The dish is recessed into the piston like a bowl.flinterman2000 wrote:The dish in the pistons, are they humped or bowled dishes. In either case the compression space remains the same as the compression ratio is affected by the dish in the piston.
No. What I'm saying is in this case the combustion chambers are almost identical and that is why the dish is what changes the compression ratio. I can't remember how to calculate the volume of the combustion chamber. Learnt it in school back in 1986.seang wrote:
Are you saying that the volume of the combustion chamber doesn't directly affect the compression ratio?
Obviously, the KA-E head flows better than the Z head, especially on the intake side. Exhaust sides for ka-e and naps-z look very similar and you can even use a ka-e turbo manifold on a naps-z, even though the ports are a little different.breadbox wrote:So what does this mean in simple terms? ka24e will flow better?
At low rpms it will cause some problems but will prevent things like detonation and such like, regardless of intercooling at or above 30psi anywhere from 3500 rpm through out the range.seang wrote:I don't even hear about boosted engines going that low.
I think the early z31 turbo's had something around 7.5:1 or 7.8:1 compression, then they upped it a bit later on for, like you said, low end response.flinterman2000 wrote:
This had me laughing for real.seang wrote:A properly built single cam KA will be bulletproof. Love the ka-e. I still like the naps-z, too; but only as a friend.
Most manufacturers supply info on flow and a graph to show where the turbo spools out. No more boost. The trim sizes are an integral part of these diagrams, and will affect the size of intercooler and piping to use.seang wrote:One thing I lack on turbo knowledge is the trim sizes. I don't know s*** about that.
