as a previous car audio/electronics installer, i
HIGHLY agree with what everybody here already said.
PLUS- the e36 doesn't have 6" (neither does any Q) in the rear. They are 4".. and you're not gonna fit a 6". There just isn't room. i promise. If you want more boom back there try these guys-
http://www.bavariansoundwerks.com/produ ... -Adapters/
It's the best you're gonna do for sound in the back.
The sound system in the BMW is complex and if you're not
great with wiring, it's gonna be a nightmare to integrate anything into the factory system, meaning deck also. The factory amp is in the trunk on the drivers side. It has a plethora of wires going to each speaker in the car. If you have the 3-ways up front, that's a little extra fun, because the only 3-way aftermarket speakers are pricey (Focal, etc). The 3-ways have 2 small speakers on the door and a 5.25 in the floorboard kick panel. Now each of these speakers is wired to the amp in the back, ALL CROSSOVER NETWORKING is done thru the amp, so if you do put an aftermarket amp on them, and don't design/implement a crossover for each speaker, they WILL blow. The head unit only feeds a LOW voltage output, so it requires an external amp. You can do a decent 2-way setup up front and swap out the rears, using the factory deck and an aftermarket amp. Not sure if you've replaced the deck yet, but if not... the BMW is by far the absolute worst deck to replace, simply because of the lack of space behind the unit. There is NO room in the 3 series.. they sucksucksuck... the car with the tightest space has the biggest aftmkt harness there is. It's possible, just not easy whatsoever.
When someone would bring in a BMW for an audio upgrade, we'd tell them up front "it's extensive and expensive".
Play with the Bose in your garage, don't waste your time putting them in another car. While being a 'good' sounding speaker, They CANNOT produce the clarity of a good aftermarket setup. It isn't physically possible, they (rears) are a one way speaker. All of the highs and lows play on a singular plane, which is a midrange cone. The cone is trying to vibrate at too many different frequencies that it just can't do all at once. You can't play a 12k hz note while playing a 50hz note on the same cone.
If you really want to upgrade the Bimmer, then do it right... i've setup some great sounding ones, and i've tried to help somebody with a budget setup. I'll never install another cheap setup in a BMW. It's too much work for downright poor quality sound.
