simmode1 wrote:acslater9 wrote:Should you buy a car that has a kill switch? And can someone explain to me what is it.
Thanks
Tricky question. A kill switch is a way to wire up your ignition so that it won't start unless a certain protocol is followed first. They're a good theft prevention measure. But if it wasn't wired up properly, it can be a real headache.
Well, there's not much to wire wrong. And it's easy to fix, if they had a single working brain cell when they wired it.
A common way is to wire either the fuel pump relay wire from the ECU, or the fuel pump fuse under the hood, so that the wire comes into the car to a hidden or disguised switch.
I wired a kill switch to my fuel pump relay wire, and I regret cutting the harness - it doesn't provide the same function as pulling the fuse, when I'd thought it would also be useful for fuel work/diagnostics. If you cut the relay circuit, the ECU kills the engine, whereas if you pull the fuse, it will burn the residual fuel pressure off.
My suggestion is to be more skeptical if the owner did what I did, and tapped into the ECU harness. If I was to do it again, I'd modify a fuse to work as a plug, and run the loop into the cabin with an in-line fuse holder to make up for the lost fuse function.
Don't let him talk it up as a selling point - make sure that he knows that it's just more molestation, and lowers the value, when if you wanted one you could add one for a tiny bit of work on your own.
On the other hand, if the car's cheap and/or already heavily molested, who cares. I feel all bad about cutting my ecu harness, but it's mostly important that it's soldered, and every OTHER harness on my car was already cut, so who cares?
But it IS nice to know that if you flip it, it would make theft considerably harder, for anybody driving the car instead of hauling it away.
If you're still talking about the car in that CL link, go in guns blazing, the paints no good, theres a lot of damaged panels, including the quarter panels (which are a part of the unibody), it has the brown interior (I sort of like it, but for some reason everyone else hates it - list it's replacement as one of the necessary expenses that you will incur as the new owner) it's got an automatic (regardless of your swap plans, list it as a necessary expense), and all that. Shoot for under a thousand. If it's got a good motor with good compression, I think that'd be a great deal.
About the vinyl, haa yeah, I saw that..... there's some 240s in seriously hideous vinyl. Some people seem to use the fact that it's not permanent as an excuse to let their inner ricer out. I guess it's better than permanent rice
(I wonder if I could sell my self, and get a car business to sponsor my vinyl.....)
