 exhaust manifold studs (ARP part number and size info)
Import_Ant
Lawrence,KS KS
6-5-2004
I've been searching for the better part of this afternoon for exhaust studs for my car (Ka24E motor) because I'm going turbo soon and have 2 exhaust studs broken off in my head and 1 missing. I did a search on here, Googled it, and went through ARP's catalog and have finally found what I'm after.
Bolt size is M8 x 1.25 x 38mm
part number with ARP 400-8012 (total of 8)
I'm posting this mainly because I could only find 3 threads on here regarding exhaust manifold studs for the KA motor and none of them had any resolution and barely any information at that. I hope someone else can benefit from the time I killed at work if this ever comes up again :
I'll post a followup after I have recieved the studs if anyone is interested (I plan on going direct through ARP if I can so I'll be happy to post a price w/ shipping as well...)
Happy boosting
-Aaron
Shady-Tree Mechanic Shopporu
USDM Tight since 1986
00' Park Avenue Ultra (the superchargers go Whoooo)
89 coupe (down to the frame.)
90 fastback (up and running again)
crzycav86
93 240sx KAT
Houston TX
8-5-2003
 « Re: exhaust manifold studs (Import_Ant)
I don't plan on using those studs, since all of mine are intact, but I didn't want your find to go unnoticed. So thank you.
Give us an update/review when you get them on. Someone will probably need them one day.
Import_Ant
Lawrence,KS KS
6-5-2004
 « Re: exhaust manifold studs (crzycav86)
Thanks for the kind words. I'll definitely get some pictures/info up but it will be a couple of weeks before I get a chance to do that (I've set a reminder up so I don't forget) I'm so broke from buying the turbo kit that I won't be able to order the studs for another 2 weeks but that's ok since there's a 2-week downtime for my kit while my turbo is being ordered and the kit made so I'll get back to this asap.
onosqv
Q to the V
'92 240sx Vert
bewbews.com OC, CA
8-7-2002
Yes, we don't want this thread going unnoticed. It seems like 3 broken bolts run common w/ the KA's (at least mine has the same problem), hehe.
So, any updates, feelings on these studs?
bew bews!
Import_Ant
Lawrence,KS KS
6-5-2004
 « Re: exhaust manifold studs (brokeAs240sx)
Quote, originally posted by brokeAs240sx »
hehe... uh... I spent the 50$ on a new motor instead (had a blown head gasket but nothing else wrong and no stripped exhaust studs.)
gotta love the KA motor for that. descisions descisions; new motor or exhaust studs...
onosqv
Q to the V
'92 240sx Vert
bewbews.com OC, CA
8-7-2002
HAHHAHAHAHAHAHHAA, new motor costs less than replacing exhaust studs, HAHAHHAHAA.
O man, sad... but true.
Good times.
Titan
2-19-2003
Someone mind explaining why they must be ARP brand studs?
Local FACCA Fasteners Ltd.
M8 x 1.25 x 35mm Stud - Grade 10.9 (Equivalent to Grade 8 SAE - 150,000 psi tensile strength) was about $1.00 CDN each.
Also available in grade 12.9 (176,000 psi tensile strength).
Stock ones are grade 8.8 (120,000 psi tensile strength).
Why pay and wait more when these can be had locally?
onosqv
Q to the V
'92 240sx Vert
bewbews.com OC, CA
8-7-2002
 « Re: exhaust manifold studs (Titan)
Because ARP is the JDM of exhaust studs
Well, I didn't know about FACCA Fasteners, thanks for bringing it up. We trust arp because many guys already run their stuff w/ great success - also, I suppose it markets to us better.
Only two options I even really knew of before were stock, nismo (which doesn't make exhaust studs anyway), & arp.
Titan
2-19-2003
It doesn't have to be a FACCA, it can be any fastener shop in your area.
There is nothing special about ARP studs, bolts or otherwise. All are common commercial fasteners. Literally dozens of manufacturers.
onosqv
Q to the V
'92 240sx Vert
bewbews.com OC, CA
8-7-2002
So all studs are made this way?:
Quote, originally posted by www.arp-bolts.com »
GO BACK TO TOOL BOX HERE
CYLINDER HEAD STUDS:
“On the basis of superior material, a special heat treating process, and advanced manufacturing technology, ARP® Pro Series head studs are clearly the very finest on the market today!”
•VIEW APPLICATION CHARTS HERE
It is for good reason that virtually every top professional engine builder relies on ARP® Pro Series head studs for their all-out competition powerplants. Simply stated, there’s not a better stud setup on the market today.
For openers, ARP® uses a premium grade 8740 alloy that is rated far superior to “aircraft” quality. Then, each stud is placed vertically in special racks and precisely heat-treated to 190,000 psi. This procedure ensures complete heat penetration and the results are far superior to those lesser quality studs from other manufacturers who just dump pieces in a basket and hope for the best.
Following heat-treat, each stud is centerless ground to make it as close to perfectly concentric as possible. This procedure involves about ten very slight cuts and results in an exceptionally straight part. It’s important to note that lesser quality studs are not even centerless ground—the material is thread rolled in bar stock form (mostly before heat-treat, when the material is easier to machine). Because ARP® studs are manufactured to such exacting tolerances, you will note that gaskets and cylinder heads literally glide into position and are perfectly aligned—something that won’t happen with inferior quality head studs.
ARP® studs are thread rolled after heat-treat, which gives them about 1000% (that’s ten times) better fatigue strength than those studs that are threaded prior to heat-treat (a very common industry practice). It costs a lot more to do it this way, because it’s tough on tooling, but the results are well worth the extra effort.
You will also note that ARP® offers specially undercut studs for several engines. This procedure (done only to the shorter studs) more equalizes the “stretch” of both studs, which makes for a more consistent clamping force—and one that compensates for head gasket compression when the cylinder heads are installed. This helps prevent blown head gaskets, and assures optimum engine sealing!
Premium quality heat-treated 8740 chrome moly steel head stud kits are available for most every domestic and import application. You won’t find a better quality stud on the market from any other source. Look for ARP® stamped on each stud as your assurance of quality.
ARP® head stud kits are available with your choice of conventional hex nuts or compact 12-point nuts. Premium quality parallel ground washers are also included with each kit. Clearly, they are the best on the market today, and the favorite of leading professional engine builders in all forms of racing.
I would think someone who finds above important would be willing to pay extra - peace of mind if you will. Others who don't, won't
Import_Ant
Lawrence,KS KS
6-5-2004
Quote, originally posted by Titan »
Of course they don't have to be, that's why I listed stud size, length, and thread pitch as well. Alot of people like ARP bolts so I thought to list their part number as well since I had it available at the time of the post
skatanic28
96 240sx
buffalo ny
10-10-2002
thanks for the info:)
im surprised that none of mine have broken yet.
http://www.cardomain.com/memberpage/190556/1
Titan
2-19-2003
That's the point, it's not important. The process described is far and beyond overkill. If you calculate the shear and tensile stress acting on the cross-section of the studs, even given the heftiest turbo/manifold setup, you will find the safety factor to be ridiculously in excess. More then likely, the studs will be one of the last components to fail.
Furthermore, having the studs centric to such a tight tolerance warrants no benefit, as the manifold is drilled for a clearance hole, not a dowel fit.
What I’m saying is, from a cost/benefit perspective, it makes absolutely no sense to pay for something you will never fully make use of. Especially when there is something locally available that will perform the job equally well for less.
This reminds me of people who buy fittings/hose/etc. from specialty shops (such as ATP Turbo), when the exact same product can be found at an industrial supplier (such as mcmaster.com) for much cheaper. I just don't understand it.
Import_Ant
Lawrence,KS KS
6-5-2004
I am probably the most guilty of not practicing what I preach but...
It is a product of our society, slothfulness that is, to want everything 'pre drilled, polished, packaged, and shipped to our door' 2day UPS. I imagine they see it as ordering "head bolts for civic" not "M8 x1.75 x 80mm bolts". Alot of people get intimidated and, regardless of difference in price it is more comforting for them to pay extra for a part labeled as 'this part' for 'this car' that they feel they know will fit, instead of trying to research and get its generic counterpart and save the money it cost the manufacturer to print/stamp/etch their name into the same part. Sometimes it's cheaper if you order things as a kit for example, most of the time it isnt. It just comes across as a form of sloth to me.
[/rant]
tiger
BarefootRacer!
Hville tn
5-3-2005
Quote, originally posted by Import_Ant »
[/rant]
Dude, you're absolutely correct... I find myself just wanting to take the easy, no-headache way out. Especially when shopping for sizes.. i'm just afraid that I won't order the right part so I go pay more for a product that has already been figured out and labeled as "the right part" no guessing. I am not familiar with anything other than Milimeter.. that 1/16th and all that other just confuses me cause i'm not familiar with it. SOrry if this thread is really really old, I just had to chime in. I am not going to order ARP studs, i'm going to take those measurements and go to maybe Lowes or something and get the
studs.. of course, making sure that they aren't made of cheap metal.. yes. people like the easy button.
daconkiftador
Classified$ P0st Wh*re
'92 Coupe SE, '83 Rabbit GTi
Clarkston WA
1-14-2006
Good find, I needed to replace an exhaust stud before dropping my DE back in!
FS: DOHC KA24DE Timing Chain Kit, OEM(yes real Nissan) Brand-New! eMail me.
http://forums.nicoclub.com/zer...d-new
Chezedik
...and then there were three.
1991 Nissan 240sx
Overland Park KS
12-17-2002
Ant, are you keeping the engine or just using the studs?
Check me out, I'm a ricer: "I am going to get a stage two turbo kit, and nitrous, just like I saw on N4S Underground!!!"
Stuff for Sale:
!!!BUY MY CAR!!!! 1991 240sx KA24DE-t for sale, very nice!
Stock and Performance Parts For Sale
FS: KA24DE MAFS, Wheels, MORE!
FS: TiAL 38mm, Jacob's i.C.E. Pak Ignition system, Z31 T3/T04b V-trim turbo more
WDRacing
Porn Crusader
Online
1995 240SX, K5 Blazer
USA
11-25-2002
 « Re: exhaust manifold studs (Chezedik)
You do know this thread is Ancient Cheze??
Truth is Treason in the Kingdom of Lies - Ron Paul
WDRacing
Porn Crusader
Online
USA
11-25-2002
I also added this to the sticky so its not lost forever.
Chezedik
1991 Nissan 240sx
Overland Park KS
12-17-2002
No, I wasn't paying any attention. I was wondering why it said that Ant still wasn't turbo, hasn't he been running that T25 for a while?
Still I am in KC, and so I am about 20 min from him and would like to pick up a spare motor.
C-Kwik
2004 Nissan Titan LE Crew Cab, 2005 Honda CBR600 F4i
SoCal CA
8-2-2002
Well since it was brought back from the dead, I suppose I'll add a bit of info.
I won't say not to do this, but if you are beaking stock studs, you should consider why before thinking a stronger stud is the solution. The stock studs are plenty strong for anything you can throw at it under normal use. Overtighteneing or perhaps breaking one free when siezed will probably be a couple of conditions that can cause this. But the ones that mysteriously break by themselves is likely attributed to a side load created by the expansion of the exhaust manifold (whether its the stock or a turbo mani). Generally, the holes for the studs in the manifold need to be bigger on the outer ends of the manifold or it can put stress on several studs. You'll probably find few aftermarket manifolds that are drilled out this way for you. This type of probalem will sheer just about any stud.
"Bad Driver's Famous Last Words:
Watch This!
eazye2000
Booze Hound
of FAIL...
Inverness FL
6-27-2005
Yeah, while we're at it..
I have a KA24DE block and the M8x1.25 studs don't fit in the exhaust side of the head for me. They just kinda dangle around in there. I DO however have some M10x1.50 bolts and they're the right diameter, but the thread pitch is wrong. So I'm thinking M10x1.25 maybe? The M10x1.50 bolts have a much more coarse thread than the stock bolts(studs, whatever) So either M10x1.25 or M10x1.75 (if there is such a size)
Just my $.02
*EDIT* The exhaust manifold side of the KA24DE head are M10x1.25
I really hope noone goes out and buys the M8's because they are too small. Unless it's for a SOHC, then I have no clue what thread size they are.
Modified by eazye2000 at 11:39 AM 1/26/2007
Car is For Sale: http://forums.nicoclub.com/zer...56205
GTR PrYdE
1993 Nissan 240SX, 2003 Evolution VIII
La Porte TX
6-5-2005
 « CHEAP OEM STUDS FOR KA24DE!!!
Yes they fit!
Head to Exhaust Manifold:
- Studs: Toyota Part# 90116-10017... MSRP: $2.06/ea... QTY: 8.
- Nuts: Toyota Part# 94180-41000... MSRP: $1.49/ea... QTY: 8
http://www.trademotion.com/par...14074
I ordered 8 studs only and it costed me 20 bucks shipped, and they fit perfect. I got the nuts from autozone for like 4 bucks. Not bad at all!!!
thanks to IMperfection on ka-t.org
KA-T DD as of 6-01-2009
tommypaton
1990 240sx KA24E-T
Bremerton Washington
2-26-2008
 « Re: CHEAP OEM STUDS FOR KA24DE!!! (GTR PrYdE)
I have the SOHC and my 2 of my studs broke and I am already turbo. Does anyone know the right size for me? We are talking about the studs that stick out and a nut tightens down to them, not the bolts that just screw in the top holes right?
http://www.racingtown.synthasite.com/
for sale: front and rear 90 hatch bumpers with foam and supports
kouki_hmongster
Want 97 kouki
Pomona ca
6-21-2008
 « Re: CHEAP OEM STUDS FOR KA24DE!!! (tommypaton)
i think the previous post already answered your question. studs are studs and bolts are bolts. so when they talk about stud its threaded only and maybe a plain spot in the middle. bolts have a nut at the end.
i think the kade and kae use the same exhaust manifold stud from the head to exhaust manifold. if you are afraid you can call up dealer and get a part number and compare it to previous post.
JDS Performance
NICO Sponsor
Online
Charlotte/Concord NC
6-4-2006
 « Re: CHEAP OEM STUDS FOR KA24DE!!! (kouki_hmongster)
Lets bring this back from the dead.
OK so for the KA24DE S13 and S14;
Exhaust manifold studs are M10 X 1.25 thread pitch - and the other end of the stud is whatever nut you want to use basically.
Ok so now what about the head bolts and main bolts - whats the size and thread pitch on them? Also what about the rod bolts/nuts?
I would love to get a cheaper alternative to ARP as the full kits will be around $275.00+ plus shipping and thats a bit steep for some fastners IMO.
If I had a bare block laying around I would find out and post it all up but I do not at the moment!
http://www.240SXTECHDVDS.org
Xise
89 S13 Coupe
West Warwick RI
8-7-2009
 « Re: CHEAP OEM STUDS FOR KA24DE!!! (JDS Performance)
ressurrecting this thread again
when i searched for the size of the studs, at autozone and a few other places listed the size as M10 1.50 x 52 mm. I searched the cataologue of the manufacturer and they also listed both the ka24e and the ka24de as using these studs.
couldn't get the size of the studs from courtesyparts.com though they didn't list it.
I just ordered the studs from autozone, they come with the nuts and I am just going to get some generic bolts and some washers and i can bolt my headers on finally.
also does anyone know the wrench size for the ka24e egr port on the top of the exhaust manifold? some tell me 24mm wrench but i tried today and split my finger open, is it 23mm?
C-Kwik
SoCal CA
8-2-2002
I usually just went to the dealer for the stus. They usually had them in stock and weren't all that expensive (after you add shipping to a set of studs online, it probably gets pretty darn expensive).
While ARP studs are probably pretty good, there isn't any specific reason a OE stud should fail on its own. If you are running a turbo manifold, make sure the holes are drilled properly so that it allows for expansion. Not soing so can easily shear off a stud.
Xise
89 S13 Coupe
West Warwick RI
8-7-2009
 « Re: (C-Kwik)
Quote, originally posted by C-Kwik »
Well I am keeping my KA NA, just wondering aboutt eh size of the bolts b/c what was origionally posted and what i found were different, can anyone confirm the actaul size of the bolts?
WDRacing
Porn Crusader
Online
USA
11-25-2002
 « Re: (Xise)
So you're switching from studs to bolts? Take a stud out, drive to Ace Hardware and tell them what you need. Done and Done
480sx
Angry Hippie - Gone but not forgotten.
1996 Pearl White 240sx
Northern Va
11-12-2006
 « Re: (C-Kwik)
Man, that statement carries no sustenance. ARP studs are a great freaken move if you have the money and the means to install them. For instance, if your pulling your motor apart and you have the head off AND the money to spend, ARP hardware is just cheap insurance. Except when it comes to main studs..
I have literally broken and removed more than eh.. 5-6 studs from Ka heads. They are sometimes a b**** to get out. Aluminum and steel heat cycling together... (i stripped 6 ka heads and scrapped them.. money for trash thats taking up space? Sweet![truth be told, iv only broken.. two studs on my mannyyy motors(tht powrd my car..) lol. Its always either the top right one that breaks or the bottom left.])
What you have to remember is this. The OEM studs while being high quality, were NEVER intended to see the kind of temperatures that a turbo manifold creates. Even if they are torqued perfectly, that many extreme heat cycles fatigues the metal. Same is true with the ARP studs, but they are designed for the extra heat.
Modified by 480sx at 12:33 PM 8/18/2009
Victoriam mere
Xise
89 S13 Coupe
West Warwick RI
8-7-2009
 « Re: (WDRacing)
Quote, originally posted by WDRacing »
KA24E sohc has 4 studs AND 4 bolts, I just got the4 studs and nuts from autozone, and then i am off to ace hardware to get teh bolts and the spacer yoke washers.
also does anyone know the torque specs for tightening the studs and bolts?
WDRacing
Porn Crusader
Online
USA
11-25-2002
 « Re: (Xise)
My bad yo
Also, I've probably installed 100 various manifolds throughout my life. Never once used a torque wrench Anything critical gets torqued, everything else gets tightened. Not saying this method is best for everyone, but I've yet to break a stud.
WD
Xise
89 S13 Coupe
West Warwick RI
8-7-2009
 « Re: (WDRacing)
yea i mean unless your inside the motor I guess it's not that important it be torqued to spec, Some people told me if I didn't I would either break a stud or have an exhaust leak, thatnks for the quick reply though...besides i don't even have a torque wrench anyway
C-Kwik
SoCal CA
8-2-2002
 « Re: (480sx)
Quote, originally posted by 480sx »
I'm not saying its a bad idea. Just no reason to go out of the way to get them. For the most part, I would have to hunt for a set of ARP studs or find them online and have to wait and pay shipping. Where as I can simply go to the Nissan dealer and buy a set of OE studs which from my experience are generally in stock.
This is exactly what I was talking about preventing in my previous post (I wanted to elaborate but I had to get going). With any exhaust manifold, especially those that see higher heat (thus greater expansion), you have to drill the holes towards the end wider than those in the middle (the holes on the end will displace the most under expansion; which is likely what was happening when yours broke). Well made manifolds exhibit this trait. I assume you have Maximum Boost. It talks about this specifically and that a manifold can shear off studs. Part of the prep work I put into the revhard mani I used with my turbo system was to enlarge the holes mto allow for expansion. I never had to replace any of the studs. The only reason I know of the availability of these studs is that the turbo-to-mani studs were the same size and the dealer was an easy place to find them. While a better stud may be able to resist being sheared off as easily, the better solution is to properly address the problem. If the manifold is pushing on a stud sideways its putting unintended forces on the head and manifold.
While I've never had a problem with them, if you are that concerned, ask for the ones for a 300ZX TT.
Somteimes its impossible to get a torque wrench on some parts. Especially with aftermarket turbo systems. The rev-hard mani wasn't designed with much, if any, thought to getting proper access to the nuts that secure it to the head. One or two nuts had to be put on with that end of the manifold away from the head and you had to bring the manifold closer to the head as you tightened the nuts. Otherwise, the runner would hit the nut and prevent you from even gettin a wrench on it. Even then, you were limited to using open ended wrenches on some of the nuts. Don't even get me started on the turbo to mani nuts. Lets just say shorty wrenches or a god send.
