Not knowing any service history on the car, my first guesses would be either MAF (try cleaning) or injectors (ohm them to check). The process for both has been covered and can be found through some research and reading.INFINITI Q45 wrote: My Q45 has a ruff idle , it feels like a off balance vibration from the engine.The car has 128K on it and has been well maintained. How serious is this problem, and how can I fix it?
Thank you for any help.
best to take off the EGR valve andt he TB... Generally what gets gunked up is the port between the EGR valve and the plenum... Take the EGR valve off and seehow clogged it is... if its really clogged, you may have to pick at it with a sharp pointy object (screw driver)... Once you get all the hard stuff removed, you can use carb cleaner to get the rest.......gloucester Q wrote:jeff-any tips on how to clean the egr? -randy
Should that prove too challenging or not manageable for one reason or another, at least start another topic (Off topic conversation muddies information and makes searching difficult).Q45tech wrote:"i am clueless on how this web page works"
Perhaps you are clueless? Normally one spends around 100 hours researching and reading a few thousands posts OR signs up for community college/votech and takes a degree in automotive technology to understand basics applicable to all vehicles.
We have high standards here and expect members to do their part instead of being spoon fed every minute detail.
