everything you posted is absolutely legally true.AZhitman wrote:Will using 'aftermarket' parts void my warranty?
No. An 'aftermarket' part is a part made by a company other than the vehicle manufacturer or the original equipment manufacturer. Simply using an aftermarket part does not void your warranty. The Magnuson-Moss Warranty Act makes it illegal for companies to void your warranty or deny coverage under the warranty simply because you used an aftermarket part. Still, if it turns out that the aftermarket part was itself defective or wasn't installed correctly, and it causes damage to another part that is covered under the warranty, the manufacturer or dealer has the right to deny coverage for that part and charge you for any repairs. The FTC says the manufacturer or dealer must show that the aftermarket equipment caused the need for repairs before denying warranty coverage.
By the way, this isn't really "news". This has all been in effect since 1975.
But, since someone in the community decided to dredge it up and report it as "news", I figured I'd share it with you all - it's good information to know!
Read more about it here: http://www.ftc.gov/bcp/edu/pubs/consume ... lt192.shtm
the problem is that you can't waltz into your local dealer spouting this.
it's the equivalent of telling a police office that they are wrong when writing a citation.
even though the law states that the onus is on the company to prove that the aftermarket part caused the failure prior to denying the claim.
this is not the case the manufacturer will state that the part failed due to the modification. such as an upgraded exhaust causing a rod failure. it's not an unheard of jump to say that the increased power caused the failure.
once this claim is made the onus of proof transfers to the owner of the part.
at the very least a lawyer may/will be needed to force the company to properly prove their claim.
this causes all sorts of headaches.
Mine never cared and even replaced a blown stock strut after an Eibach drop once.downedzephyr wrote:the nissan dealership that i go to really doesn't care that i have mods on my car, guess i'm one of the lucky few
+1sultan wrote:what's a warranty?
As someone who deals with warranties on a daily basis, that is the most improtant part of the quote.AZhitman wrote:Still, if it turns out that the aftermarket part was itself defective or wasn't installed correctly, and it causes damage to another part that is covered under the warranty, the manufacturer or dealer has the right to deny coverage for that part and charge you for any repairs.
That depends.dusred wrote:If I put a chip on my brand new Duramax it voids the warranty. Period.
I work doing mobile electronics for a living currently while in school, and you would not believe the kind of crap dealership "techs" pull out of their a** to get out of doing warranty work. anything and everything is caused by a radio installation, or remote start system... EVERYTHING apparently according to most dealers around here. it's pathetic because i can't tell if they're just complete idiots or if they are just trying to scam the customer..mdawg4x4 wrote:The stealerships around here try to blame every issue on the mods you have done to your vehicle. I had a auto transmission valve body go bad and stop shifting to drive. They tried to blame it on my Alpine HU. I asked them what the HU had to do with the transmission, and they tried to blame it on wire modifications in the dash, even though I used a wire harness adapter.
That only works on pre 2007 trucks. On the new ones the ECM logs the engine data so the dealer can tell if you've been running a chip.scotty-2-forty wrote:dusred wrote:If I put a chip on my brand new Duramax it voids the warranty. Period.Just remove it when you go in for service. I did this several times with my F-350's Superchip years ago; no problem.
If the dealer finds out you have a chip it voids the entire warranty. I'm sure you could spend $20,000 and sue them but it's not worth it and they have more money than you. On a diesel truck it will void the warranty. Period. A friend of mine designs and manufactures chips for a living but they don't add HP they just delete the stupid new exhaust garbage. If the power locks stop working you take it in for warranty and they hook their computer up and see that there's a chip on there they won't fix your locks. One has nothing to do with the other. Warranty = Voided from then on. If you wanted to sue them I suppose you could.PoorManQ45 wrote:That depends.dusred wrote:If I put a chip on my brand new Duramax it voids the warranty. Period.
A chip will put more stress on the engine and transmission.
Things like the suspension and chassis would not be affected. Those parts would legally still have a warranty.
Per the law,
Troof. The only dealer that didn't bone me was Infiniti of Scottsdale and they were just selling me parts. Each time I leave a dealer I feel violated in the a**. The local Ford dealer is the worse I've ever seen (St. George Ford, Lincoln, and Mercury). I've been there three times and each time swore I'd never go back.PapaSmurf2k3 wrote:Dealers will absolutely f*** you every chance they get.
PapaSmurf2k3 wrote:Dealers will absolutely f*** you every chance they get. The following letter is a completely real life letter that my s*** lawyer got from the s*** Dobbs Honda dealership. 100% of it is BS pulled from the asses of... ***holes.
Can you get away with it? Yeah, probably, but not after a s*** load of legal hoo-hah.
Note: My car does NOT have an aftermarket header, nor did they replace any of the bolts, nor did they even heat them up. bullsh*t. If they can make those claims on someone that has a totally stock vehicle, they can make it on a modified one.
It is all about cost containment and profitability. Then there is the new car ratings and owner satisfaction reflected by warranty work. No paperwork, no issues.zerepdivad wrote:I work doing mobile electronics for a living currently while in school, and you would not believe the kind of crap dealership "techs" pull out of their a** to get out of doing warranty work. anything and everything is caused by a radio installation, or remote start system... EVERYTHING apparently according to most dealers around here. it's pathetic because i can't tell if they're just complete idiots or if they are just trying to scam the customer..mdawg4x4 wrote:The stealerships around here try to blame every issue on the mods you have done to your vehicle. I had a auto transmission valve body go bad and stop shifting to drive. They tried to blame it on my Alpine HU. I asked them what the HU had to do with the transmission, and they tried to blame it on wire modifications in the dash, even though I used a wire harness adapter.
