killernoodle »
https://forums.nicoclub.com/killernoodle-u129627.html
Thu Oct 29, 2009 5:49 am
Ok peoples, I see a lot of you guys buying bolt together roll cages for your car.
This is why you shouldn't cheap out on getting an actual roll cage:
Before:
A crash:
Now notice the roll bar tubes punched straight through the body:
Need some syrup and butter on that pancake!
Occupants were fine and walked away thanks to helmets and good racing seats.
Just a reminder that if you're gong through the trouble of installing a cage and racing, get a REAL cage that welds into the car, made of material that is at least .095" thick (for 4340) or .120" (for mild steel). Make sure the mounting plates are at least the same thickness and as large as possible, put on top of the actual frame if possible. Tie in the tubes to as many points as possible: on the roof pillars, the sides of the door supports, whatever.
Don't cheap out on safety, and for god sakes no bolt in style cages!
