Intake, exhaust, fuel injection, sensors, driveshaft, transmission, clutches, flywheels, manual swap components, differential, axles, cooling system, ECU, forced induction parts, catch cans, complete motorsets.
WI: GA16DE turbo motor, clutch flywheel/MotoIQ old build
Postby nismos13silvia » Mon Jul 23, 2012 10:40 am
Email me at nismos13silvia@hotmail.com for FASTER REPLY.
Too be 100% clear. I have not used this motor . I bought the car for the shell. Original owner is a good guy on the forums. I can provide you with his contact info as well. It is being sold as is by the words of the original owner. With that said, I have seen this motor preform in person.
-Motor $450
"GA16DE with 87K original miles.
Stock bottom end
Head is ported and polished
Swain coatings on exhaust ports, combustions chambers and valve faces
Assembeled with head approximately 5k miles ago with new OEM head bolts and updated GA16DE head gasket
Oil pan is tapped for oil return and oil temp gauge
-Flywheel & clutch combo $450
JWT lightweight flywheel with extra friction surface
Dual Sprung JWT PP
JWT metal one sided disc."
Make offers
-Starter
-Alternator
-Axles
Willing to separate as well the head and block.
nismos13silvia
Re: WI: GA16DE turbo motor, clutch flywheel/MotoIQ old buil
Postby nismos13silvia » Wed Aug 08, 2012 4:22 pm
bump
nismos13silvia
Return to Engine / Drivetrain (for sale)
