Well, that fixed the flashing of my air bag light, which started after i put in a new CD player. But i had to do the door switch 2-3 times before it works. May be you should try it again. (just a suggestion, since i don't have a answer)Big Tone wrote:"Its possibly in diagnostic mode. Put the key in the ignition, turn it ON (engine not running), press the door switch (on the B pillar, below the latch) at least 10 times within 10 seconds of turnning on the ignition, and it should go off"
