bj180sx
cars
Arkansas
8-25-2002
you know that you can just remove the z hubs and they will work on the 240sx spindles right? I did this on a friends 95 240sx. Way easier than swapping hubs. Also turn in your 240sx calipers at autozone for 300zx rebuilt ones and save. Cost me $50 for each caliper.
90 240sx SE Platinum Mist HKS Cat-Back, NGK Wires, PDM Stait Pipe, Brembo Drilled & Slotted Rotors, Metal Matrix Pads, Stillen Pop Charger, tons of other custom mods and interior
Nils
road racing
Vegas
8-28-2002
| Quote » | Originally posted by bj180sx you know that you can just remove the z hubs and they will work on the 240sx spindles right? I did this on a friends 95 240sx. Way easier than swapping hubs. Also turn in your 240sx calipers at autozone for 300zx rebuilt ones and save. Cost me $50 for each caliper. | ??? Be more specific.... front or rear? way easier than swapping hubs?? huh? n
Nils
road racing
Vegas
8-28-2002
Here are some photos from 240sx.org for a brake upgrade without swapping out the hubs or spindles.
JNM240
90 Coupe (CA18DET), 90 Hatch (freshly swapped 5spd)
Southeast Louisiana
7-31-2002
As far as Z32 brakes go, does anyone know if you need to get the Z32 master brake cylinder as well? I read that the stock S13 master cylinder doesnt push enough fluid through the lines to be as effective as the could be. Also, is there any difference between Z32 turbo brakes and Z32 N/A brakes?
My 1990 SOHC KA24E Coupe
Dragon240
Mobile AL
9-29-2002
I think turbo was the 30mm and N/A was 26mm... Is the 300zx rear brake upgrade worthwhile?
-Dragon-
bj180sx
cars
Arkansas
8-25-2002
Sorry it was late. I meant it was easier than swapping spindles. Hubs are easy to do instaed of entire spendal. Front. Not rear. 30mm are the tt calipers. 26mm are the early NA calipers.
Cyberkreig
Cars, Girls, and Techno. In no particular order.
York, PA
9-1-2002
If i could run down a few questions..What are spindals? I am assuming that hubs are where the wheel studs are. It isnt necessary to swap either is it? It looks like the hub comes off with just a cotterpin, Then you just pin the 5lug hub on? Otherwise you need longer studs. What is picture 4 showing? It looks like you need much larger wheels to fit around those giant calipers?
 -1993 Nissan 240sx 250.3 RWHP @ 15 PSIhttp://www.cardomain.com/id/cyberkreig AIM: CyberKreig
Nils
road racing
Vegas
8-28-2002
| Quote » | Originally posted by Cyberkreig If i could run down a few questions..What are spindals? I am assuming that hubs are where the wheel studs are. It isnt necessary to swap either is it? It looks like the hub comes off with just a cotterpin, Then you just pin the 5lug hub on? Otherwise you need longer studs. What is picture 4 showing? It looks like you need much larger wheels to fit around those giant calipers? | The spindle is the piece shown in photo #5. It connects the wheel assembly to the TC rods, steering rack, shock assembly etc.... The hubs come out pretty easily, relatively speaking =) The cotter pin is only holding a metal cover/washer that secures the axle bolt. The hardest part is to remove the bolts off the axle. Sometimes it can be a ***** to get loose and its a big bolt (I think it is a 36mm, not sure). You need a breaker bar and some sort of extension to brake it loose. Then there will be some small bolts to remove, once all nuts and bolts are off, the hub might still be stuck on there.... just grab a rubber mallet and whack it good a couple of times and it should brake loose. The hub might not be a direct bolt on to a 240 spindle... I am not sure on that. Longer studs are needed depending on what wheels you have, some guys need 60mm Nismo studs (me) and some use stock... that is something you'll have to figure out as you go =) Picture #4 is showing the backside of the 300zx caliper. If it was up to me I'd atleast put on the 5 lug hubs with the brake swap. The thought of self-drilling holes in a brake rotor scares me. My buddy and I just finished a complete 300zx spindle, brake, hub, auto to manual tranny swap on his s13. We had to get a bunch of stuff from the yard.... Master cylinder, parking brake lines, calipers, spindles and SS brake lines from heavy throttle. It is amazing how much lighter the rear 300zx spindles are. I am not sure if you need a master cylinder on a s13 for the swap, we just swapped everything because the car was stripped. But that could be true. n
Cyberkreig
York, PA
9-1-2002
Thank you for your detailed answers to my poorly worded questions
JNM240
Southeast Louisiana
7-31-2002
Ok, so you are running a Z32 master cylinder on your S13? Was it a bolt on install as well or did you have to modify?Reason is theres a NA Z32 300ZX in a junkyard near me with all 4 brakes intact, and i would like a complete list of what i need before i go down there.
Nils
road racing
Vegas
8-28-2002
| Quote » | Originally posted by JNM240 Ok, so you are running a Z32 master cylinder on your S13? Was it a bolt on install as well or did you have to modify?Reason is theres a NA Z32 300ZX in a junkyard near me with all 4 brakes intact, and i would like a complete list of what i need before i go down there. | Well, to swap both sides like we did on my buddies car you'd have to get: Front and rear spindles with hubs. Front and rear calipers. Parking brake lines, Rotors. You would then have to get custom SS brake lines and cutom made rear shocks. Like I said.. I am not sure on the master cylinder, but, I would grab it anyways if I was at the yard. I personally have a s14 with only the front 300zx brakes. nils
bj180sx
cars
Arkansas
8-25-2002
rears aren't really needed. Get the hubs unless you can get a machine shop to drill the 4 lug pattern.
tupac03602
keene, new hampshire
12-26-2002
maybe whoeva has front and rear 300zx brakes can list any shocks/struts they know that will fit also one more thing.. what about a first gen 300zx brake upgrade?? has anyone did that and is it worth while???
drifter
Drifting, cars, etc.
Southern California
7-24-2002
| Quote » | Originally posted by bj180sx rears aren't really needed. Get the hubs unless you can get a machine shop to drill the 4 lug pattern. | Thanks! You just answered my question without me asking it. :)
AIM: TehApologizer E-mail: that240guy@gmail.com
theNUDdistBUDDhist
3-1-2003
w bout 5 mo ago i talked to a jimwofl tech an he sayed u need 16 to fit the claiper on. but i also heard that it will fit on the se rimz witch are 15 in ovcourse any info ? is this right?
http://wWw.SPEEDingMoNK.cOm MoNK@SPEEDingMoNK.com I like building s hit Better to be a SMART *** than a DUMB ***
Nils
road racing
Vegas
8-28-2002
| Quote » | Originally posted by theNUDdistBUDDhist w bout 5 mo ago i talked to a jimwofl tech an he sayed u need 16 to fit the claiper on. but i also heard that it will fit on the se rimz witch are 15 in ovcourse any info ? is this right? | try to write in english.... I am pretty sure that 15" rims wont fit over the 300zx calipers. We bought a set of 16" 300zx N/A rims for my buddy which fitted nicely over his 300zx turbo calipers (front and rear). nils
Silvia2b
1995 240sx SE 2008 Acura MDX Tech
Portland
10-28-2002
What about the size and offset for the 5 lug S14 se Wheels has anybody tried, successfully?
David 95' 240 SE
Bussman240sx
Nissan cars, and women
Madsion
2-23-2003
i think you do need at least some 16's
Nissan!!
Cyberkreig
York, PA
9-1-2002
Bussman - You Stole my icon! I stole it off a guy on aim Fair and square! LoL. Now i have to go find something unique.
C-Kwik
2004 Nissan Titan LE Crew Cab, 2005 Honda CBR600 F4i
SoCal CA
8-2-2002
Depends on the wheel. There are 15" wheels that fit. in fact the Stock DOHC S13 SE wheels fit around the brakes. But there are apprently two different types of the same wheel. The are visually the same but a few have ridges behind the spokes that will not clear the caliper. But the ones without that ridge will clear. It's a tight fit, but it does fit.The 5 Lug S14 SE wheel clears with no problems. Most wheels have more problems clearing the spokes than they to the inner diameter of the wheel.
"Bad Driver's Famous Last Words: Watch This!
d240t2
Atlanta, GA
2-27-2003
The 26mm Aluminum brakes came off of 90-92 NA Z32s. The 30mm Aluminum brakes came off of 90-92 TT Z32s. After that, all Z32s had 26mm iron brakes. The S13 wheels that fit...only fit the 26mm brakes. As far as MCs go...this is a bit tricky. There are 5 different MCs on Z32s. There are 2 different size Tokico MCs (1" and 17/16"), and 3 different Nabco models (15/16", 1", and 17/16"). With minor modifications, they'll bolt up to S13s and S14s without ABS. ABS S13s, these bolt right on. Non-ABS S13s, if you just want to go to the 15/16" MC (stock is 7/8"), then you can get an 86 S12 200SX MC from autozone, rebuilt, that will bolt right on. Fitting the brakes behind wheels is more about spoke design and offset than about diameter...some 15s will fit, some 18s won't. Dennis
theNUDdistBUDDhist
3-1-2003
the s13 SEz do tho right? thx -- MoNK
Sopdadope
Boston
7-26-2002
Nils, Thanks for the well-written write-up. I've seen that bad-*** Supra of yours in Sport Compact Car, IMO it's the best looking Supra I've seen. Just wondering, I know some of the downsides to cross-drilled rotors include shorter pad life, more brake dust and supposedly, lower performance but wouldn't the weight-savings nullify that somewhat? I ask because, as of right now, I'm looking for a machine shop to fabricate some nice steel brackets to mount the Z32 calipers outboard to fit 13" Cobra rotors. Now I'm sure these outweigh the stock S13 rotors quite a bit and adding a lot of unsprung weight worries me.
My Yu-Gi-Oh cardz bring all da boyz to the yard, And i'm like - yo u wanna trade cardz? Dam right - do u wanna trade cardz? I'll trade u- but not my Charizard
Nils
road racing
Vegas
8-28-2002
| Quote » | Originally posted by Sopdadope Nils, Thanks for the well-written write-up. I've seen that bad-*** Supra of yours in Sport Compact Car, IMO it's the best looking Supra I've seen. Just wondering, I know some of the downsides to cross-drilled rotors include shorter pad life, more brake dust and supposedly, lower performance but wouldn't the weight-savings nullify that somewhat? I ask because, as of right now, I'm looking for a machine shop to fabricate some nice steel brackets to mount the Z32 calipers outboard to fit 13" Cobra rotors. Now I'm sure these outweigh the stock S13 rotors quite a bit and adding a lot of unsprung weight worries me. | Thx for the good comments =) The weight savings on the rotors wont really be that much. The chances of you cracking or warping your rotors are alot greater if you have drilled ones or even more so with custom drill stock rotors. IMO, I wouldnt do it.... I road race with solid brake discs and they work great. Most race teams that use cross drilled or slotted rotors have insanely large budgets which most of us cant hang with... they change rotors "very" often. For easy street driving I guess the odds of you cracking a drilled or slotted rotor are pretty small... on solid rotors it would be a VERY small chance =) Cross drilling and slotting is mostly for looks when it comes to street cars, only when you step in the road racing arena does it really matter. If you want to cross drill your rotors.. go ahead.... I dont see you having problems with them. BUT, if you plan on doing any sort of track events... be careful and let the rotors cool down plenty before stopping the car completely. It aint fun to warp or crack your rotors... $$$... I have done it alot in the past =) n
bj180sx
cars
Arkansas
8-25-2002
Nope the 26mm brakes were on the early 90 models only. 6/89-6/90 are the production dates. Every tt and na after that have 30mm.
cosmo
Des Moines, Iowa
10-7-2002
Does anyone know if Advan RG 15x8 will fit if I do the Brembo Z32 30mm upgrade? Or will I have to run 16x8? BTW its for an S13.
Some like torque(KA), some like high revs(SR), some prefer to save money(KA), and some just like to be JDM gay(SR)- Redline 240#5 in the Ben(n) revolution http://www.nickbiz.org/ -RIP BIZ
matt0941
Counter-Strike, Cars, Girls (in that order)
Chicago Suburbs (But currently directly behind you
11-13-2002
Where you gonna get the cash for Brembo brake upgrade? $3,000 right? Anywho.... I read around and whats the deal with this auto-zone thing, interests me: I have a 98 SE, so what am I supposed to say exactly to replace my calipers with Z32s? Hi these are my ____ calipers mr.autozone, bla bla bla, I want 30mm aluminum 300zx calipers. I don't get it.EDIT: PS Buddhist, learn how to spell or dont bother at all you are giving everyone a headache.
"The faster you drive, the less time you have to get into an accident" -Matt AIM: CaptainPlunet
cosmo
Des Moines, Iowa
10-7-2002
I'm not talking about the 13.1" GT Brembo's, I meant the Brembo Z32 30mm rotors and having them redrilled. http://www.heavythrottle.com/
bj180sx
cars
Arkansas
8-25-2002
you can just order some z32 tt calipers and pay like $86 each or when you do the switch just put your old calipers in the return box. My autozone didn't check.
matt0941
11-13-2002
Oh I see, do you just "return" the calipers that you bought from them saying you don't want them anymore but they are actually stock 240s and they don't find out... hence trading your stock calipers for 300zx ones, if thats not it please correct me. But the ones that autozone stocks for $86, are they rebuilt OEM ones for the 300zx?
bj180sx
cars
Arkansas
8-25-2002
yes rebuilt oem ones
93RPS13
Cars, Girls, Cars, Food
Boston, MA
1-1-2003
There is a very good website that covers the complete swap including the rear brakes.http://www.importnut.net/300zxbrakeswap.htm great website
Looking for a S14 Manual in New England Area...please contact me by email
ESPER
8-16-2002
could someone help clarify what "HUBS" and "SPINDLES" ARE please?? Also, if someone could help elaborate that would be great!! maybe email me or CHat or something cuz what i am thinking is Upgrade the front calipers to Z's and just bring my front s14 calipers to the back! and then what else would i have to change besides the rotors??
Dori Dori
Cars of course
WPB FL, in the shade
11-15-2002
Nevermind.
Dori Dori
Cars of course
11-15-2002
Oh yeah, if you are using the Z32 spindles...what kind of ball joint are you using on the control arm?
mav1178
Torrance, CA 90504
2-21-2003
I have some big questions with this swap.........| Quote » | | -1 set of used 1995 (any year from that generation) Nissan 300zx (no ABS) front spindles with hub. It was a direct bolt on, watch out for your dust boot covers.. be careful when swapping. | What did you bolt it up to? S14 LCA? If so, it will NOT work on S13 unless you press in new S14 ball joints on the LCA, or swap over to a S14 LCA on the S13 setup (which would make the LCA longer by about 1/2" and dial in a lot more negative camber). | Quote » | | - 1 set of rear rear hubs from a 1995 (any year from that generation) Nissan 300zx (no ABS). You can order the rear spindle assembly aswell, but, I heard that you have to customize your shock or get custom coil overs and new ball joints. I think SCC went over this and got JIC coilovers and Moog ball joints, it worked quite well. | No, what you need for rear upright swap is to run either Z32 rear shocks and Z32 rear springs (which is not the same length as S14 OR S13), or get coilovers with a removable lower shock seat and swap that with a Z32 fork-type unit. Much like this:
In the picture the shock on the left is with Z32 fork type rear lower shell casing, the 3rd one fromleft is with S13 rear bolt-type shell casing. | Quote » | | - 4 used brake rotors from a 1995 (any year from that generation) Nissan 300zx. If you have a lot of money get new ones, no need for fancy cross drilled or vent holed rotors, they just tend to crack and warp or create massive brake dust.. a regular rotor is all you need, trust me. | If you are just swapping front calipers like your post suggests, you do not need all 4 rotors. Get 2 Z32 rotor (and NOT any year, for 26mm caliper use ONLY 26mm rotors, for 30mm calipers use ONLY 30mm rotors), and 2 S14 SE rear rotors (or redrill 4 lug rotors to 514 bolt pattern). -alex
mav1178
Torrance, CA 90504
2-21-2003
And my other question is, why would you swap with Z32 front spindles when S14s only require you to swap hubs to go to a 5 lug setup?-alex
Dori Dori
Cars of course
11-15-2002
He used Z32 hubs...do you know if those bolt up to s14 spindles? If they don't, that would explain why he chose z32 spindles.And yes, I want to know too, what ball joint did you use? S14 or Z32? If you used the s14 ball joint, isn't that dangerous or is it the same as the z32 ball joint?
asad
11-12-2002
| Quote » | Originally posted by d240t2 The 26mm Aluminum brakes came off of 90-92 NA Z32s. The 30mm Aluminum brakes came off of 90-92 TT Z32s. After that, all Z32s had 26mm iron brakes. | Ahhh Dennis you should know better. The ONLY Z's with 26mm rotors were the 1990 non-turbos. ALL 90-96 twin-turbo Z's used 30mm rotors. ALL 91-96 non-turbo Z's used 30mm rotors as well. In mid-year 1992, they switched from aluminum to iron calipers. The iron calipers take 30mm rotors. http://www.princeton.edu/~asad/zbrakes/ Asad
| First 1 2 3 4 5 6 > Last |
