maxnix wrote:Didn't Andy say he uses 7K-10K interval? Someone did.
The previous owner's interval was about 6-7K on dino oil and my interval is 10K on synthetic. After wiping the cam there is no discernable wear only a different sheen. Looks pretty good for 227K miles.
Got the driver's side done also and about as troublesome as the passenger side. There are SO many brackets holding everything together, wires, plugs etc. Especially as compared to my Mustang which I think has one zip tire holding the entire engine harness in!
The big obstacle on the driver side is a bracket that holds the middle air housing section to the intake. This bracket is directly over the valve cover and has to be removed in order to get the cover out. BUT, the bracket is bolted to the intake with two bolts that are upside down and hidden from every direction. In addition, it has a bunch of hard vacuum lines brazed to it. I think you may have to take the upper intake off to reach them-for one lousy bracket. But I didn't
I simply pulled out my trusty saber saw with a metal blade and cut the offending bracket off. I thought about patching it back together after I got the valve cover off but after bolting the intake tract back in, missing this one mounting point doesn't seem too serious.
I'm likely to rig up a couple of extra connections elsewhere to further secure it. Hopefully pics will be up soon.
I've told this story before but it bears repeating. I replaced the engine in a Chevy P20 Stepvan (bread truck) and the manual stated that the entire front suspension had to be dropped and the truck lifted off the engine. Well- that wasn't an option. I decided instead to cut the top radiator support and pull it out the traditional way. It took me 2 minutes to cut it off and 20 minutes to weld it back (could also have been bolted back on). This as compared to removing 30 year one-ton truck suspension bolts and lifting a 7000lb? van in the air.
The proper way to do something and a correct way to do something are sometimes the same, sometimes different.
