Service Engine Soon Light
StockMuffinSE
Car: 2002 Nissan Maxima SE 6-Speed
A couple of days ago my service engine soon light came on, and i noticed that there was no check engine light in the dash (or i missed it). Is the service engine soon light actually the check engine light??? Or it is just a light set on a timer to get your car fixed at regular times? I have an 02 maxima se if this helps anybody. I Appreciate the help guys!
maxhopper
Car: 02 Maxima SE 6spd
StockMuffinSE wrote:Is the service engine soon light actually the check engine light???
Yes. Here is how you can pull the code(s) yourself if you need to. Please post if you have any problems when performing this procedure. I do not know for sure that this procedure works. See post #9 for more information.
Make sure engine is off, and gas pedal is completely released.Turn the key to the “Ignition” position (but do not engage the starter), and wait 3 secondsPress the gas pedal all the way to the floor, then release completely - Repeat this process 5 times in 5 seconds.Wait 7 seconds, then press the gas pedal all the way to the floor, and hold for 10 seconds.When the SES light begins flashing, release the gas pedal.At this point the SES light will blink a 4 digit code (0 = 10 flashes), pausing briefly between digits, and pausing slightly longer between codes. Any stored codes will continue to repeat themselves.Once you have written down all the stored codes proceed to clear the computer.Press and hold the gas pedal all the way to the floor for more that 10 seconds.When the SES light starts flashing again release the gas pedal.The SES light should flash 10 times, pause, 10 times, pause, 10 times, pause, and 10 times.Turn the key to the “Off” positionWait 3 seconds, and start the car.
maxhopper
Here is a list of what the codes mean:
P0011 - IVT Control (Bank 1)P0021 - IVT Control (Bank 2)P0031 - Heated Oxygen Sensor 1 Heater Low Voltage (Bank 1)P0032 - Heated Oxygen Sensor 1 Heater Low Voltage (Bank 2)P0037 - Heated Oxygen Sensor 2 Heater Low Voltage (Bank 1)P0038 - Heated Oxygen Sensor 2 Heater Low Voltage (Bank 2)P0051 - Heated Oxygen Sensor 1 Heater High Voltage (Bank 1)P0052 - Heated Oxygen Sensor 1 Heater High Voltage (Bank 2)P0057 - Heated Oxygen Sensor 2 Heater High Voltage (Bank 1)P0058 - Heated Oxygen Sensor 2 Heater High Voltage (Bank 2)P0100 - Mass Air Flow SensorP0101 - Mass Air Flow Sensor Circuit Range / Performance ProblemP0102 - Mass Air Flow Sensor Circuit Low InputP0103 - Mass Air Flow Sensor Circuit High InputP0105 - Absolute Pressure SensorP0107 - Absolute Pressure Sensor Circuit Low InputP0108 - Absolute Pressure Sensor High InputP0110 - Intake Air Temperature SensorP0112 - Intake Air Temperature Sensor Circuit Low InputP0113 - Intake Air Temperature Sensor Circuit High InputP0115 - Engine Coolant Temperature Sensor CircuitP0117 - Engine Coolant Temperature Sensor Circuit Low InputP0118 - Engine Coolant Temperature Sensor Circuit High InputP0120 - Throttle Position SensorP0122 - Throttle Position Sensor 2 Circuit Low InputP0123 - Throttle Position Sensor 2 Circuit High InputP0125 - Insufficient Engine Coolant Temperature For Closed Loop Fuel ControlP0127 - Intake Air Temperature Too HighP0128 - Thermostat MalfunctionP0130 - Front O2 Sensor Circuit (Bank 1)P0131 - Front O2 Sensor (Lean) (Bank 1)P0132 - Heated Oxygen Sensor 1 Circuit High Voltage (Bank 1)P0133 - Heated Oxygen Sensor 1 Circuit Slow Response (Bank 1)P0134 - (2000-2001) Front O2 Sensor High Input (Bank 1)P0134 - (2002-2003) Heated Oxygen Sensor 1 Circuit No Activity Detected (Bank 1)P0135 - Front O2 Sensor Heater (Bank 1)P0137 - Rear O2 Sensor Low Input (Bank 1)P0138 - Heated Oxygen Sensor 2 Circuit High Voltage (Bank 1)P0139 - Heated Oxygen Sensor 2 Circuit Slow Response (Bank 1)P0140 - Rear O2 Sensor High Input (Bank 1)P0141 - Rear O2 Sensor Heater (Bank 1)P0150 - Front O2 Sensor Circuit (Bank 2)P0151 - Front O2 Sensor (Lean) (Bank 2)P0152 - Heated Oxygen Sensor 1 Circuit High Voltage (Bank 2)P0153 - Heated Oxygen Sensor 1 Circuit Slow Response (Bank 2)P0154 - (2000-2001) Front O2 Sensor High Input (Bank 2)P0154 - (2002-2003) Heated Oxygen Sensor 1 Circuit No Activity Detected (Bank 2)P0155 - Front O2 Sensor Heater (Bank 2)P0157 - Rear O2 Sensor Low Input (Bank 2)P0158 - Heated Oxygen Sensor 2 Circuit High Voltage (Bank 2)P0159 - Heated Oxygen Sensor 2 Circuit Slow Response (Bank 2)P0160 - Rear O2 Sensor High Input (Bank 2)P0161 - Rear O2 Sensor Heater (Bank 2)P0171 - Fuel Injection System Too Lean (Bank 1)P0172 - Fuel Injection System Too Rich (Bank 1)P0174 - Fuel Injection System Too Lean (Bank 2)P0175 - Fuel Injection System Too Rich (Bank 2)P0180 - Fuel Tank Temperature SensorP0181 - Fuel Tank Temperature Sensor Circuit Range / PerformanceP0182 - Fuel Tank Temperature Sensor Low InputP0183 - Fuel Tank Temperature Sensor High InputP0217 - Coolant Over Temperature Enrichment ProtectionP0221 - Throttle Position Sensor Circuit Range / Performance ProblemP0222 - Throttle Position Sensor 1 Circuit Low InputP0223 - Throttle Position Sensor 1 Circuit High InputP0226 - Accelerator Pedal Position Sensor Circuit Range / Performance ProblemP0227 - Accelerator Pedal Position Sensor 1 Circuit Low InputP0228 - Accelerator Pedal Position Sensor 1 Circuit High InputP0300 - Multiple Cylinder Misfire DetectedP0301 - Cylinder 1 Misfired DetectedP0302 - Cylinder 2 Misfired DetectedP0303 - Cylinder 3 Misfired DetectedP0304 - Cylinder 4 Misfired DetectedP0305 - Cylinder 5 Misfired DetectedP0306 - Cylinder 6 Misfired DetectedP0325 - Knock SensorP0327 - Knock Sensor Circuit Low InputP0328 - Knock Sensor Circuit High InputP0335 - Crankshaft Position Sensor CircuitP0340 - Camshaft Position Sensor (Phase) Circuit (Bank 1)P0345 - Camshaft Position Sensor (Phase) Circuit (Bank 2)P0400 - EGR Function (Close)P0403 - EGR Volume Control Valve CircuitP0420 - Catalyst System Efficiency Below Threshold (Bank 1)P0430 - Catalyst System Efficiency Below Threshold (Bank 2)P0440 - EVAP Control System Small LeakP0441 - EVAP Control System Incorrect Purge FlowP0442 - EVAP Control System Small Leak Detected (Negative Pressure)P0443 - EVAP Canister Purge Volume Control Solenoid Valve CircuitP0444 - EVAP Canister Purge Volume Control Solenoid Valve Circuit OpenP0445 - EVAP Canister Purge Volume Control Solenoid Valve Circuit ShortedP0446 - EVAP Canister Vent Control Valve CircuitP0447 - EVAP Canister Vent Control Valve Circuit OpenP0450 - EVAP Control System Pressure SensorP0452 - EVAP Control System Pressure Sensor Low InputP0453 - EVAP Control System Pressure Sensor High InputP0455 - EVAP Control System Gross LeakP0456 - EVAP Emission Control System Very Small Leak (Negative Pressure Check)P0460 - Fuel Level Sensor Circuit NoiseP0461 - Fuel Level Sensor Circuit Range / PerformanceP0462 - Fuel Level Sensor Circuit Low InputP0463 - Fuel Level Sensor Circuit High InputP0464 - Fuel Level Sensor CircuitP0500 - Vehicle Speed SensorP0505 - Idle Air Control Valve / Auxiliary Air Control ValveP0506 - Idle Speed Control System RPM Lower Than ExpectedP0507 - Idle Speed Control System RPM Higher Than ExpectedP0510 - Closed Throttle Position SwitchP0550 - Power Steering Pressure Sensor CircuitP0600 - A/T Communication LineP0605 - Engine Control Module (ECM)P0650 - Malfunction Indicator (MIL) Control CircuitP1065 - ECM Power Supply CircuitP1102 - Mass Air Flow Sensor Circuit Range / Performance ProblemP1121 - Electric Throttle Control ActuatorP1121 - ABS / TCS Control Unit PerformanceP1122 - Electric Throttle Control Performance ProblemP1124 - Throttle Control Motor Relay Circuit ShortP1126 - (2000-2001) Thermostat FunctionP1126 - (2002-2003) Throttle Control Motor Relay Circuit OpenP1128 - Throttle Control Motor Relay Circuit ShortP1130 - Swirl Control Valve Control Solenoid ValveP1143 - Heated Oxygen Sensor 1 Lean Shift Monitoring (Bank 1)P1144 - Heated Oxygen Sensor 1 Rich Shift Monitoring (Bank 1)P1146 - Heated Oxygen Sensor 2 Minimum Voltage Monitoring (Bank 1)P1147 - Heated Oxygen Sensor 2 Maximum Voltage Monitoring (Bank 1)P1148 - Closed Loop Control (Bank 1)P1163 - Heated Oxygen Sensor 1 Lean Shift Monitoring (Bank 2)P1164 - Heated Oxygen Sensor 1 Rich Shift Monitoring (Bank 2)P1165 - Swirl Control Valve Control Vacuum Check SwitchP1166 - Heated Oxygen Sensor 2 Minimum Voltage Monitoring (Bank 2)P1167 - Heated Oxygen Sensor 2 Maximum Voltage Monitoring (Bank 2)P1168 - Closed Loop Control (Bank 2)P1211 - ABS/TCS Control UnitP1212 - ABS / TCS Communication LineP1217 - Engine Over TemperatureP1223 - Throttle Position Sensor 2 Circuit Low InputP1224 - Throttle Position Sensor 2 Circuit High InputP1225 - Closed Throttle Position Learning Performance ProblemP1226 - Closed Throttle Position Learning Performance ProblemP1227 - Accelerator Pedal Position Sensor 2 Circuit Low InputP1228 - Accelerator Pedal Position Sensor 2 Circuit High InputP1229 - Sensor Power Supply Circuit ShortP1320 - Ignition SignalP1335 - Crankshaft Position Sensor (REF)P1336 - Crankshaft Position Sensor (POS) (COG)P1401 - EGR Temperature SensorP1402 - EGR Function (Open)P1440 - EVAP Control System Small LeakP1444 - EVAP Canister Purge Volume Control Solenoid ValveP1446 - EVAP Canister Vent Control Valve ClosedP1447 - EVAP Emission Control System Purge Flow MonitoringP1448 - EVAP Canister Vent Control Valve OpenP1456 - EVAP Emission Control System Very Small Leak (Positive Pressure Check)P1464 - Fuel Level Sensor Circuit Ground SignalP1490 - Vacuum Cut Valve Bypass Valve CircuitP1491 - Vacuum Cut Valve Bypass Valve CircuitP1564 - Automatic Speed Control Device Steering SwitchP1572 - Automatic Speed Control Device Brake SwitchP1574 - Automatic Speed Control Device Vehicle Speed SensorP1605 - A/T Diagnosis Communication LineP1706 - Park / Neutral Position SwitchP1800 - VIAS Control Solenoid Valve Circuit OpenP1805 - Brake SwitchP2122 - Accelerator Pedal Position Sensor 1 Circuit Low InputP2123 - Accelerator Pedal Position Sensor 1 Circuit High InputP2127 - Accelerator Pedal Position Sensor 2 Circuit Low InputP2128 - Accelerator Pedal Position Sensor 2 Circuit High InputP2135 - Throttle Position Sensor Circuit Range / Performance ProblemP2138 - Accelerator Pedal Position Sensor Circuit Range / Performance ProblemU1000 - CAN Communication LineU1001 - CAN Communication Line
audtatious
Scott, why don't you start a new stickie with all the codes. Then, we can add posts on how to resolve codes as we run across them. Eventually, the stickie would contain all the fixes.
maxhopper
Added links to the new threads in this thread. We can edit links to each gen page code as things come up.
audtatious
Sounds like a winner. I know there is some answers on here already, so I will have to track those down and post them when I have the opportunity.
NISTECH
Scott where in the hell did you come up with that procedure? I know thats not in the service manual. This is the second time I have seen that procedure but havnt heard of it being succesfully used.
maxhopper
Compiled from information on two other sites.
Edit: I've got a 5th gen owner coming to check the procedure.
Fezzik
Car: 2010 G37 Vert w/ stage 1 GTM supercharger
I have not actually pulled any codes that way. i've reset my ecu this way a lot of time. I am fairly sure at one point of this cylce you can get the codes. I've seen it blink in a fashion like i've gotten codes before.
Turn ignition switch on and wait about 3 seconds. Repeat the following steps (2a and 2b) procedures quickly five times within 5 seconds.2a. Fully depress the accelerator pedal (HARD).2b. Fully release the accelerator pedal.3. Wait 7 seconds, fully depress the accelerator pedal and keep it for approx. 10 seconds until the CEL starts blinking. (here is where i think you can get a code from this.)4. Fully release the accelerator pedal (while the CEL is still blinking)5. Wait about 10 second.6. Fully depress the accelerator pedal and keep it for more than 10 seconds.7. Fully release the accelerator pedal (The CEL light will continue to blink).8. Turn ignition switch to “OFF” position and now you can start the car. The CEL light should be gone.
Hope this helps.
rick_the_mick
Car: 1994 J-30
Hey folks,
Does this work for a 94 J-30, which is an OBD-I vehicle?
Thanks,
Rick
maxhopper
No.
rkbaker
I can confirm this works on a 2003 maxima as well. Thanks for the tip.
r
03i35
Car: 2003 Infinity i35 (winter pkg)
i tried the first set of instructions with my 03 infiniti i35, 65k miles. repeated times and nothing showed up on my dash. no blinking or anything. im doing this b/c i was driving on the bqe(nyc) and luckily i didnt merge too much to the left b/c the car just died on me, all the lights came up on my dash and the car was doing about 50 went it did this. i eased on the ebrake and came to a stop finally. i was towed to a yard, then the car started up and then died on me again about 10 blocks later. the starter cranks the engine but it seems that something with the combustion portion of the car is not working, so im thinking either somewhere before the throttle body, the plugs, or my injectors. i read a post around page 11 saying that it was the alternator but the alternator has nothing to do with the initial start up of the car. its only for a recharging of the battery. so help me guys i really dont want to take it to Infiniti of raping pee holes. email me at [email protected] so i can answer u in a timely fashion.
03i35
hey guys me again 03I35, my car shut off on the highway, and after soo many individual wrong advice, i decided to tackle this one solo. i purchased a diagnostic scanning tool on ebay $120IMG]http://i185.photobucket.com/albums/x111 ... 07_001.jpg[/IMG], and i localized my problem. P0340 CAMSHAFT POSITION SENSOR (bank 1)-closest to the intake. I purchased the CAMSHAFT POSITION SENSOR from INFINITI of Manhattan for about $93. I removed the entire intake assembly (10mm) to clear the way for the sensor. Also removed the entire wiring harness from the sensor back to a blue colored plug on the upper left side of the engine next to the intake manifold. Its a ***** to separate the green bracket from the sensor itself. I took it to a local mechanic and he did it in 2seconds. You hold the sensor and green part in oposing hands, push the tab on the green in and separate. i think this requires some up/down toggle play. i replaced, put all back together and plugged the diagnostic scanner back into the car erased the code and test drove it for 15min. tom im going to try a real test on the highway. oh man i wish i hope i did it right. pictures are in sequential order of the aforementioned [email protected] for support and comments.
Modified by 03i35 at 6:00 PM 6/14/2007
Usuck!
Car: 01 Maxima 20th anniv.
ive tryed this 2 seperate times and it never works, i will do it exactly how u said and cant get the SES light to flash, am i doing it wrong on something?
maxhopper
Try this one instead of the procedure in the first post.
Fezzik wrote:I have not actually pulled any codes that way. i've reset my ecu this way a lot of time. I am fairly sure at one point of this cylce you can get the codes. I've seen it blink in a fashion like i've gotten codes before.
Hope this helps.
Usuck!
maxhopper97 wrote:Try this one instead of the procedure in the first post.
i tryed that one as well and still samething
p.harris
Car: 2003 Maxima GLE 40,000 miles and in mint condition
Hello Scott and everyone. I am new here, first timer, name is Peter and I am in Coventry, Rhode Island. I have a 2003 Maxima with 40,000 miles, bought it new, no real problems. Had to replace the rear brakes and rotors at 24,000 miles and just did the front brakes and a new set of tires.Had all the routine maintenance done on this Maxima dnd it is still Cherry, The wife's chariot.Now the Service Engine Soon light came on about a week ago. Car still runs like a champ, new air filter, cabin air filter, oil & filter change, and light is still on. I tried the "step on the accelerator pedal" procedure several times with no results: No Blinking, no codes, etc; light just stays on. I took one royal screwing from the local Nissan dealer and the "factory rep or Customer Service Rep as she preferred to be called) over the first brake problem and do not want to take it to them for another fleecing. Can you or does anyone else have any suggestions to help me out. Sure would appreciate it. Thanks,
brianw
Car: 4-doors, 5-speeds...
Your local autozone, Kragen, Napa, Checker, whoever should be able to pull the code for you.
triplet
Car: 2004 Maxima SE
Sorry for maybe dumb question, but I just got a used 2004 maxima seAnd The service engine soon light popped up. But It popped up when the fuel was low and low fuel indicator was on as well. I immediately filled up, but the service engine soon light is still one. Is that normal? When fuel is low, does the service engine light supposed to come on. Or maybe i would have to check for codes? Will the method stated above work for a 2004 as well?Thanks
NutriaforBreakfast
Car: Nissan Maxima 1995 VQDE engine
Get a code reader ASAP
$59 for an orange Actron one on the internet displayed in Chiltons
Want a reader and one that clears codes
Worth every dime-forget the flashing lights
rlguarig
Car: 1999 Infiniti I30
Hi Folks. My name's Ralph and I'm new to this forum. I'm from Phoenix and I drive a '99 I30. The Service Engine Soon light has just come on and, from what I have read here, I seem to have 3 options: The gas pedal procedure (one of two), take it to Checker or buy a reader. I'd like to be able to utilize the Code list that Scott posted. Does one of the two gas pedal procedures work on this car? I'm also open to other ideas. Many thanks in advance for your help!
maxhopper
Welcome to NICO.
The 99 is pretty unique. Your best bet would be to have it read by your local parts store.
rlguarig
Thanks, Scott. Will do.
Ralph
rlguarig
Another question about my '99 I30: the code came up "P0138 - Heated Oxygen Sensor 2 Circuit High Voltage (Bank 1)". I'm assuming this means the O2 sensor needs to be replaced. O2 sensors screw into the exhaust pipe or manifold, correct? If it's the manifold, how do I know which is Bank 1?I'm just not very good with anything newer than about 1987.
Thanks,
Ralph
maxhopper
Bank 1 is the side nearest to the fire wall. Sensor 2 will be the one furthest from the manifold (before the catalytic converter) on that bank.
rlguarig
One more thing... The light has gone out. Does that mean the car has magically fixed itself? I'm thinking I should go ahead and replace the O2 sensor...yes?
Ralph
Modified by rlguarig at 2:05 PM 10/10/2007
maxhopper
Yes, it means that the sensor is slow in responding and on it's way to total failure. Best to go ahead and replace it.
rlguarig
Scott,
Many, many thanks for your help. If you're ever in Phoenix, please look me up - http://www.HomesByRalph.com.
All the Best
Ralph
maxhopper
Well you just missed me. I was there the weekend of Sept 29 for a memorial service. Maybe next time.
