You will actually probably spend more money going through a few junk units the next couple of years than buying the Cardone remanufactured one. Have you called Joe for a price?subtle_driver wrote: i will just save some money to buy it from the junkyard. thanks.
im gonna try that fast sofware, looks kinda annoying how it is installed, not easy for lazy people like me. I used to work at nissan, and it was not easy to use. anyway....the abs module thing looks so simular and the brake lines are in simular locations and they have the same number of brake lines going into it and the electronics are the same and the connectors are the same. so i thought surely someone has done this before! but no its kinda a gamble, cause the unit will cost me $150 and i don't know how it will turn out. but if it does, this unit looks like it is a better design than the older unit. but at the same time someone says that the seals are better on 1991/92 units? if that is true, i might as well just go with one of those.Q451990 wrote:It appears that Joe's price is about $1350, while a Cardone unit from Advance Auto is about $550. I would check a few other places if you decided to go remanufactured... I know Pep Boys was greatly cheaper than the others in 2000 - who knows what the case is now.
Subtle - I think the only way to answer your question about replacing with a 94+ style is to download FAST (Nissan's parts software) from http://www.phatg20.net and then compare all of the brake parts from your car and a newer car to see which part numbers are different.
In over 10 years of very active membership in this forum, and the yahoo forum before that, I have never heard of anyone doing this conversion - not saying it can't be done, or hasn't been done - but if it was common and easy I think I would have heard about it. Looks like you get to be the guinea pig!
Good luck and keep us posted!
Heath
uh oh, i totaly just cut those lines....I read your earlier post that says you used the lines from the bmc to the abs unit. and you bent the other lines... so i cut the other lines and took with me the lines from the bmc. i guess im screwed now. so you can't reshape the lines coming from the calipers to fit the new unit?mattd1979 wrote:When you get the ABS pump, you will see 3 lines coming in at the top. You want to get the 1st brake line and the 3rd brake line that goes in at the top closest to the fire wall. You can reshape the line that goes in the middle of the pump. That line goes to the left front wheel. The 3rd line goes to the rear brakes and the 1st line goes to the right front wheel. You will not need the entire brake line that goes to the rear. Just after it exits the inner fender, there is a junction block. You disconnect it there. Hope this helps.
