KA wiring harness removal/RB25DET wiring harness install
jrsink
Is it absolutely nessesary to remove the dash of a 240 to extract (and install the next wiring harness and ECU) the complete wiring harness? I will be using a RB25det wiriing harness and ECU.
Slo_240sx
Car: Mean Green LS1 S13. Caged and Backhalfed.
Not at all unless you are using the rb25det interior harness. Get a friend feed the old harness out and its a pain in the butt to get the new harness back in. Some people take out the dash to remove the evap core and a/c and it makes it easier but unless you want extra work or to take the a/c out then no.-Alex
BoostFab
Car: S13cp, S13fb, S14z
no need to remove the dash, do remove the glove box, however-- it'll make life easier to reach down there.
JonPowell
Car: Cars, Music, My family
I always remove the dash & the blower motor/AC box....just TONS easier that way to wire everything.
FerrariTruck
so im currently in the last leg of completly removing my ka harness and im
stuck at this step..
Man i really didnt feel like having to take the dash out,,ughh
FerrariTruck
FerrariTruck wrote:so im currently in the last leg of completly removing my ka harness and im
OK AFTEr thinking it long and hard, i did not feel taking out the dash and removing the evap unit...
/with that said i got my dewalt sawzall and took 30 seconds to cut the support bracket from the blower motor to firewall...Yes it was that easy...I pulled the harness thru with the slightest of ease...
when i reinstall the harness i will expoxy weld the support bracket back on FTW
bspeed_il
Car: s13 vert. rb25.
winter works in the process...
I guess not having a/c to worry about makes a difference? I didn't have a single bit of trouble when removing mine--oh wait, minus disconnecting the white plug above the ecu...just pulled it out bit by bit myself.
Not a huge fan of cutting anything...
Darius
Holy thread revival!
This thread is so old that the info in it doesn't really apply anymore. The ECU plug and dash plug on the engine harness can be fed through the OEM hole in the firewall. It is kind of a PITA, but it can be done without using a sawzall. LOL To each his own I guess.
s14_sport
well since we're grave digging...I'm curious about the "FerrariTruck"
Now, I'm assuming you have a Dodge Ram truck right? Did you ACTUALLY put a ferrari motor in there? OR (looking at your post) Have someone put a ferrari motor in there for you?
OR...Do you have the Ram with the SRT-10 motor? Which is from a Viper?
Please clear this up for me as I'm very curious AND confused.
FerrariTruck
QUOTE=Darius]Holy thread revival!
This thread is so old that the info in it doesn't really apply anymore. The ECU plug and dash plug on the engine harness can be fed through the OEM hole in the firewall. It is kind of a PITA, but it can be done without using a sawzall. LOL To each his own I guess.[/QUOTE]
I was able to feed the wires thru the hole even thought the connector was beeotch to unplug.
but i thought long and hard of a way to get it out and removal of that bracket was the only way..
Did i comprimise the integrity? slightly, but eh..
Did i save my self aggravation and frustration? You better believe it!
both harness are at the sr20 store getting converted now
s14_sport wrote:well since we're grave digging...I'm curious about the "FerrariTruck"
yeah bud its 04 ram srt 10 with the viper motor.
shes my baby and its my sn on a few forums.
has a few bolts on and in the middle of hooking up Nx system for a 150 shot
to learn more of these creatures see vtcoa.com
