Wiring Specialties »
https://forums.nicoclub.com/wiring-specialties-u27774.html
Mon Feb 22, 2010 11:08 am
February 22, 2010
Wiring Specialties – the leader in Nissan performance wiring conversions since 2001 is proud to announce an unprecedented wiring product – Wiring Specialties Pre-Made Conversion Harnesses.
Each conversion set is available with a Main Engine and Lower Transmission wiring harnesses for the popular SR20DET, RB25DET and RB20DET engine swaps into the 240sx chassis. Through months of arduous research and development, each harness has been designed and manufactured to provide OEM fit and performance, and features our industry exclusive, Turn Key Start-Up Guarantee.
Finally, there is a solution to wiring headaches. Simply purchase a Wiring Specialties Pre-Made Conversion Harness, install it in under 20 minutes and be on your way. It is no longer necessary to send your harnesses out for wiring service, wait countless days for the work to be completed and still be left with a 20-year old wiring harness under the hood.
Each Pre Made Harness will save you time, improve engine performance, give your engine bay a factory look and comes equipped with our Turn Key Start-Up Guarantee!
-Brand new wiring and connectors-OEM routing and fit and finish-Improved grounding routing by addition of internal cross-grounding-OEM connector specs (no cheap aftermarket connectors that fall apart)-MAFS wiring shielded and routed through the harness-Greddy/Freddy manifold compatible-All A/C, Temp override, Auto On/Off functionality-5-speed and Auto to Manual swap compatible-OEM wiring connections and 'T' connections-NO soldered connections-S13 and S14 Speed Sensor compatible-Quick installation-Detailed Installation instructions
MORE IMAGES HERE
Pre Order your set Today!
Use coupon preorders13 for FREE shipping (Pre-order ends March 1, 2010)
Order here - Wiring Specialties Replacement Harnesses
• S13 SR20DET into S14 240sx – Available March 1, 2010• S14 240sx Transmission Harness (fits all SR engines) – Available March 1, 2010• S13 SR20DET into S13 240sx – ETA April 1, 2010• S13 240sx Transmission Harness (fits all SR engines) – ETA April 1, 2010
• RB25DET S1 into S13 – In Development - ETA May 1, 2010 • RB25DET S1 into S14 – In Development - ETA May 1, 2010• RB25DET S2 into S13 – In Development - ETA June 1, 2010 • RB25DET S2 into S14 – In Development - ETA June 1, 2010• RB20DET S1 into S13 – In Development - ETA May 1, 2010• S14 SR20DET Zenki into S13 – In Development - ETA June 1, 2010
