McAdam »
https://forums.nicoclub.com/mcadam-u5096.html
Mon Jun 30, 2003 4:00 am
I actually measured the distance shock tower to shock tower in a Z32 and an S13. the S13 is wider by about 3 to 4 inched up top and a lot wider down low, near the cross member. The Z32 uses a double A arm front suspension that takes up a lot of engine bay room and makes things apain to work on. I wanted to do this swap to, except use a VG30DET out of a nissan CIMA. single turbo and a lower intake plenum, should clear the hood of a 240sx just fine....
McAdam
