Ya, I totally understand that they fail.... but how do OEM sensors fail so soon? Shouldn't they be worth at least two years? I mean.. c'mon... WTF man? BTW... I cleared the code once already and it came back again...goody90q45 wrote:It's pretty easy to read codes on your Q with an OBD2 code reader. I would clear the code, start your engine for just a few seconds and then go back and read the codes again. If the KS code comes back that quickly then it's dead. You should also be able to ohm test the KS at the connector which on the 90-95 Q is on the passenger side of the plenum. Instructions are at Q45.org. I suspect that your MY will be the same as the 90-95 OBD1 engines.
Wiggler wrote:What are the chances that the ECU is not putting out the operating 5 volts to the sensor? If the actual sensor is testing ok in terms of Ohms, then it should be sending back 2.5 volts to the ECU, shouldn't it?
1.3 mV is just 0.0013 volts, which is essentially nothing. All your meter is picking up is just a small amount of random voltage, not the 5 volts which the ECU should be supplying to both of those pins.Wiggler wrote:
next, checked voltage from the ECU at the corresponding female ends of the engine harness connector, with ignition in "on" position...
left:
center:
is this voltage within spec??? It's not 5 volts but am I doing something wrong?
Again, your meter is just measuring a small amount of random voltage.
voltage at pin # 108 ignition on engine running position....
voltage at pin # 105 ignition on engine running position...
FSM says these voltages should be between 2.0 and 3.0 volts??? I'm way off unless I'm checking something wrong...
You mean the ECU harness?? yes.. the harness was plugged in and I managed to stick a wire through the outside of the connector and it was making contact with the metal crimp....Skibane wrote: Did you measure with the harness connector plugged into the ECM?
