad & Tobago
5-15-2003
i am very very interested in teh 4G63 Rod combo... what was special about them did he have to machine the caps to fit the crank, special bearings?? are they forged rods or factory...?? more info needed please.
CA18_shift
Kouks
2004 Nissan Altima 2.5SL
Orange Park FL
4-18-2005
| « Re: (rico05) | 9:16 AM 3/27/2006 |
Yes the Ca and RB share alot, and have alot of the same basic design. However, the block height, bore and stroke of the motors are way different, (square vs. undersquare), and if you compare the rb25 to the ca18, you get 86mm x 71.7mm, while ca is 83mm x 83.6mm. CA has app. 452cc per cylinder, while Rb has about 417cc.
2004 Nissan Altima 2.5SL Super Black -04 Maxima SE Wheels 245/45/R18 -Nismo Cold Air Intake -06 Altima SE-R Suspension -More to come....
OverBoosted180
89' 240sx
Miami Fl
1-17-2006
I love my CA aka the mini RB...So small but packing BIG power!
fraz
rb30det gts4
New Zealand
8-28-2004
| Quote, originally posted by CA19DET » | | i am very very interested in teh 4G63 Rod combo... what was special about them did he have to machine the caps to fit the crank, special bearings?? are they forged rods or factory...?? more info needed please. |
There are 2 sizes of 4g63 rods. They are identical apart from the width of the big end. Any rod from evo1 onwards has the narrow big end. You need to take about 0.9mm off both sides i think. Dont have my pc to check the specs i have saved. They are 150mm long and have 22mm pin, maybe 21mm, i cant remember either. I had a set narrowed to run on a ca18det crank in a ca20 block with 84.5mm honda pistons from 2l crv with b16a head You can run the factory evo bearings
datsunboy
Datsuns
New Zealand
3-29-2004
ok....hes using a standard CA20 crank....and VR4 rods machined down ( so I assume these are the first gen rods you speak of? ).... CA20 crank......and using some kind of toyota cam belt that fits the taller block.and custom spec Wiesco pistons
CA19DET
Trinidad & Tobago
5-15-2003
my god...you know my engine builder is a 4g63 wizard and had tonnes of 4G parts laying around, gotta check that out.. but this got my attention BIG time...
| Quote » | I had a set narrowed to run on a ca18det crank in a ca20 block with 84.5mm honda pistons from 2l crv with b16a head You can run the factory evo bearings
you used a B16 head on a CA18 or pistons for a B20 using a B16 head so you ge the correct valve releifs etc.. and evo bearings work (with standard CA18 crank and rods too???), man if so - thats great cause we can now use all those slick super trick coated evo bearings.
fraz
rb30det gts4
New Zealand
8-28-2004
| « Re: (CA19DET) | 1:29 AM 3/29/2006 |
| Quote, originally posted by CA19DET » | | my god... you know my engine builder is a 4g63 wizard and had tonnes of 4G parts laying around, gotta check that out.. but this got my attention BIG time... you used a B16 head on a CA18 or pistons for a B20 using a B16 head so you ge the correct valve releifs etc..
and evo bearings work (with standard CA18 crank and rods too???), man if so - thats great cause we can now use all those slick super trick coated evo bearings. |
You can use 84.5mm pistons from a b20 honda that has been fitted with a b16a head. Go to http://www.theoldone.org or something, they sell a million sizes of trick pistons to suit any possible combination of honda you could think of. There are about 4-6 different crown sizes available off the shelf, so you can easily find something to fit. The evo1 onwards rods are 150mm with 26.4mm wide big end that needs to be narrowed to 24mm CA crank. the small end is 22mm so the honda pistons need to be bored from 21 to 22mm pin, or you can get some trick wrist pins made up
CA19DET
Trinidad & Tobago
5-15-2003
man thats jsut sick.. thanks for all the info..
Driftek Motor Sports
1989 240sx, 1986 Turbo VG30ET Truck, 1986 300zxt Shell for sale or part out.
Chesapeake VA
3-26-2006
| « Re: (CA19DET) | 10:42 PM 3/29/2006 |
I am using Forged I beam Pauter rods for a ca20e (yes they make them) with the ca crank, and a set of custom pistons 15 mm shorter and flattened (top) for a ca20e (I did have to send my head out to arias for them to find the angle of the valves etc....)Heres my delima, what rpm is acceptable for this block without having a crank girdle? And What is the part # for the Toyota Timming belt you guys are using for the taller block? The Honda piston/ DSM rod combo is engenious, wish i had known about it before i started building my frankenstein.....(I love it we've evolved to honda tuner status....We can swap heads on different blocks....lol)
Driftek Motor Sports Presents: www.true180.com
datsunboy
Datsuns
New Zealand
3-29-2004
I'll try find out 2moro what part number the belt is.....but hes not even sure that it is a Toyota one....I forgot CA20s didnt have a crank girdle......wonder how thats going to go with the power hes hoping for......hope nothing breaks! evolved to honda??? weve ALWAYS beena able to swap heads on different blocks! The old Datsun "L-series" engine is a non-crossflow single cam carbed engine.....and a lot of people bolt on a "Z18ET" head....which gives it crossflow EFI turbo. wierd as it sounds....I also know a guy that is putting a mazda MX5 head ( DOHC EFI )....onto a Datsun "A-series" engine ( pushrod motor!! ). so the head swapping thing sure isnt new for datsun/nissan tuners.....
Chesapeake VA
3-26-2006
| « Re: (datsunboy) | 7:56 AM 3/30/2006 |
| Quote, originally posted by datsunboy » | | I'll try find out 2moro what part number the belt is.....but hes not even sure that it is a Toyota one.... I forgot CA20s didnt have a crank girdle......wonder how thats going to go with the power hes hoping for......hope nothing breaks! evolved to honda??? weve ALWAYS beena able to swap heads on different blocks! The old Datsun "L-series" engine is a non-crossflow single cam carbed engine.....and a lot of people bolt on a "Z18ET" head....which gives it crossflow EFI turbo. wierd as it sounds....I also know a guy that is putting a mazda MX5 head ( DOHC EFI )....onto a Datsun "A-series" engine ( pushrod motor!! ). so the head swapping thing sure isnt new for datsun/nissan tuners..... |
Yeah definately, I need that Timming belt part #..... Thanks....
CA19DET
Trinidad & Tobago
5-15-2003
thats why i guess TOMEI uses a custom crank instead of the CA20 block with no girdle.
nissanic89
89 nissan coupe
dayton oh
3-6-2006
| « Re: (CA19DET) | 11:32 AM 3/31/2006 |
i think what he is saying is that you need pistons to fit a b20 motor thats been fitted with a b6 head, not a ca18det fitted witha b6head...all this info is very interesting and came a month too late, we had a spare block and spare 4g6 rods laying around we could have done some experimenting. jon opps this is actually Not_a_Sr... someone left themselves logged in last night. ..
'89 240sx coupe baby RB and a pimp a$$ driver
 hooolllyy diver ohhh holy diver
oldschoolsilvia
350z
Cleburne Texas
8-1-2005
| « Re: (nissanic89) | 3:35 PM 3/31/2006 |
That is very nice
http://www.club-s12.org
Chesapeake VA
3-26-2006
| « Re: (CA19DET) | 5:20 PM 3/31/2006 |
| Quote, originally posted by CA19DET » | | thats why i guess TOMEI uses a custom crank instead of the CA20 block with no girdle. |
I think i can used a ka24e crank girdle after better inspection with a litte modification....
fraz
rb30det gts4
New Zealand
8-28-2004
ka cranbk girdle wont fit, the bore spacing is too different. ca18 crank girdle will bolt on using ca20 caps and ca18det main bolts and will clear the ca20 crank. The early crank girdle from ca18det (late u11) wont fit
Chesapeake VA
3-26-2006
| « Re: (fraz) | 6:29 PM 4/1/2006 |
| Quote, originally posted by fraz » | ka cranbk girdle wont fit, the bore spacing is too different. ca18 crank girdle will bolt on using ca20 caps and ca18det main bolts and will clear the ca20 crank. The early crank girdle from ca18det (late u11) wont fit |
Thanks for the advise bro...... I'll check it out......
Seishuku
1987 Nissan Silvia 5-speed, SR20DE+T@11PSI, Alky Injection
Beloit WI
5-13-2005
| « Re: (Driftek Motor Sports) | 1:52 AM 5/16/2006 |
| Quote, originally posted by Driftek Motor Sports » | | Yeah definately, I need that Timming belt part #..... Thanks.... |
Anyone have that part number?
fraz
rb30det gts4
New Zealand
8-28-2004
i got a quote from econobelt in the states for a good price. they were going to cut down a 20mm belt to 19mm(3/4) to fit ca.you need to drill the block on the ca20 in the same spot as the idler pulley on the ca18. drill to 8.6mm and tap to m10. you can also use a cut down h22a honda timing belt
tyrannix
Real Decepticon
go big or go home
mckinney tx
4-6-2005
| « Re: (fraz) | 7:20 AM 5/16/2006 |
Fraz, you get my last email?
S13 cardomain page fight my giant battle monster CA18DET Silvia . JZX83 Cressida . xxxxx AW11 (still stock, havn't decided what to do yet)
datsunboy
Datsuns
New Zealand
3-29-2004
| « Re: (tyrannix) | 1:52 AM 6/6/2006 |
Update.....We finally got it started tonight....running a Link ECU, that hasnt been tuned yet, so was running real rich. and for some reason, all 4 coils spark at the same time every time you switch the key on.....(without starting engine). There must of been some fuel vapour left in there......and BOOM! haha, wasted the intake manifold!
Modified by datsunboy at 5:59 PM 6/7/2006
Attachment: DSC00567.JPG (295618 bytes, downloaded 4860 times)
PantherRacer
1998 Nissan Cedric GranTurismo Ultima
Nassau Bahamas
4-24-2004
| « Re: (datsunboy) | 6:29 AM 6/6/2006 |
Hope you get it to work properly soon, cuz I'm sure I'm gonna be doing this in the future lol. The CA does look like a Mini RB....I'm gonna paint mine just like one lol.
Brown Squad son! | Quote, originally posted by Soravia » | Beer makes you ghey? I KNEW IT!  | What I want at this point in life, is air suspension and Work Eurolines for my car. Is that so much to ask?
rico05
I pwn.
Online
Carrollton Texas
6-23-2003
CHRIST that intake mani has insane volume! That is going to be a lot of motor to flow that much air.
datsunboy
Datsuns
New Zealand
3-29-2004
| « Re: (datsunboy) | 10:02 PM 6/6/2006 |
another pic
Attachment: DSC00568.JPG (289736 bytes, downloaded 4977 times)
datsunboy
Datsuns
New Zealand
3-29-2004
| « Re: (datsunboy) | 10:08 PM 6/6/2006 |
another pic!
Attachment: DSC00569.JPG (305397 bytes, downloaded 4467 times)
shane_lxi
'71 Datsun 521, '89 240sx coupe, '90 240sx fb, and 2 s13 shells
Hoquiam WA
5-17-2006
Nice :D. I have a '69 510 2 dr, so I can appreciate all the hard work that went into that!!! (I'm in the process of a ka-t setup on mine :P )
datsunboy
Datsuns
New Zealand
3-29-2004
yeah I've got a 70 4door of my own with a CA18DET.but this one here is amazing.....pics are off my cell phone, so the quality is crap, and doesnt do this car justice!
ks13
89 Silvia K's
Southern NH
9-3-2006
| « Re: (datsunboy) | 11:18 PM 6/15/2008 |
Is this motor still alive by any chance?Curious as to what kind of power it made....
themadscientist
Super Moderator
Online
staring down at you with disdain from the
spooky mountaintop castle
11-12-2002
| « Re: (ks13) | 11:24 PM 6/15/2008 |
holy dusty thread batman!
BRINGING SEXY BACK
Two-Fortee
180sx.
Whitby Ontario
11-7-2007
| « Re: (themadscientist) | 6:49 AM 6/16/2008 |
I was at a big car meet checkin out my buddies ca18 silvia, and a guy walks up and goes "hey is this an rb20?" "No, ca18.." "oh CAA? Nice." Just realized only canadians will get this, CAA is like AAA but in Canada, for roadside assistance and whatnot
r34 gtr
ugly black 89 240sx hatchback
Huntsvegas AL
12-29-2002
He probably said CA-eh? not "CAA." Damn Canadians.
I'm like the Gangstalicious of NICO.
| First 1 2 > Last |
