kerrton »
https://forums.nicoclub.com/kerrton-u88348.html
Mon Mar 22, 2010 7:51 am
Update:
The wind noise on my car is still present, but I have ruled out a few potential causes and with the help of the dealer feel I am very close to solving this problem.
1) The two holes on the underside of the roof rails were covered, but the noise is still present.
2) I removed my driver's side mirror and applied foam tape to the mounting surface, but the noise is still present.
3) Discussed the issue with my service dept today, they said they were aware of some Rogue's making the "wooooo" wind noise, which sounds like it's coming from the main roof rails. However, my service manager feels the noise is not coming from the rails but rather the driver's door seal. He indicated that it's almost impossible to nail down the cause of intermittent road noises, but if we wait a while Nissan may release a TSB so we agreed it wasn't urgent and we'd discuss it again later.
So I had a look at the door and window seals on the driver's side and there's plenty of potential spots where some wind noise could be developing. The trick is, like Philip said in a previous post regarding his 03 Altima, is the fix has to be "carefully placed", or else I could go crazy sticking foam tape all around the door and window (which I just might do before this is over, it's driving me nuts!).
So I'm going to stick to the scientific method as best I can: keep everything constant and manipulate one variable at a time. I'll pick a spot to beef up the door seal, drive it on windy days and note if the noise is still present, if so, try another spot that looks like a likely candidate and keep going until problem is solved.
I'm going to be patient and it might take a while but I'll find the source of the noise. When I do I'll be sure to share it, and if I get lucky maybe Nissan will solve the issue for me, but in the meantime I'm going to be proactive.
