xclusive build thread the road less taken
xclusivez32
Car: 1990 300zx 2 seater limo
tt engine build
2004 gmc serria
I just picked up a twin turbo engine so I decided it is time to start my build thread. Your probably thinking you didnt build anything yet if you just got a twin turbo engine. Sit back relax. This is my project car a 1990 300zx 2+2 na.
^This is the picture from the ad I seen when I went to look at it. Image
^The day I brought it home new years day 1/1/2009
This is where the fun began the car had 120,000 miles on her brand new tires and just inspected, the kid I bought it from wrecked it a month before I picked it up. Ran smooth just some ...... well there was front end damage. Image
This is where I decided to cut the support and replace it with a nose cut I picked up from a local import yard.
During this time while the support was out of the way I figured it would be good to do the 120k maintenance, this guy I knew that worked at a nissan dealship said he could do it. Thats where this went wrong. The belt slipped and all the valves were bent, needless to say "NO ONE" touches this car but me from now on. I found some freshly rebuilt heads from a tt for a good price never installed, sent them out to get milled and ordered new head bolts and other little hoses and other things you know how it gets when your buying parts. haha
New heads installed, I believe I was testing my new color scheme. Forgive me it was a few years ago now.
Test fitting there was tons of that. Notice the rocker that is missing in the corner of the picture. :tisk:
This is probably a year into this project and I lost my job. But the front end is almost completely fixed and the engine runs smoothly. Engine bay was painted black as well.
By this point I have come to far to not finish this project so I replaced the rocker panel because the t-top drain came off the little nipple in the rocker and for how ever long it was off, water kept sitting in the rocker rusting it out. Found some one parting out a car that was willing to cut the rocker off for me.
The interior was not in good shape 3000gt seats were put in there for who knows what reason and the rear seat is useless. So 2+0 interior? Why not?
Sorry for the small picture. This is still in the works I am going to have it recovered when I do my stock 300zx seats.
I did the body work getting all the little dings out and filling the spoiler holes shaving the rear wiper, rock guard and antenna. Then primered it. Image
Hoods open ^
New wheels, kyb adjustables with tein springs, powertrix front arms, used rear arms forget the brand.
stillen III sides and turbo III lip
Deciding on a color now and gathering some tt parts for my build.
xclusivez32
tt engine build
2004 gmc serria
I will get some pictures of my engine build as parts start to flow in. Hope you enjoy my story.
300ZXttZMAN
Very nice! Tomorrow ill add you to the list of build threads in that sticky at the top of the page.
painter69
Car: 1990 300ZX TT/swap 5sp 2-0
1995 300ZX convertible
Looking good
xclusivez32
tt engine build
2004 gmc serria
Thanks I put in alot of hard work to bring it back and this year is the first time I have had the chance to drive it.
300ZXttZMAN
Alright man I just added you to the sticky at the top of the page. :bigthumb:
TTkickedin
Car: 1991 Nissan 300zx TT 5 speed, t-tops, < currently in intensive care unit!
2011 MBTA BUS
This is an awesome display of ingenuity, persistence, and B/S/T. Great Build thus far sir. clean product came out of all that work, and the front looks like it lines up well! Any fitment issues we can't see?
xclusivez32
tt engine build
2004 gmc serria
Only one of the fender holes dont line up perfectly on the pass. side. other then that it is exactly the way it was before. It was my dream car forever, I found this really cheap so why not? The weather up here is pretty cold so working on it is getting tough but spring will be right around the corner.
xclusivez32
tt engine build
2004 gmc serria
I was making a list for my build and would like some opinions/comments
wisco 87mm
stock rods (?)
bottom end bearings
new main and head bolts (What can stock hold up to?)
gt2860rs turbos
740cc injectors
oem gasket kit
new na wiring harness
aluminum radiator (looking around for a good deal)
z1 chip (already have a na z1 ecu)
tt fuel pump
tt fly wheel and clutch (not sure what brand yet)
intercoolers (debating z1)
120k maintenance
The engine I picked up has the new style lower intake and 48p heads, I was told it is a 94?
I already have
z1 2.5 downpipes
stock intercooler piping
all silicone engine hoses
electric fan setup
I am looking to be close to 450-500hp
300ZXttZMAN
I am guessing the block is in good shape since your getting 87mm pistons??
Don't get stock head bolts. Get ARP L19.
Get a TT koyo radiator.
Get new style nismo 740cc injectors.
Not sure about the wiring harness since its a swap?
I wouldn't get an electric fan but that is just my preference.
xclusivez32
tt engine build
2004 gmc serria
I already have an electric fan setup on the car. The na wiring harness is the way to go since I have a na fuel pump controller, plus my na ecu is already chipped just needs a tt chip $50 from z1. thanks for the input
TTkickedin
2011 MBTA BUS
along with the 740cc Nismo's, get the 300 degree fuel rail while you're at it. My guess is that you'll want m0ar boost after 500hp anyway. Oh, and make sure you're tending to the suspension and braking just as well. 350z track rotors (or vr4's) braided brake lines, a good coilover setup, F&R strut bars, fender brace. These are all worthwhile investments.
how-to-install-fender-brace-on-a-300zx-t523464.html
xclusivez32
tt engine build
2004 gmc serria
I guess I should have posted my list of current mods.
z1 13" bbk with hawk pads
kyb adjustable struts with lowering springs
rear strut bar
powertrix fuca's
powertrix ruca's
Stillen catback exhaust with x pipe
egr delete
aiv delete
pop charger -probably going to a dual intake setup (selin)
Im sure there is more just cant remember, thanks for the input
xclusivez32
tt engine build
2004 gmc serria
So I have been collecting parts for my build, pictures will come soon.
As of right now I have a good na block with oil squirters and crank. Off the twin turbo engine I picked up I have 48p head with matching lower intake and hardware around the engine. rzt exhaust manifolds, solid motor mounts (z1), stillen intercoolers with ducts, cp pistons 87mm, z1 split down pipes 2.5, stock intercooler piping complete set. I also just bought some z1 throttle bodies. Anyone put these throttle bodies on their na? Might do that in the mean time while Im building my engine. Looking for some opinions on bearings for the lower end?
xclusivez32
tt engine build
2004 gmc serria
Image sorry for the crappy pictures
eagle rods
greddy ebc
z1 throttle body, the other ones is still packaged
have the ducts for them as well
stock bore cp pistons and z1 solid mounts
z1 split downpipes 2.5"
rzt manifolds just need alittle cleaning up
also picked up a selin translator and nismo 740cc new style injectors today. Other parts is complete tt valve train, obx boost hoses, and a few little things. :chuckle:
DCaff300ZX
Car: .
1993 CRP TT- Modified
Nice go-fast stuff, too bad about the pics... :sad:
raremotive
Car: 04 Infiniti G35
^ Agreed. Plenty of ambition and diy. Looks clean!
xclusivez32
tt engine build
2004 gmc serria
Thanks guys, when everything comes together I will break out the camera and get some quality stuff this is just pictures of parts. I am thinking about changing the turbos I want, I am looking for something the has very little to no lag because I dont really need a ton of top end out where I live "hill towns" What do you suggest? gt525? 535?
DanDrath
Car: 1990 Nissan 300ZX 2+2 TT
i like where your going with this :) So where in ny do u live?>
nick1809
Car: 1991 300zx 2+0 n/a slick top
this build takes place in NY ehh?? im intrigued.. and also interested to know where in NY you are (; haha.
xclusivez32
tt engine build
2004 gmc serria
I live 20 minutes north of Albany just past Troy
DanDrath
ooh thats to far for me to come help you :(
xclusivez32
tt engine build
2004 gmc serria
yeah one day we will have to meet up and take a cruise
DanDrath
yeah id like to get all the long island/ny people together one day this summer. Also wanna go on that east coat cruise that dudes setting up my z should be done by like the end of may or june so well see
Good luck! and back on topic
MOAR PICS lol
DCaff300ZX
Car: .
xclusivez32 wrote: I am thinking about changing the turbos I want, I am looking for something the has very little to no lag because I dont really need a ton of top end out where I live "hill towns" What do you suggest? gt525? 535?
The JWT sport 500's seem a good fit with what you describe for your turbo needs, and a set of low-mileage turbos are listed in the NICO classifieds...BigTDogg runs them among others, and unless you want gobs of HP they have gotten good feedback for the 400-450 HP range, with great torque as well.
xclusivez32
tt engine build
2004 gmc serria
Those jwt 500s are sold other wise I would have bought them on the spot.
nick1809
xclusivez32 wrote:I live 20 minutes north of Albany just past Troy
you're close-ish to me!!!!! :DDDDDD
xclusivez32
tt engine build
2004 gmc serria
picked up some jwt530 bb for a good price, I believe these will put me in my 500 rwhp goal with very little lag. Here are some pictures. Image Image Image Image Image Image
300ZXttZMAN
The twins look good congrads!!
Rager
Car: 1992 Nissan 300ZX 2+2
1999 Nissan Sentra
2004 Chevy Silverado
those sure are puuuurdy :boink:
