blushbaby wrote:I have another question!!! doesnt make sense to create new threads so umm i heard that some hatchbacks have a nasty habit of the glass shattering when you lower the back.
true or false?
False.
I think this has happened in one single, solitary case.
My rear hatch glass didn't even break when I was rear-ended by a pickup. So they've got to be pretty damned strong.
Now, back to the CVT discussion -
"The more they overtake the plumbing, the easier it is to stop up the drain". If you are looking at efficiency in any mechanical situation, simpler devices in general lose less efficiency than complex devices.
Whenever you build a "machine" (by the most basic definition of the word), there is no such thing as 100% efficiency. Take, for example, a fulcrum. Simplest of all machines. The theory is that if you take a board and put it on a rock or some other fulcrum point, and have 4x the board length on the end you push down as on the end being lifted up, you get 4x the lift on the other end as you exert in force down on the push end. Not quite true. Due to imperfections in the fulcrum mating surface, flex in the board itself, etc... it's not QUITE 4x.
Now... a transmission is many many simple "machines" built into one piece. The more complex, the more pieces, the more efficiency you lose simply to the "number" of machines.
The CVT tries to counter the main inefficiency of the automatic (running in a less than optimal power band) by keeping is pulleys in a ratio that keeps the engine in its optimal power band. Unfortunately, in doing so, they have created a more complicated mechanism. Best-case scenario, a CVT will be a mild economy improvement over an automatic.
If efficiency (or acceleration) is your game, the 6MT is the only player in town. It is simpler than either automatic.
If you're looking for a super-smooth ride, the CVT is king.
If you're looking for a good price, but can't drive a stick, or don't WANT to drive a stick, then the 4AT is for your whip.
