ds08versa »
https://forums.nicoclub.com/ds08versa-u94940.html
Sun Oct 12, 2008 3:51 pm
run one pos(+) wire and one neg(-) wire into your box and wire to the pos and neg of one coil and the wire the other coil to the same pos and neg and you will have a 2ohm load. the amp will be fine at 2 ohm, and please don't turn the bass boost up, that is something we never do. if you have a good input signal from your head unit, you should only turn the gain, and even then you shouldn't have to that much.
