 1/4 mile timesFirst  1 2 >  Last
boost_boy
Supporting Member
B12 sentra w/built CA18DET, B12 sentra w/fully built CA18DET, b13 sentra w/CA18DET
Miami Fl
11-14-2002
  CA18DET 1/4 mile times+mods+track experience
NOTE:Please post your mods as well as the track info!
This thread is being restarted because the previous one was accidentally deleted. Keep in mind folks that this thread is more for reference and not up for discussion or arguements. If you feel the need to voice a concern relating to this topic, feel free to start a regular thread below. One warning, do not bring arguements to this thread or you will have wasted your valuable time because it will be deleted. If you post something that sounds rediculous, you will be emailed and validation of said claim will have to be produced or your post will be deleted "Point Blank". Keep it real and most importantly keep it clean.
My 1st time on the track was in April 2k2 with a stock CA18DET powered, 1990 b12 nissan sentra 4-dr. Mods included custom FMIC, MSD 50lb/hr injectors, a re-worked T25, a non-LSD gearbox, and SDS standalone engine management system.
1st run was a 14.8@98mph on 13psi of boost on regular street tires, 35psi of air in all 4 tires (205/50-15 kumho tires on B14 SE-r 15in. rims). Just lauched the car too hard because I was excited and the thing went nowhere fast.
2nd run was a 13.9@103.93mph. This launch was a little better with less wheelspin, but still a weak launch nonetheless. This run was done on open-boost (yes, I pulled the hose off the wastegate actuator). It didn't make the car that much faster, but it did sound cool and caused my intake temperatures to shoot through the roof. Tire pressure this time was brought to 20psi.
In 2003, I replaced the previous sentra that was destroyed with another sedan. On Dec. 21, 2003, I ran a 14.770@104.55mph with regular street tires. R/T=1.031, 60'=3.016, 330=7.059, 1/8=10.073@81.54mph, 1000'=12.636.
In 2004, I took the new sentra (the other one got destroyed later in 2k2) with it's new T3/T04E stage III with a .48 backhousing, 205/50-15 BF goodrich drag radials on B14 SEL gunmetal rims, 7 y/o intrax/kyb suspension, much better tuning on SDS, MSD 72lb/hr injectors, MSD DIS-2 ignition box with 2 step launch control, better turbo manifold, hks 40mm wastegate, blitz and Greddy bovs, upgraded FMIC, NISMO fpr, and bliz dual sbc/turbo timer on board.
1st run got smoked by an S14 with RB25DET. R/T=1.287__60'=2.799__330'=6.928__1/8=9.903@83.11mph__1000'=12.414__1/4=14.547@104.72mph
2nd run got smoked by a 10 second Supra. R/T=981__60'=2.906__330'=7.207__1/8=10.232@82.97mph__1000'=12.735__1/4=14.862@106.11mph
3rd run against old neon with SRT4 motor in it boosting 25psi to my 18psi. R/T=.690__60'=2.578__330'=6.715__1/8=9.722@83.04mph__1000'=12.202__1/4=14.236@111.38mph (difference here was 2-step lauch, but still burned radials and went nowhere fast).
4th and final run against mazda6 and killed my clutch after 2nd gear. R/T=.348__60'=2.368__330'=6.312__1/8=9.520@69.85mph__1000'=12.979__1/4=16.487@60.20mph. This run started out to be my best effort for the day, but the clutch let loose after coming out of 2nd gear and I just let the car coast in neutral through the traps.
Have fun sharing your experiences, but remember to keep it real!
Dee
Dee
CA19DET
Trinidad & Tobago
5-15-2003
averaged 14.2-14.5's@100-105mph at 9psi
T3/T4E 50T .63 Stg3
TRUST turbo manifold
XS ENG Intercooler (20x12x3 bar plate)
TOMEI 260 ProCam KIT w/ TOMEI valve springs
Haltech E6k, 3bar Map
RC ENG 550cc Injectors w/ 255 Walbro
Aeromotive FPR
HKS 1.6mm Headgasket
SPEC stage 4, OEM VLSD
225 50 16 Kumho's
returning on the 26th more boost and slicks
CA18_shift
nismoplsr
connecticut
10-19-2003
 « Re: (CA19DET)
Where:
Oct 2004 New England Dragway
Condtions:
Cold (~40deg f) and night time.
Tires:
Kumho Ecsta Supra 712 @ ~30 Psi
warmed up in the water box.
Time:
14.5 @ 106 Mph 2.5s 60'
Mods:
Haltech E6k
Greddy Profec-B spec II
Unorthodox lightened underdrive crank Pulley
Lucas 550cc injectors
Nismo AFPR
Z32 TT fuel pump
GT28RS(.86 A/R hot) running 18psi of boost
Spearco 26x6x3 intercooler
2.5" exhaust
This was my first time ever on a track. I had trouble with the launches. I either bogged badly or just spun the tires threw the first 3 gears.
I was getting the hang of the track when my wastgate actuator arm fell off on the launch so i coasted the rest fo the track while i tryed to figure out what happened. Because i didnt have any spare e-clips and the car would have had to cool for a while before i could get behind the manifold the night was over for me. I had an awesome time thought and cant wait to go back this summer with some better tires and with my fully functioning studder box and anti lag.
Project Johny 5 - 1988 Nissan PulsarNX SE sportbak ~ too much to list
Daily Driver - 2008 Nissan Sentra SE-R Spec V ~ MR coilovers, Wedsports
USDM_OneVia
Racing
Cincinnati, OH
4-5-2003
 « Re: CA18DET 1/4 mile times+mods+track experience (boost_boy)
Embarrassment time!
1992 SE Coupe
Stock T25
Stock exhaust system
Stock EVERYTHING except GReddy FMIC and 3in Downpipe
14.2@99mph
I can drive bitches!!!
Never ran it on the setup before I sold it....... oh well.
Joe
Joe
03 Subaru WRX Prodrive Whore
96 Base Daily Driver New Project
92 240SX SE Coupe CA18DET HKS Whore SOLD!!!
cortina-mk1
GT-R Skyline, MK1 Cortina's
Ballarat VIC
7-6-2003
 « Re: CA18DET 1/4 mile times+mods+track experience (USDM_OneVia)
ok dee will post again
still a 1.8 liter CA
these best times achieved on radials, leaf springs (no ladder bars) full exhaust, full trim and still stock manual transmission.
60 footer 1.62
1/8th et 7.31
1/8th MPH 100
1/4 ET 11.5
1/4 speed 123 mph
engine specs can be found here
Modified by cortina-mk1 at 4:23 PM 5/19/2007
www.cortina-mk1.com
CA18 det powered ----> 11.5 and 123mph
CA19DET
Trinidad & Tobago
5-15-2003
i just ran this weekend, 13.4@114mph was best.. running 18-20psi, on stock CA18DET with TOMEI valvetrain and T3/T04E 50t.. great runs, need slicks badly...
Nismo1182
Nissan's
ORLANDO, FL
10-24-2002
114 trap, spun a lot didnt ya hehe
Never ran my CA at the track but with the SR on stock sidemount, intake, 3" dp, 3" tp, 3" N1 catback and 10 psi, I did 14.0 @ 100 with a 2.2 60'
on 14 psi I did 13.5 @ 104 with a 2.0 60'
~Z~
originalsin
3-25-2004
well i havent gotten to the 1/4 yet, but i was just at the 1/8th for my 1st time
mods
-3in downpipe, gutted cat, 3in apexi n1 catback
-cone filter
-ka24de TB
-vlsd
-205/50/15 yokohama es100's
-centerforce dual friction clutch
-sr smic
-10psi
1st pass - very ****ty, my 1st time at a track ever lol
r- 1.16
60ft- 2.8
1/8th - 10.68@71mph
2nd pass - sumhow worse
r- .59
60ft- 3.2
1/8th - 11.1@71mph
3rd pass - best one
r- 1.03
60ft- 2.5
1/8th - 10.33@72mph
i think with me learning to launch better i can make it into the high 9's
1SlowCA18DET
Flower Mound TX
4-27-2005
 « Re: (originalsin)
went to the 1/8 mile last night
60ft= 2.3
330=6.1
1/8= 9.24@78mph
mods=
evo 8 front mount
z32tt fuel pump
ka throttle body
ka maf
11psi
oped diff
safc
full turbo back 3 inch exhaust
stock t25
what you guy think i'll get in the 1/4?
Not_a_sr
90 ca18 pwrd 240sx FB
dayton oh
12-19-2004
 « Re: (biosehnsucht)
Quote, originally posted by Not_a_sr »
well after a short day at the shop preping the car for test and tune we made the first track apperance ever with my car. showed up at 6pm left at 9pm got in 4 runs. the first run was the best of the day, and it just got slower as it went, but my trap speeds went up... i also did not drive i let my friend drive. i wanted to spectate what my car could do.. next time ill probably drive and see what i cant get out of it.
made these runs on mismatched used tires i bought down the street. full air pressure prob 35-50psi, on the first run coil overs set full stiff rear,full soft front. then half stiff in the rear and full soft in the front the rest of the runs.
i was car 132
second or third run
these were the fastest runs, the others were 13.6828 and 14.4878
http://www.ForcedFabllc.com
nismoplsr
connecticut
10-19-2003
 « Re: (boost_boy)
I just got back from the track tonight.
60' 2.498
1/4 ET 14.569
107.44 MPH
ozzie180ca
1990 180sx ca18det
Brisbane Qld
11-18-2005
 « Another Australian Racer
My mate was running a CA in a datsun 120Y, s15 turbo and small fmic with toyo ra tyres and ran 12.3. Now is fitting a rb20 turbo.
http://www.cruisingbrisbane.co...12115
Hillkill
s12
Briisbane CA
7-13-2005
 « Re: (boost junky)
Well a ca18det powered s12 can run 9.03 1/8th mile with some minor improvements (14psi, 255lph walbro, stock t25 turbo, open diff, CFDF clutch, 2 10in subs in the back, and on bridgestone potenzas) and still lost to some stripped civic.
1fast200
too many to list
Curacao, N.A.
9-12-2002
Wel,
I just swapped a CA18DET for a customer in a 4 door, 1983 Toyota Starlet.
Full weight, STOCK engine, Microtech MTX-8 ECU, T3/T4, Tial 38mm W/G, big FMIC, Injectors, twin RX-7 coilpacks @ approx 15lbs :
11.46 sec. @ 120 mph. with a slow 1.6+ sec. 60ft. due to big wheelstands.
www.RYSO-TECH.com :
Builders of the fastest stock block, street Nissan's.
Bullseye Turbo & Microtech Sales Representative.
Haltech Authorised Dealer & Certified Tuner
Dynojet 224 dyno
1fast200
too many to list
Curacao, N.A.
9-12-2002
 « Re: CA18DET 1/4 mile times+mods+track experience (1fast200)
Well, an update from past weekend (5-28-06)
11.10 seconds @ 122 MPH, 60ft 1.53sec. Still BONE STOCK MOTOR!
Thanks,
RYSO.
NeedCAforS13
Supporting Member
E46 M3 and SR S14
Oldsmar/Tampa FL
1-13-2003
finally ran my ca18det at the track... first time EVER drag racing, so my 60 ft's kinda sucked.
on crappy drift tires dropped to 25psi. I spun all the way through first, and each time I shifted gears. I did however manage to beat the other s13 I went with 3 times in a row, and he's got an SR20
1st run:
R/T: .700
60ft: 2.452
1/8: 9.771 @ 77.67mph
1/4: 14.777 @ 98.89mph
2nd run: (best)
R/T: .580
60ft: 2.505
1/8: 9.609 @ 79.61mph
1/4: 14.53 @ 100.53mph
3rd run (I hit the rev limiter in 3rd and the car bogged HARD).
R/T: .516
60ft: 2.473
1/8: 9.538 @ 79.76mph
1/4: 14.544 @ 98.18mph
mods are intake, exhaust, downpipe, fmic, s14 gt28, 10psi. I have an safc as well, but I haven't done any tuning with it. I have a maxima maf and 550cc injectors, once I install I'll turn it up to 14psi and get some good tires and hopefully go deep into the 13's. I think with trap speed just over 100mph, high 13s are within reach right now even.
edit for some pics: mine is the s13 in front, the other is my friend's car with an SR20.
originalsin
3-25-2004
went 9.6@73 in the 1/8 tonite, 60ft was 2.23, was pretty happy considering my times up above, all i did since then was put some bigger tires on and do a hg and studs
shogun!
Nissan 200SX S13
Gothenburg SE
3-31-2005
 « Re: (originalsin)
So far he best time we have here in Sweden, with ca18det in an S13:
11,47
191 km/h
60 feet 1,59
Not me...I wish...
http://web.200sx.nu/MetaForum/...0&S=1
On my way towards better performance...
http://www.garaget.org/?car=16972
`SHOGUN´ My Project +700HKR, 200SX from standard 2 extreme
teambuiltnissan
nissan 2 dr
7-1-2005
 « Re: (kapower06)
I finally had time to do shake down pass. this pass was made with 26psi boost. missed 2nd gear and spinning pretty bad on 1st
r/t 1.175
60 1.789
330 5.042
1/8 7.576
mph 103.92
1000 9.673
1/4 11.24
mph 134.84
I should be able to run again on end of this month if I get lucky enough....
Attachment: poop048-1.jpg (159205 bytes, downloaded 13311 times)
Owner of The shop
http://www.yellowmunsontuning.com
highest HP record for ca18det, and stock bottom end KA-T.
AEM factory certified trained tuner
Power FC excel pro tuner
F con Vpro
custom rom tune
teambuiltnissan
nissan 2 dr
7-1-2005
 « Re: (teambuiltnissan)
pic
Attachment: poop049-1.jpg (161852 bytes, downloaded 13132 times)
teambuiltnissan
nissan 2 dr
7-1-2005
2nd gear burn out
Attachment: scot_s13.jpg (326918 bytes, downloaded 12316 times)
Ca_Silvia
Calgary
11-18-2005
Here is my bone stock CA 1/4 mile times. First the car was setup for autocross that night and it was my first time at a track. Now that the excuses are out of the way here are the numbers:
R/T .424
60' 2.3
330 6.06
1/8 10.1
1000' 13.2
1/4 15.77
MPH 89.4
This was my fastest run of the night i did however muster a .232 R/T once and a 90.9 MPH on one run also. So i feel confident that the car can do low 15's
Aaron
ca18hatch
1992 240sx hatch w/ca18 swap
lebanon tn
12-29-2006
Second time at the track, running stock t25 and stock everything except 3" exhaust and greddy boost controller at 12 psi, vlsd.
60ft-- 2.0
1/8 mile-- 9.1@79 mph
We dont have a quarter mile track nearby, thus only have 1/8 mile times.
WaKoS13
S13 Silvia
portland vic
4-1-2007
My S13 has ca18, auto trans, custom intercooler, t25g twin dump pipe, 3" exhaust, rising rate reg, walbro fuel pump, rb20 AFM, and a pod filter 14psi boost done:
1/8 mile:
r/t 0.437
60 f/t 2.1 sec
et 8.637 sec
mph 82
smoked a manual r33 running the same boost all night
240sxbobbis
was ca powered now ka powered rb is under construction
silver spring maryland
6-28-2006
well i went to the 1/4 mile track in Crofton Maryland on Friday known as capital race way and did bad well honestly it was my first time dragging my car on a track before so the experience was totally new to me i ran an 15.573 at 88.78 miles per hour
Image exceeds 600 x 200 sig size limit
Phyrx
2001 Audi TT Quattro
Millbrook AL
8-26-2006
Ran on 4-6-07 @ Montgomery Motorsports Park in Alabama
14.1 @ 98 mph
Stock internal CA18DET RWD
Stock slipping clutch
NO LSD
290k suspension
100lbs of parts in the trunk
Full weight 90 coupe
Buddy Club Spec II exhaust
Weird turbo... (80 a/r front and back but looks like a stock CA turbo)
Stock boost
Apex Hybrid GT FMIC
Cusco Cold Pipe
HKS SSQV Blow Off Valve
SSAC Downpipe + Test Pipe
Same night I ran dead even with my best friends SR20 @ 14+ psi from a 50 kick and he ran a 13.7@104 at the track the same night
I should def. have high 13's with a better clutch, LSD, and suspension.. on stock boost!
1989 Nissan 240SX Hatch - SR20 Powered
dvd
daly city, ca
7-6-2003
Just got back from the track. It was my first time.
Car:
69 datsun 510
4.11 diff ratio subaru lsd
gt2510 @ 10-11psi
sohc ka maf running as blowthrough
Car's been running rich constantly around 10:1 everytime, no matter how much I change the boost. I have a walbro inline 255lph pump and a nismo afpr.
Car is too low in the rear so there's a lot of camber. Anyways here is the best time i got.
r/t 1.169
60' 2.487
1/4 14.358 @ 99.74 mph
Pretty sad considering phyrx got a better time and he has a stock turbo with stock boost. Ha
Phyrx
Millbrook AL
8-26-2006
 « Re: (dvd)
The turbo I had wasnt stock.. looked more along the lines of an SR turbo minus the flanged inlet... weird.
Nice times though
ser20det
Silvia K's 88
Montreal Quebec
12-8-2006
 « Re: (Phyrx)
Well ! First time at track forever !
Silvia k's jdm 1988 ca18det Bone stock (full loaded...it'S a k'S anyway... a/c, P/s, P/w, Abs, etc ...
Street tire yokohama evs es100
Best run
E.T.: 15.351
Réact: .360
Mph: 90.341
Best mph of the night: 90.625
Best Reaction time : .206
I was very happy with my first time at track with my stock ca18det car and fully loaded!
Modified by ser20det at 8:22 AM 6/25/2007
Don't trust my nickname ! *** CA18DET inside ! ***
shelnut
4D b13 GA, 2D b13 SR, s13 Empty
Johnson City Tennessee
7-17-2007
14.5 at 99 with restrictive 3 inch ehaust 3 inch dp crappy intercooler hks f-con spec stage 1 clutch r32 rear end and sr turbo on about 9psi
hoping to get into 13s today on about 11psi straight through 3 inch ehaust big hidin frout mount and a little 110 octane
Modified by shelnut at 10:23 AM 7/17/2007
91 240sx w/CA18- Traded
92 Senrta E - Back on the road
92 NX2000-Traded
93 Pulsar GTi-R-Sold
96 240sx w/RB25- Sold
91 Sentra SE-R Boosted- Sold
92 240sx- Empty
Giallo spyder met
Nissan 200sx -92 Euromodel
Jonkoping
2-15-2007
 « Re: CA18DET 1/4 mile times+mods+track experience (shelnut)
I did my first striprun last week and the best run were
12,81s 179km/h 60fot 1,91
This with my s13 ca18det totaly stock bottom.
ser20det
Silvia K's 88
Montreal Quebec
12-8-2006
 « Re: CA18DET 1/4 mile times+mods+track experience (Giallo spyder met)
New record. Second time at track.
Best run
E.T.: 15.299
Réact: .437
Mph: 90.506
BigTone
guess!!!
CARDIFF
8-23-2004
went to Ten Of The Best on the weekend with SXOC.com for the cars first outing
and my first drive in 2yrs
heres what happened..
first off a big thanks to SXOC for sponsoring the team..
a big thumbs up to the team itself (did the club proud)
on a personal note..
Mike and myself got to ND's first thing Saturday morning to finish her off...
by 11.00 hrs she was as ready as she was going to be,
fired her up and I got to drive her for the first time in 2 yrs,
ND told me to do a few laps of the ind est, bring her on boost just to make sure everything was fine..
Well.... on my second lap I nailed it in second boost came in lit the rear tyres up arse end shot out
I fought the car straight... oh and I crapped myself :nod:
ND then set it from 1.2 bar to 2.0 bar and sent me back out:eek:
all I can say is she is scary fast with a slight traction issue...
and thaty was my total amount of practice for TOTB, we hitched the car up and left for Elvington...
I had a cracking but tiring 2 days,
had a right laugh all day Sunday, very relaxed feeling all day..
as for my times..
while Mr Purple / White and I were chatting on the strip (they had to clean a load of oil up)
Mike came over with some of my timming slips, first one 13.38, 12.59, 17.81:wack:(1st to 4th gear change)
12.07, 12.06, feck I thought am what do I have to do to get into the 11's...
then he showed me a 11.59 the bastid :D
we let out some air (down to 8psi) and did a 11.32 @ 131 mph :D (all with no driver aids not even a rev counter)
the top speed.. was a bit hair raising (side wind was blowing the car all over the place :)
but I though feck it and just nailed it foot to the floor...
managed 186.8 mph (not bad for a mile)
I would just like to say thanks to Dave at ND for the 3 days he was on wire duty, ND for all his help :thumbs: even on the Sunday morning
(they had to change some pins in the ecu on Sunday)
and a huge thanks to Mike for all the help over the last 2 yrs to get her ready (would never done it without your help):thumbs: :thumbs:
team HQ
accomodation
calm before the storm
the MLR boys came and joined us for burgers and beer..good bunch of lads :nod:
at the start line
project phoenix
Giallo spyder met
Jonkoping
2-15-2007
 « New personal record.
I made
60ft 1,75
1/8 7,79-147km/h
1/4 12,13-182km/h
With stock bottom ca18det and 1,3bar boost.
Giallo spyder met
Jonkoping
2-15-2007
 « Re: New personal record. (Giallo spyder met)
Hi
We have a new record in Sweden.
11.26sec and 205km/h in a 200sx S13 with a ca18det.
The engine put out 497Whp at 1.95bar boost but the time
was set with 1.6bar.
Anywone who knows what the world record is with a ca18det in a S13?
Cameron
a 240
Atlanta GA
6-3-2007
you wouldnt happen to be the record setter would you, cause i watched his vid on youtube, and i **** my pants.
Can't stop, Wont stop, ride to the rhythm, cause I, I get down an I, I get down
ser20det
Silvia K's 88
Montreal Quebec
12-8-2006
MAde my best e.t. at 13hoo pm.
Ser20det - 60' 2.182 , 14.971@94.483mph(1988 silvia k's Ca18det - Blue )
Tire in the rear was yokohama evs es100 195/55/r15
The car is completly stock (jdm silvia) . Next year we will work on the suspention and bump those 60' feet time ! hope for 14,7 for next year !
CadetLD
1991 Nissan 240sx Coupe
Clearwater FL
12-3-2006
fun night at the local 1/8th mile last nite with the ole' hatch, It was about 90 degrees out and the track has ALOT of DHT(?)...sticky stuff..
Best time of the nite was 9.499@77.51mph with a 2.2 - 60'
Mods: S15-T28, SR Downpipe, 3" Megan Exhaust, SBR MBC (10-11psi), Walbro(sp?) 255, noname FMIC, Blitz ECU-Filter-BOV, Gutted rear interior/carpet, Falken Ziex 245/50/R16 (R) tires, noname lowering springs, stock dampers.
My first 4 runs were 9.9-10.0 area due to launch issues(me being a n00b), but the last one I ended up slipping all of 1st gear at about 5k rpms and it just felt way faster. My clutch hates me, and my hood release magicaly stoped working at some point during the nite, but hey i had a blast and will be back soon to work on those 60' times and reaction times. -Shane
trevr
'93 240sx Vert CA18det
Endicott NY
1-12-2007
Here's my best run for my first time ever at the 1/8 mile drag strip.
Mods:
2.5" FMIC
Equal length exhaust manifold
3" turbo back exhaust w/ test pipe
stock t25 @ 7psi
Stage 3 clutch
clutch fan
175/15 rear tires @ 30 psi
I was getting better with each run, but my night was cut short cause my hot pipe kept blowing off, and the officials black flagged me for the night. My best run was against a fox body v8 mustang with slicks.
Reaction .8678
60ft 2.1242
330ft 6.1262
1/8 ET 9.3912
1/8 MPH 75.89
Using a conversion table, my 1/4 ET would have been approx 14.59
http://www.eldemoniorojo.com/calculator.htm
With better tires I believe I could possibly get close to 80mph since I was burning tires through 3rd gear.
Modified by trevr at 2:06 PM 11/1/2007
MeanGreenS13
Online
1993 Nissan 240sx
Vero Beach FL
8-20-2005
 « Re: CA18DET 1/4 mile times+mods+track experience (trevr)
does anyone know what the 100% VERIFIED National record is, for a CA18DET in an S13, that is street legal (registerd and insured in the usa for street use)
Let me know guys... im after it =)
Phil
1997 SVT Cobra
 First  1 2 >  Last
» Return to CA18DE / CA18DET Forum
