1993 240sx Capacities and Specifications
Fuel tank 15-7/8 gallonsCoolant (with reservoir tank) 7-1/8 quartsEngine oil without filter 3-3/4 quartsEngine oil with filter 4 quartsTransmission fluidManual transmission (M/T) 5-1/8 pintsAutomatic transmission (A/T) 8-3/4 quartsDifferential Carrier (R200) 2-3/4 pintsDifferential Carrier (R200V) 3-1/8 pintsPower steering system 1.0 quartAir conditioning refrigerant 1.8 - 2.0 lb of R12
Engine Tune Up Data:Engine model KA24DEFiring Order 1-3-4-2Idle speed (in "N" position, No-Load) 700 +/- 50 rpmIdle speed (In "N" position, Air Conditioning ON) 1000 +/- rpmIgnition timing 20 degrees = +/- 2 degrees B.T.D.C. at idle speed
High tension cable resistance less than 30 kilo ohmsSpark Plug Typestandard BKR5E-11cold BKR6E-11cold BKR7E-11gap mm (in) 1.0-1.1 (0.039-0.043)tightening torqueN-m 20-29 (2.0 - 3.0 kg-m, 14-22 ft-lb)Drive belt deflection (cold) all belt measurements in millimeters withinches in parenthesisalternator 11 (0.43) limitdeflection after adjustment 7-8 (0.28-0.31)deflection of new belt 6-7 ( 0.24-0.28)
Air conditioner compressorlimit 12 (0.47) deflection after adjustment 7.5-8.5 (0.295-0.335) deflection of new belt 6.5-7.5 ( 0.256-0.295)
Power steering pump withOUT SUPER HICASlimit 13 (0.51)deflection after adjustment 7.5-8.5 ( 0.295- 0.335)deflection of new belt 6.5-7.5 (0.256- 0.295)Applied pressed force N (kg, lb) 98 (10, 22)
Power Steering pump with SUPER HICASlimit 9 (0.35)deflection after adjustment 6.5-7.5 ( 0.256- 0.295)deflection of new belt 5.5-6.5 (0.217- 0.256)Applied pressed force N (kg, lb) 98 (10, 22)
Oil pan drain plug tightening torque N-m 29-39kg-m 3.0-4.0ft-lb 22-29
Clutch pedal height mm (in) 186-196 ( 7.32- 7.72)Clutch pedal free play mm (in) 1.0-3.0 ( 0.039- 0.118)
Front wheel alignment (unladen) fuel, radiator and engine oil full withspare tire, jack, and tools.
camber -1 degree 30' to 0 degreecaster 6 degree 00' to 7 degree 30'toe in mm (in) 0.3 - 2.3 (0.012 - 0.091)toe in degree 2' - 13' ( total toe in angle)Full turns inner wheel 39 degree - 43 degreeFull turns outer wheel 33 degree
Rear wheel alignment (unladen) as abovecamber -1 degree 30' to -0 degree 36'toe in mm (in) 0.5- 4.5 (0.020- 0.177)toe in degree 3' - 25' (total toe in angle)
Brake:
CL22VB (non-abs)pad repair limit mm (in) 2.0 ( 0.079)minimum front rotor thickness limit 18.0 (0.709) mm (in)minimum rear rotor thickness limit 8.0 (0.315) mm (in)
CL25VA (abs)pad repair limit mm (in) 2.0 ( 0.079)minimum front rotor thickness limit 20.0 (0.709) mm (in)minimum rear rotor thickness limit 8.0 (0.315) mm (in)
pedal free height M/T 177- 187 (6.97 - 7.36) mm (in)pedal free height A/T 186- 196 (7.32 - 7.72) mm (in)parking brake # of notches 6-8 (under force of 196N, 20kg, 44lb)
Engine Compression in PSI
standard 179 @ 300rpmminimum 151 @ 300 rpmdifference limit between cylinders 14 @ 300rpm
Thermostat inspection
valve opening temperature 170 degree fahrenheitmaximum valve lift 0.31 inches @ 194 degree fahrenheit
Oil pressure check Idle Speed More than 11 PSIAt 3000 rpm no load 60-70 PSI
Radiator cap relief pressure 11-14 psileakage test pressure 23 psi
Return to “240sx Articles”
