 vq35de in a 240sx?First  1 2 3 4 >  Last
the_ace
240sx 90
Calgary AB
11-20-2005
  vq35de in a 240sx?
hey guys,
question: is it possible to swap a vq35de from a g35 oe 350z with manual transmission into a 240sx? s13?
i know someone swapped an engine from maxima 04 into a sentra specV in calgary canada.
MinisterofDOOM
Maxima Moderator
Online
Layton UT
5-19-2004
 « Re: vq35de in a 240sx? (the_ace)
With enough time and money?
Absolutely.
It'd require a ton of custom fab. The VQ35 is a very wide engine.
-The MinisterofDOOM
|The Q of DOOM| - |The Maxima| - | Hear my Q!|
4.08 VLSD, NICO 8-way ECU, full exhaust with custom headers,
Tokico Blues with Eibach springs, Stillen FSTB, 20mm RSB, 255 rear rubber.
gepeto
1995 S14
Montreal Qc
12-20-2004
the_ace: I know some dude close to Montreal is swapping a 3.0l in his S13 (he competes in GTU so he can't have a turbo and he has to stay 3.0l and under) but with a 350z 6spd tranny..
I went go karting with another guy around who has an RB26DETT in his s14 and he's gonna help him do the swap..
He says basically the drive by wire will have to be bypassed and other things like that, also you'll need a megasquirt or a obd1 ecu or something..
I also think the shifter has an extesion on it (like a rod shifter at the end of the tranny) which will need to be shortened by a few inches..
elwesso
Super Moderator
94 Q45t NICO Track Slut
Anderson and Angola IN
2-23-2003
 « Re: (gepeto)
Personally, i would go with a VG30DETT in the S13/S14 before Id go with a VQ35.....
NICO Sponsor Directory | Infiniti Of Scottsdale, 1-888-216-5328, ask for Joe, say Wes sent you.
Need a Nissan/Infiniti Mechanic around Indy OR Northern Indiana?? EMAIL ME!!!
NICO ECU's for sale
Exar-Kun
2005 350Z
Georgia
9-27-2002
 « Re: (elwesso)
Quote, originally posted by elwesso »
Theose are easier to soruce for sure....
Not sure on the weights, but neither engine setup will be lighter than the RB26Dett..or have as much aftermrket support for serious power.
-Chet
You can live in a car, you can't drive the house.
"The essence of stupidity is doing the same thing and expecting different outcomes"
-Albert Einstein
"It is possible to store the mind with a million facts and still be entirely uneducated." Alec Bourne
2005 Daytona Blue 350Z 6 speed. NISMO Exhaust, NISMO Differential and PS cooler, JWT intake, B&M, Redline 10W30/MT90, Tomei 2 way LSD, DC headers, Comp Clutch flywheel and stage 2 setup, SPL Front upper arms, SPL rear toe link, TEIN Flex coilovers, Stoptech 355 F 328 R BBK, ARC rad panel, ARC catch can, Carbing STB, HKS DLII, ADVAN Super Racing V.2 18x9 F 18x10 R with ADVAN SPORT 255/40YR18 F 275/40YR18 R
amerikajin
s13's s14's lots of chevys and titan
riverside ca
1-9-2006
we are working on right now...vq35de in an s14.
rudedrift
240sx
buffalo ny
1-14-2006
 « re
sweet. i cant wait to read more.
cdlong
'95 240sx
Iraq
11-30-2003
 « Re: (Exar-Kun)
Quote, originally posted by Exar-Kun »
you think an iron block twin turbo charged I6 will be lighter than a NA all aluminum V6? even with the difference in displacement, i doubt it.
there are a couple of guys on freshalloy doing the swap right now.
'95 240sx, sorta stock
pics and mod list
wheels, audio, and more for sale
C-Kwik
2004 Nissan Titan LE Crew Cab, 2005 Honda CBR600 F4i
SoCal CA
8-2-2002
Turbonetics had one on display at the Z and G open house. It wasn't complate yet, but they had it mounted in the engine bay of an S14. I've been contemplating doing this myself as I'd like to do it in a manner to get it approved by a BAR referee and have a street legal near 300 HP 240sx. But time would definitely be an issue for me so I'm a bit reluctant. It will be a big project. to make it street legal, it would need to be using the drive-by-wire system and the corresponding ECU. Adapting it to the stock guages and converting the 240sx fuel system to be returnless would present a few challanges as well. I would have loved to talk to the guy at turbonetics that is working on the project, but he was a bit busy at the time.
"Bad Driver's Famous Last Words:
Watch This!
C-Kwik
SoCal CA
8-2-2002
 « Re: (cdlong)
Quote, originally posted by cdlong »
Even though it's aluminum, a V6 has a lot of material. The block itself is much wider to accomodate 2 banks of cylinders. There are 2 heads, and while both are shorter, there is still much more material used. Now I don't know the weights of either, so this isn't to say which is heavier, but a V6 is indeed heavier than an I6 of the same materials. An aluminum V6 might even be heavier than an iron I6.
cdlong
'95 240sx
Iraq
11-30-2003
 « Re: (C-Kwik)
Quote, originally posted by C-Kwik »
i don't believe that. first of all, the driveshaft is shorter. it might not save much weight, but it certainly isn't heavier. if you imagine taking an I6 block and cutting it in half and joining it on a common crank like a V engine, there will be a good ammount of material that overlaps. the V shape is naturally stiffer because of compressed nature of the layout. you can use less material because of the inherent stiffness thus making it even lighter. width doesn't make a difference, an I6 is longer, but dimensions don't change anything, just how much material is used.
V6 heads and an I6 head cut in half are virtually the same except for the extra cam gears and whatnot. the V6 parts would weigh more, but not much.
for the reasons i stated i bet a V6 and an I6 of the same material are very close in weight. however, if you take off two turbos and make the block aluminum, the VQ will certainly be lighter. the only thing the VQ has going against it is the displacement.
i'd have to see some hard numbers to really be sure though.
DanCouga
1995 Nissan 240sx
Columbus GA
3-14-2005
If anyone is thinking of trying it, now is your chance. Looks to be a very good deal.
C-Kwik
SoCal CA
8-2-2002
 « Re: (DanCouga)
Personally, I'd rather try to find a complete wrecked Z or G35 to do this with. There are a lot of electronics needed, particularly if you wanted to get by CARB certification. Plus, you may have the opportunity to test on a vehicle a little to check compatibility of some of the components. And if you happen to get a 03-04 6 speed G35 coupe or a track Z, you might be able to pull of the bremobs as well. Not sure how much salvage would go for on a car like that, but I would definitely try.
fredb
granby mo
2-24-2003
 « Re: (C-Kwik)
Did it, done it, heck still doing it as we speak.
http://www.engineswaptech.com/....aspx
allen
Attachment: vq35de2.jpg (76982 bytes, downloaded 10535 times)
VQ35DE, 6 speed, MegaSquirt II
S13 Charlie
7-28-2004
 « Re: (fredb)
WOW!!
You are a god among insects!!! All that, and a custom intake manifold too! Beautiful work bud, it looks like you really planned this swap out. And all those people who are worried about the weight of a v6, look how far back in the bay that engine sits. That is going to be one sweet ride when it's done. Are you in socal? If so, I'd love to check out your car when it's done.
cheers,
C
cesar240sx
93/240sx turbo/nitros
w.columbia sc
10-31-2005
 « Re: (fredb)
hi i am new here ,now i am doing the vq35de swap into s13.this the first time i see one into the s14,i looked into the swap of vq30de of maxima i was great. but did vq35de is harder swap cause of the ignition sys. nats ,and the vtc control..i would like to ask you FREDB,doer the exhaust cleared the steering linkage,and what type of motor mount u used,the original ka mount hit the starter.i work for nissan dealer and this what i do for living.
952FourtyEssex
95 240SX
Honolulu Hawaii
7-7-2004
Fredb got it running yet?
cesar240sx
w.columbia sc
10-31-2005
hi guys, after some research,i start doing the swap .vq35de into s13..its going to take some time ..trans in place and engine mounts done..next i am waiting for z headers hopefully will clear the steering rod w/o modifications.i dought it i think this going to be the hardest part....
hecktic one
92 Nissan 240sx
Miami Fl
3-17-2005
wow i should go on this forum more often! im also doing this swap, hey now i have some people i can relate to....
gyfer
Columbia, MO
10-14-2002
 « Re: (cdlong)
You can do google search to find out.
I6 is indeed much lighter. In design, V6 require counter-balance in crankshaft oppose to I6. The extra weight also comes from bigger head (2 of them actually), double cylinder block, timing belt/chain component, oil/water runner, wider intake & exhaust manifold, and etc.
Naturaly, Inline design also have less "vibration" compare to V design.
V design are not any stiffer, nor need less material for the engine design. Inline unique layout balance one piston to another, which does not require any balancer. Vertical and tranverse foces also completely balance by one another, which result almost zero force. However, V6 need couter rotating shaft to suppress vibration. V6 has more energy loss because it duplicates valve gears and camshafts, and use of 2 cylinder bank leads to more heat loss. (engine efficiency) Ultimately, I6 is more efficient, yet smoother.
Despite all of the cons of V6, V6 has shoter and a little wider engine. Easier to implement & fit in wide variety of cars, thus you can find VQ35DE in Altima, Maxima, 350Z, Murano, FX35, G35, Quest & lots of other Nissan. You can almost never fit a I6 for FWD.
Don't believe Inline is better ? 2004 Wards Auto annually "10 best engines" in the world, 5 out of 10 engines is Inline, including BMW 330series, and M3.
~May the Boost be with you~
0.4bar@2500rpm
Those who said "No replacement for displacement" obviously don't know anything about chemistry and physics.
the_ace
240sx 90
Calgary AB
11-20-2005
is it really worth it in the end??
300hp na
vs 320+ hp from........ maybe tt rb??
cdlong
'95 240sx
Iraq
11-30-2003
 « Re: (gyfer)
Quote, originally posted by gyfer »
i didn't say anything about better, we were talking about weight.
i know all about Wards Auto, i also know that the VQ has been on there a number of times.
you didn't really say anything to other than the vibration issue that would make much difference. until i see both of them on a scale, i won't be convinced.
fredb
granby mo
2-24-2003
 « Re: (S13 Charlie)
Quote, originally posted by S13 Charlie »
WOW!!
cheers,
C
Wow man, thanks for the compliments!
I'm still working on this project, updates can be seen at http://www.engineswaptech.com
I got it running on the MegaSquirt standalone but it's not tuned yet, still working out the bugs so to speak.
The LH exhaust manifold has to be modified to clear the shaft, it almost clears but not quite.
It's gonna be featured in SCC in a couple months, keep an eye out for that.
I'd like to invite all you guys that are attempting this swap over to my site. Please log in and post up about your project. I'm trying to get all of us together on one site so we can compare and help each other out.
thanks!
Fred
Attachment: vq35de1.jpg (80266 bytes, downloaded 10092 times)
MaxedOutR34
2-10-2004
Thats just plain awesome. I wish I had the money and time to swap in a vq35de into my s13. nice work. Keep us posted.
the_ace
240sx 90
Calgary AB
11-20-2005
 « Re: (MaxedOutR34)
great work pure genius!
also, i saw a 280z with the whole interior and mechancial bay from 350z!!
lemme try to find some pics!
the_ace
240sx 90
Calgary AB
11-20-2005
 « Re: (the_ace)
one
Attachment: 240zx.jpg (89925 bytes, downloaded 11051 times)
the_ace
240sx 90
Calgary AB
11-20-2005
 « Re: (the_ace)
two
Attachment: 240zx2.jpg (69433 bytes, downloaded 9687 times)
Nismo_Dj
97 red se kouki
orlando, fl or boston, ma
6-3-2004
 « Re: (the_ace)
Quote, originally posted by the_ace »
300hp na
--to some ppl it might not be worth it, but when it comes to originality its worth it. rb26dett swaps has been done numorous times, im sure there are onli handfuls of this kinda swap done. props to him and also yeah keep us updated, im also lookin forward to seein how this comes out. i think its more of tryin to be original than anythin else. and also u could look at this from a domestic p.o.v. is modyfyin ur 4cyl nissan/honda or any imports worth it when u could get a v8
Nismo_Dj
97 red se kouki
6-3-2004
 « Re: (fredb)
Quote, originally posted by fredb »
thanks!
Fred
hey man if u dont mind me askin how much would u say in total u will have to spend? the reason i ask is cuz im thinkin about that swap too
nismo dreaming
1997 240sx KA-T
Arlington Texas
11-22-2005
 « Re: (fredb)
OMFG!! That is one amaizing looking swap you got goin there. +1 for the s14 and +1 for the custom intake manifold. There is some real genius going into that one. Make sure to keep all of us posted on the further updates of the install. Dont forget to give us a video with that thing runnin too!!
1997 240sx se / Ka24det
fredb
granby mo
2-24-2003
 « Re: (jaytheman88)
Quote, originally posted by jaytheman88 »
Thanks for the compliments, I'm making progress but slowly! I'll keep everyone updated at my site:
Fred
Modified by fredb at 8:25 AM 6/28/2006
TT510guy
1971 Datsun 510
Beaverton Oregon
7-5-2006
 « Re: (gyfer) I6 vs V6
Please, do your homework
1) V-6 does not *require* a balance shaft - the VG and VQ engines do not have one. It depends on the angle ov the "V" (60-deg, 90-deg, etc) as well as other design goals.
2) Do the math - it takes a given amount of cylinder head to cover a given cylinder count - note that your I6 head it about um....twice as long as one of the two V6 heads (all things being equal like bore spacing, etc)
3) "V6 has more energy loss because it duplicates valve gears and camshafts, and use of 2 cylinder bank leads to more heat loss. (engine efficiency)" See #2 above - your I-6 camshaft is about 2x a long as a V6 one. I will give you partial credit on the overcall concept. Your argument *might* have more validity if you were comparing frictional losses between SOHC and DOHC since a 4v/cyl DOHC has 2x as many camves/cams as a 2v/cyl SOHC......but guess which makes more power? A 24v V6 and I6 both have 24 valves, rockers or tappets, camshaft lobes, etc.
4) "Ultimately, I6 is more efficient, yet smoother". All other things being equal, MAYBE. In today's world it is not, I will wager the aluminum VQ35DE is lighter than the iron/aluminum RB26.
FYI the VQ35DE is in the 375# range complete and the older VG30DE is roughly 425#, and continuing down the Z-car engine lineup the I6 (L28) is closer to 500# and it is "only" SOHC vs DOHC for the VG / VQ mentioned here.
Simply because one engine is an I6 will not automatically make it lighter than a V6 of comparable displacement. Conversely an all-aluminum engine is not automatically lighter than a similar-displacement iron block/alum head engine....the aluminum SR20DE is about 300# whereas the iron block CA18DE is about 270#.
The only way to know is to weigh each engine in similar configuration (accessories, manifolds, etc).
And as far as what is better - V6 or I6....the answer depends on what the design goals are. I6 is inherently smoother, but the V6 packages better. This exact thread flows through the Z-car list about once a year or so.
Dave Lum
'71 510 w/ VG30DETT
http://www.datsuns.com
cdlong
'95 240sx
Iraq
11-30-2003
thanks for the backup. welcome to NICO. you are required to post pics and info on your car.
fredb
granby mo
2-24-2003
 « Re: (gyfer) I6 vs V6 (TT510guy)
TT510guy,
Thanks for chiming in, I saw your page quit some time ago and was blown away at the quality of the job. This was a while before I had the nerve to dive into my project and yours was really an inspiration to me.
Any updates on the 510?
Fred
irax
VQ35DER Powered S14.3
San Diego CA
1-5-2004
 « Re: (fredb)
when is this bad boy going to see some dyno time? i wanna see what kind of power it puts out
Latka
2004 G35 Sedan, 1966 Austin Mini Cooper S, hopefully a Hakosuka soon
Kaneohe HI
7-12-2006
 « Re: (irax)
Wow. Double Wow. Whoa!
That's some impressive work. I'm a little under the Jägermeister right now, so I'm not sure if it was posted how much work it was.... but man that's cool!
Later this year I'm going to be picking up a '69 - 72 Skyline. The popular swap seems to be to go from the L20 I6 to the L28...but holy crap, according to the weight listed here it's like 500lbs!!!
We've got the VQ35 in our G35 Sedan and absolutely love it. I wonder how much of a crazy-*** project it would be to stuff it in the Hakosuka...
irax
San Diego CA
1-5-2004
 « Re: (Latka)
if that engine bay is anything like the Z then theres alot of room, and it should be as simple as new motor mounts, drive shaft, and wireing. but i could be wrong.
JasonH
1992 Nissan 240SX coupe
Statesboro Georgia
8-22-2006
 « Re: (fredb)
Hey Fred... The car is looking great... I have a '92 240SX coupe and I am serious about doing the swap. I did see the article in SCC and have read it over and over again.
Just wondering where you are with your car and what you are your plans for guages and other necessary guages? I have also been to your website and have been studying the pictures and your posts. Can't wait to hear about the latest...
JasonH.
Georgia
fredb
granby mo
2-24-2003
 « Re: (JasonH)
Hey man,
It's coming along but slowly right now, I've got another car to finish up then I'll be back hard at it, it's sooooo close to drivable, just need a few hours to work on it.
Fred
Nealoc
95 Maxima
Kalamazoo MI
8-28-2006
 « REAL engine weights
Sorry, but some of you guys are WAYYY off with regards to the engine weight info being posted here:
KA - 368lbs (unknown if that is short, long, or fully dressed) - posted by UKnissan
RB20 - 476.8lbs YoMani (or something like that, he's on nico) weighed it himself
RB25DET - 720lbs - sport compact car magazine Sept 2003
RB26 unknown to me but estimates range from 550-700lbs from what I just read, I GUARANTEE it is a sh!tload heavier than these weights:
VQ35 - 260lbs longblock, no intake manifold - weighed by JClaw, lifted by himself onto bathroom scale
VQ30 Shortblock - 127lbs weighed by JClaw on his bathroom scale - including rotating assembly, no heads, no timing cover, and of course no intake manifold.
VQ30 long block - 246lbs weighed by ME at aluminum recycling facility. No intake manifold, obviously including rotating assembly, block, heads, timing equipment.
VQ30 long block (different one than above) 315lbs - lifted by my buddy and I onto bathroom scale at my buddy's house with no problems whatsoever.
VQ35 long block component pieces weighed on shipping scale by eng92 - 277lbs - block, heads, rotating assembly.
VQ35 long block including intake manifold, no accessories - 313lbs weighed on a recently calibrated auditing scale with supposedly accurate to within +/- 0.5lbs
CREDIT GOES TO eng92 FOR THESE PICTURES
VQ35
http://img.photobucket.com/alb...1.jpg
VQ30 long block, undressed - 338lbs
VQ30
http://img.photobucket.com/alb...4.jpg
So, yeah... if you guys would stop saying the RB is lighter than the VQ that would be greaaaaaaat... mmmmkay? It's not even within the same realm, let alone"lighter than the VQ" lol it's at least 2x heavier.
Obviously some of the scales above are out of calibration (bathroom scales always try to make you feel good about yourself lol), but you get the basic idea. VQ35 is somewhere between 270 and 310ish lbs, VQ30 is somewhere between 270 and 330ish lbs (I don't trust the 246lbs that the aluminum recycler gave me as being completely accurate, because they pay you based on weight, and of course they'd like to pay out as little as possible. so their scale probably reads light which coincides with the numbers that other people got.) They say (nissan says) that the VQ35 is about 35lbs lighter than the VQ30 was which is exactly what eng92's weights on the same scale, on the same day, indicate.
Anyhow - to the topic at hand... There are a number of guys (I can think of 4 off the top of my head) on maxima.org who are putting or have put VQs into S13s and S14s. I don't know where else those guys post but their names on maxima.org are broaner, JClaw, eng92, and of course Fred Allen Burge who posted above, if you want to search for their posts. broaner is done and drives the car, eng92 i believe is done and drives the car (he doesn't post all that much) and JClaw is 90% and should be driving the car within a week or so it seems, fred's posts speak for themselves.
Modified by Nealoc at 8:50 AM 8/29/2006
95 Maxima - unnaturally aspirated
12.18 @ 120.3mph
R.I.P.
96 Maxima naturally aspirated
13.43 @ 102.3mph
» Return to VQ30DE / VQ35DE / VQ35HR Forum
