So I was working on my car's rack and thought it would be a great time to compare the tie rod end of a Z33 and a stock Z32 one. Many people ask what the difference is and why it matters. Well, here are some pics and some reasons to why the differences matter.
Top: Z33
Bottom: Z32
Close up of the length difference.
This is the only difference between the two tie rod ends, the overall length of the tie rod.
Now, when does this difference matter? Either when you do ackerman changes to your stock knuckles (meaning fabrication work) or you are adding tie rod end spacers for more steering angle. The longer tie rods will not work with certain spacers because you run out of adjustment. The spacer will push out the tie rods, and you have to adjust the tie rod end to compensate for it by shortening it.
With a longer tie rod, you have the possibility of running out of adjustment and not being able to get your car aligned properly. So, when using spacers, a Z33 tie rod works best. If making ackerman changes or just running no modifications to your steering, then a stock Z32 tie rod works best.
I hope this helps those with any confusion. If anyone has any questions, post up, and I will do my best to answer/ explain.
