INSTALL: Getting rid of the big chrome "NISSAN" emblem
Nissan 350z / Nissan 370z general community discussion forum
Exar-Kun
Car: 2005 350Z
OK, so this is one of my first mods to my 2005 350Z, and I figured some of you guys would benifit from the process being shown.
First- FIND YOUR ENEMY!
Exar-Kun
Car: 2005 350Z
Yep. Very good. You found it. Chrome is bad, right? RIGHT! I much prefer the Matte/Brushed aluminum look.
Second - Get a grease pen (I used red), and outline the old emblem. Marking very darkly near the ends of the "NISSAN" plate.
Note: The new emblem does not have alignment pins, where the stock emblem does. Mark it now so you can align the new symbol correctly!
Exar-Kun
Car: 2005 350Z
Step 3: Compare your emblems! Bright shiny chrome one=bad, brushed alluminum look one=good.
Exar-Kun
Car: 2005 350Z
Step Four - Get out some fishing line. Work it under the double sided tape holding the old emblem off. GET GLOVES, it requires quite a bit of tension to start pulling through the tape. I found it easier to start at the top, then sides and bottom. Moving the fishing line back and forth and you go through it also helpfull, but can lead(in my case) to shredding /breaking the line. Get at least 20lb line, I only had 15lb line and wished it had been stronger.
Step Five - Once the backing has been cut through with the fishing line, slowly pull the old emblem off your trunk. It should look like this:
Exar-Kun
Car: 2005 350Z
Step five - Get that old adhesive crap off the paint! I used my fingernail and some simplegreen. DOn't use anything that may damage the paint. Afterwords someone reccoemended a popsickle stick or plastic/teflon scraper, try it.
Step six - clean the surface -WITHOUT- wiping off the grease pen marks!
Step seven - Peel the backing off the new and improved emblem, and align it with the grease pen marks. Once done it will look like this:
Exar-Kun
Car: 2005 350Z
Sexy, no?
Another shot of the finished product:
saheintz
Car: 2003 Nissan 350Z
Nice! Now just take the 350Z emblem off and you'll be set. No need for two Zs on the rear IMO.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
saheintz wrote:Nice! Now just take the 350Z emblem off and you'll be set. No need for two Zs on the rear IMO.
Good post... And I agree with that!
Exar-Kun
Car: 2005 350Z
Yeah, I am undecided on that right now...
I would have jsut left the emblem off (the NISSAN one) if it didnt ahve those dman holes behind it...
I prefer clean looks, hence the brushed alluminum instead of chrome. ANyways, I may remove that, so long as ther eis nothing under it likc the holes or something :p
-Chet
saheintz
There is nothing under the "350Z" emblem.
Mantis3024
Car: '04 Nissan 350z ll '01 Acura Integra GSR ll '84 Porsche 944
Welcome to the club ! Id definately recommend shaving off the 350Z badges, it'll look a lot cleaner. They come off A LOT easier than the Nissan emblems. Its just a pain to get rid of the leftover glue residue. After a thorough claybar and couple coats of zaino (or wax), the traces should be gone. (refer to sig)
240DRFT
haha love the pic in your sig.
the new emblem looks good
Exar-Kun
Car: 2005 350Z
Gotta do the front one now :/
I'll post up some more installs shortly...-Chet
Bosrudorfer
Car: S14
Shouldn't you heat the emblems? I will be using this guide to remove my S14 OEM emblems.
Thanks
Exar-Kun
Car: 2005 350Z
Yeah,
Heating the emblem would probably be helpfull. One thing to remember about it: Your clearcoat can be smeared if heated enough(!!!!)..be very carefull if you heat it up and start craping away...
otherwise, it should help the removal of the adhesive backing of the old emblems..
Good luck!-Chet
CABhc4life
Car: 2006 350Z
what do you all think of this:
what's the deal with "fairlady" ?
Sil40_Mayhem
Car: 1995 Nissan 240SX 5spd
1992 Acura Integra LS
Looks nice! Good job, Exar-Kun!
CABhc4life wrote:what do you all think of this:
Wrong place for it (I think it belongs where the "350Z" emblem goes. Oh, and "Fairlady" is the JDM (Tyte) name for the Z (in lieu of 240, 260, 280, 300, and 350).
CABhc4life
Car: 2006 350Z
it looks like they have 2 options for these:
http://www.courtesyparts.com/M...FRLDC
that's the smaller one to replace the 350Z emblem, and here's the other one:
http://cgi.ebay.com/ebaymotors...ZWDVW
^^^requires 3 holes to be drilled...screw that.
I'll probably stick with doing an aluminum Z emblem on the front and on the rear, and take off the rear 350Z. Simple, standard, and flush.
Any ideas/suggestions on where to get a couple of aluminum Z emblems for a good price online?
CABhc4life
Car: 2006 350Z
I just purchased these:
anyone know the best method for taking off the dealership stickers?
Black on Gold
Sil40_Mayhem wrote:Looks nice! Good job, Exar-Kun!
Nah, i like exactly where it sits
CABhc4life
Car: 2006 350Z
anyone know where I can get these cheaply made pieces of plastic labeled JDM for less than $70 for both?
2 chunks of plastic...looked all over the internet...cheapest i saw was 70 bucks for both BEFORE shipping...
someone is making a killing!
BlackSmoke
Car: 2007 350z Grand Touring
Yeah new emblem looks good.
brandonDavid
Car: 1992 240sx, 1992 D21
still looks big and ugly to me...
should have shaved it, welded a little piece of metal behind the two holes, bondo, primer, and get someone to match the paint... IMO.
rmezz13
Car: Had 2004.5 Nissan 350z
Have 96 f250 and mommas 07 Murano
*bump*
lucsious
Car: 350z
how did you remove the front nissan emblem im finding it tricky as its not flush with the car its sucken in
lucsious
Car: 350z
CABhc4life wrote:anyone know where I can get these cheaply made pieces of plastic labeled JDM for less than $70 for both?
ebay has them right now for under 70 just saw them
lucsious
Car: 350z
hey just wanted to note , i just removed my back emblem today and there where no holes. i read peoples questions about that, in other threads on the net, so wanted to clear that up... and i have an 04 roadster
RCAnismo
Car: '06 Nissan 350Z Enthusiast, '05 CBR 1000RR Repsol, '03 Jeep Grand Cherokee
lucsious wrote:hey just wanted to note , i just removed my back emblem today and there where no holes. i read peoples questions about that, in other threads on the net, so wanted to clear that up... and i have an 04 roadster
no friggin way???? If this is the case I am going to remove mine immediately....Is this just a roadster thing you think??
lucsious
Car: 350z
the way i was able to tell at first was i was able to slide the credit card right under and felt no pins. i was going to remove it either way but im glad there are no holes ill post pics tomorrow
lucsious
Car: 350z
Return to “350z / 370z Discussion”
