BBISHOPPCM wrote:No, they hacked it. I would request a new filler pipe.
Did you check under the hood of yours? Just curious if you did or not. If you did, thanks for taking the time to check for me. If you didn't, then I would ask you check under the hood before posting. Just to clarify, when you open the windshield washer fluid there is a long flexible plastic tube that snakes down the FILLER neck. The filler neck connects to the windshield washer reservoir. Where the windshield washer reservoir and filler neck connection, it looks like a spool of electrical tape is there connecting the two. Not 100% sure if that's what it is or not, but appearance wise, it looks like electrical tape.
Sorry to sound abrasive. But I don't know if you checked under your hood or not, and if you didn't, then you shouldn't post.
