NateB29 wrote:So after my last post I was going to try to get to the bottom of this starting issue. I figured next time it didnt start I would try to move it to Neutral again and see if it would start. If I was able to start it in Neutral after it not starting, it most likely would be the inhibitor switch (aka neutral safety switch). If it would not start in Neutral than most likely I could rule out a faulty Neutral safety switch, and most likely would in fact be my starter solenoid going out. However I have been driving it for the last 3 days and tried to repeatedly start it and stop it to the point that I felt I was unnecessarily wearing out my starter; but it starts up every time now. Im hesitant on just buying a new switch because they are about $100 and I am also hesitant to just buy a solenoid because of the work involved to get to the starter. Im sure this isnt a problem that will just go away forever, so when I do actually figure it out I will be sure to update this...
I've had strong suspicions about the neutral switch, too.
Since the Y33 lacks a "starter relay" per se, the Park/Neutral Selector Switch carries all of the current required to energize the solenoid coil on the starter:
It's fused at 30 amps, so it's definitely carrying a decent amount of current - and that sounds like a recipe for trouble.
Adding a relay would reduce the current flowing through the Selector Switch to just a fraction of an amp, ensuring that the solenoid coil got full battery voltage - even if the contacts in the Selector Switch weren't in perfect shape.
Incidentally, there is no way in hell I'd remove the starter unless I was 100.0000 percent certain that it was the cause of the problem.
