Rex
1995 SC400 Red/Black 1993 Maxima Black/Tan
Cincinnati OH
4-5-2003
Are the injector top feed or side and are the low or high resistance, maybe even add the actual ohms??Great thread idea BTW.
For Sale: Forged BBS 18x9 Rex - Not THAT Rex ____ Teh Coupe Killaz #0 Tutorial for pics/avatars Donate To NICO: PayPal acct 'advertise@nicoclub.com' The 3 R's - Read/Research/Reply
elwesso
Super Moderator
Anderson and Angola IN
2-23-2003
| « Re: (Rex) | 2:04 PM 10/5/2005 |
Low resistance and side feed, 12-14ohms is the spec.
Raxephon
'04 RX8
Fl
7-27-2004
| « Re: The ultimate VH45DE FAQ (elwesso) | 3:21 AM 10/6/2005 |
1991-1994: 8 individual cast aluminum intake manifolds, each feeding into dual ports. Each manifold has a cylinder number cast on one side which faces towards the valvecover when installed.Intake manifold #8 also retains a side bracket that houses one of the fuel pressure regulators Intake manifold to cylinder head bolts are 12mm, 2 per manifold (Length & thread pitch?) Intake to Cylinder Head gasket is metal (Thickness?)
Modified by anlasak at 2:51 PM 10/6/2005
elwesso
Super Moderator
2-23-2003
| « Re: The ultimate VH45DE FAQ (anlasak) | 9:52 AM 10/6/2005 |
They changed it in 94 to a single opening instead of the 2 openings.
Raxephon
'04 RX8
Fl
7-27-2004
| « Re: The ultimate VH45DE FAQ (elwesso) | 11:50 AM 10/6/2005 |
Didn't they also swap the 8 manifolds out for a single intake manifold somewhere along the line?
elwesso
Super Moderator
2-23-2003
| « Re: The ultimate VH45DE FAQ (anlasak) | 1:52 PM 10/6/2005 |
Not in the VH45, in the VH41 maybe.
PoorManQ45
FL
7-2-2004
good thread idea.Can we get some internal specifications? Like clearances/tolerances
"When seconds count between life and death, the Police are only Minutes away." - Phillip Van Cleaves (October 30, 2007) Freedoms lost are seldom restored. "A government big enough to give you everything you want, is big enough to take away everything you have" Thomas Jefferson "Laws that forbid the carrying of arms . . . disarm only those who are neither inclined nor determined to commit crimes . . . Such laws make things worse for the assaulted and better for the assailants; they serve rather to encourage than to prevent homicides, for an unarmed man may be attacked with greater confidence than an armed man." Cesare Beccaria, 1767 (Later quoted by Thomas Jefferson)
elwesso
Super Moderator
2-23-2003
| « Re: (PoorManQ45) | 8:07 AM 10/7/2005 |
Sure let me post up some of those later.....
Raxephon
'04 RX8
Fl
7-27-2004
| « Re: (elwesso) | 9:49 PM 10/19/2005 |
http://forums.nicoclub.com/zerothread?id=1403101991 Q45 Timing Chain Links/Pins (May cover other years as well)
elwesso
Super Moderator
2-23-2003
| « Re: (anlasak) | 9:08 AM 10/20/2005 |
thanks buddy!!! good info
Raxephon
'04 RX8
Fl
7-27-2004
| « Re: The ultimate VH45DE FAQ (elwesso) | 4:06 PM 11/11/2005 |
I noticed this thread has fallen a little behind. So, How much boost do you think the stock internals can handle if temperature is not a factor?
elwesso
Super Moderator
2-23-2003
| « Re: The ultimate VH45DE FAQ (anlasak) | 4:11 PM 11/11/2005 |
All i can say is that Slim is running about 10lbs, and it has PROVEN to be reliable. he drove it for over 2 hours each way to come to NOPI..... took it on a large drifting session earlier this week and its all good... He has stock internals AND a stock ECU with only the JWT Boost ECU!SO much torque on this that people say they can see the chassis flexing!
qsiguy
1994 Infiniti Q45 Turbo
Phoenix AZ
3-20-2005
I don't want to get off subject but who is this "Slim" that has a boosted Q? I'd like to get the specs and details on what he's done.
elwesso
Super Moderator
2-23-2003
| « Re: (qsiguy) | 8:18 PM 11/11/2005 |
He has a boosted VH45DE in a 93 nissan 300ZX
erbe
300zx, Q45
Bergen, Norway
11-2-2005
| « Re: The ultimate VH45DE FAQ (elwesso) | 9:18 AM 11/12/2005 |
| Quote, originally posted by elwesso » | | All i can say is that Slim is running about 10lbs, and it has PROVEN to be reliable. he drove it for over 2 hours each way to come to NOPI..... took it on a large drifting session earlier this week and its all good... He has stock internals AND a stock ECU with only the JWT Boost ECU! SO much torque on this that people say they can see the chassis flexing! |
10lbs???
http://300zx.kwn.no/300ZX.mpg (Right click, save as)New and improved: http://300zx.kwn.no/drift_300zx.wmv
elwesso
Super Moderator
2-23-2003
| « Re: The ultimate VH45DE FAQ (erbe) | 9:19 AM 11/12/2005 |
| Quote, originally posted by erbe » | | 10lbs??? |
erbe
300zx, Q45
Bergen, Norway
11-2-2005
How can I convert that to metric? Do you meen 10 psi?
elwesso
Super Moderator
2-23-2003
| « Re: (erbe) | 9:27 AM 11/12/2005 |
Yeah 10lbs.. as in .68bar.
PoorManQ45
FL
7-2-2004
| « Re: (elwesso) | 11:49 AM 11/12/2005 |
| Quote, originally posted by elwesso » | | Yeah 10lbs.. as in .68bar. |
Wow, he's injecting a vacuum into his engine! Actually it'd be 1.68bar wes. 1 bar equals outside pressure. You're thinking of a pressure guage, not a barometer
elwesso
Super Moderator
2-23-2003
| « Re: (PoorManQ45) | 1:50 PM 11/12/2005 |
whatever.. its 10 PSI, anyone who doesnt understand that needs to..... well.. nevermind.
qsiguy
Phoenix AZ
3-20-2005
Actually elwesso is correct 10PSI equals .6894757 bar to be exact. 1.68 bar is 24.36634 PSI, that would be a lot of boost!
PoorManQ45
FL
7-2-2004
| « Re: (qsiguy) | 3:33 PM 11/12/2005 |
| Quote, originally posted by qsiguy » | | Actually elwesso is correct 10PSI equals .6894757 bar to be exact. 1.68 bar is 24.36634 PSI, that would be a lot of boost! |
Well, considering that at sea level 1 bar is atmospheric pressure. anything under one bar is lower then atmospheric pressure, which by definition is a vacuum. A "boost guage" is actually a pressure guage, not a barometer. When it says 0, it's 0 above atmospheric pressure. Whereas a barometer starts out at 14.7PSI, which is equal to one bar. So depending on how you look at it, we're both right, BUT sinse he said the word "bar" that implies barometer *edit* You guys are confusing a pressure guage with a barometer 24.36634psi - 10psi = 14.3psi, close to atmospheric
Raxephon
'04 RX8
Fl
7-27-2004
| « Re: (erbe) | 3:51 PM 11/12/2005 |
1 pound per square inch = 0.07031 kilo per square centimeter (1 kilo per square centimeter = 14.22282 pounds per square inch )So it would be .70 ksc = 10 psi = .69 bar
elwesso
Super Moderator
2-23-2003
| « Re: (anlasak) | 4:14 PM 11/12/2005 |
A-HA! I knew I was right.....And the legend lives on! Wes>PMQ
Raxephon
'04 RX8
Fl
7-27-2004
| « Re: (anlasak) | 7:20 PM 11/12/2005 |
psig = Pounds per Square Inch (Gauge) - (10) psia = Pounds per Square Inch (Absolute) - (24.7)psia = psig + atmospheric pressure @ sea level (14.7psi) I know Wes meant psig , which is what I wanted to know. But since this is supposed to be THE ULTIMATE FAQ on the VH45DE, I should have spelled it out more clearly.
Raxephon
'04 RX8
Fl
7-27-2004
| « Re: The ultimate VH45DE FAQ (elwesso) | 7:52 PM 11/12/2005 |
'91 VH45DE cam tower bolts require a T-30 Torx bit.(Clean out each bolt Prior to attempting removal !!) I didn't get 1 completely clean & stripped out the bolt.
UK-SRi
P10 SRi
9-21-2005
I thought that boost was usually specified as guage pressure as opposed to absolute.Mike
Raxephon
'04 RX8
Fl
7-27-2004
| « Re: (UK-SRi) | 12:16 PM 11/13/2005 |
| Quote, originally posted by UK-SRi » | | I thought that boost was usually specified as guage pressure as opposed to absolute. Mike | . It is.
elwesso
Super Moderator
2-23-2003
| « Re: (anlasak) | 12:48 PM 11/13/2005 |
OK since no one wanted to do this, I decided id go for it......  VH45DE camshaft angles Nitrous and VH45DE More camshaft information A chain guide thread but lots of good information Supercharged VH45DE in a skyline VH45DE in a 240 More power related info
elwesso
Super Moderator
2-23-2003
| « Re: (elwesso) | 12:55 PM 11/13/2005 |
Forged pistonsAssorted good information VH45 in a skyline Nitrous and VH45DE More
Raxephon
'04 RX8
Fl
7-27-2004
| « Re: (elwesso) | 12:57 PM 11/13/2005 |
All the pics on page 1 are red X's
elwesso
Super Moderator
2-23-2003
| « Re: (anlasak) | 1:50 PM 11/13/2005 |
http://www.teamkrazy.com/members/johnv8/index.htm
Raxephon
'04 RX8
Fl
7-27-2004
| « Re: (elwesso) | 3:19 PM 11/14/2005 |
Thats an interesting link. He went the opposite way my father was suggesting, (ie,.. RB series motor in my Q45) Any detailed threads involving the hydraulic lash adjusters? (I searched & came up with no results)
elwesso
Super Moderator
2-23-2003
| « Re: (anlasak) | 3:37 PM 11/14/2005 |
| Quote, originally posted by anlasak » | | Thats an interesting link. He went the opposite way my father was suggesting, (ie,.. RB series motor in my Q45) Any detailed threads involving the hydraulic lash adjusters? (I searched & came up with no results) |
The question remains... Why woudl you put an RB in the Q? that seems pretty stupid to me... UNLESS of COURSE you were talking with the ATESSA...
Raxephon
'04 RX8
Fl
7-27-2004
| « Re: (elwesso) | 4:07 PM 11/14/2005 |
| Quote, originally posted by elwesso » | UNLESS of COURSE you were talking with the ATESSA...  |
I was
But I didn't want to have to scrounge around for the rear end sensors/wiring/etc, that would've been needed to make it work properly. Not to mention the other little things here & there. Also if something goes bad on my VH45DE I can find it online or at a local junkyard. I haven't seen an RB series motors in any junkyards lately. Besides, I'm happy with my VH45DE.
elwesso
Super Moderator
2-23-2003
| « Re: (anlasak) | 4:10 PM 11/14/2005 |
Ive always thought it would be cool to make an AWD Q.. relaly that would be the only reason I would put the RB motor in the Q.. If oyu were sticking with RWD, pretty stupid to go to an RB.
Raxephon
'04 RX8
Fl
7-27-2004
| « Re: (elwesso) | 2:26 AM 11/15/2005 |
| Quote, originally posted by elwesso » | | Ive always thought it would be cool to make an AWD Q.. relaly that would be the only reason I would put the RB motor in the Q.. If oyu were sticking with RWD, pretty stupid to go to an RB. |
I like the idea of an AWD Q45 as well, but only if its a manual & I have one.
I wouldn't consider dropping in an RB series motor to be "stupid", merely impractical. Stupid would be dropping in a SR20DE ( I wouldn't mind a 6-speed Gertrag though ) *EDIT* *Corrections made, see below*
Modified by anlasak at 9:38 PM 11/18/2005
PoorManQ45
FL
7-2-2004
| « Re: (elwesso) | 7:19 AM 11/15/2005 |
| Quote, originally posted by elwesso » | | If oyu were sticking with RWD, pretty stupid to go to an RB. |
Nah, it makes perfect sense. Even though replacement parts are harder to find, it's still cheaper to maintain an Mod an RB then it is to do the same to a VH45.THe RB can make plenty of torque if that's what you're "worried" about
elwesso
Super Moderator
2-23-2003
| « Re: (PoorManQ45) | 8:10 AM 11/15/2005 |
| Quote, originally posted by PoorManQ45 » | | Nah, it makes perfect sense. Even though replacement parts are harder to find, it's still cheaper to maintain an Mod an RB then it is to do the same to a VH45. |
Depends who you talk to!!
| First 1 2 3 > Last |
