Why?
tmorales509
Car: 1991 nissan maxima gxe auto
I check my oil all the time and its always good. Well today i cheked it and it was pretty much completely empty. Wasnt even showing on the dipstick. So i put a quart in and its still not showing. Where did all my oil go? I looked around and didnt see any leaking. Im thinking of changing the valve cover gasket. Tomorrow i wil get a better look considering is was a little dark out. I also read it could be the piston rings? Well im hoping its just leaking thru the gasket because i think the piston rings are quite expensive, well more than the gasket anyway. I also remember one time i took one of the spark plugs out and there was oil in it which im guessing is a indicator of a worn gasket?
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
How long/how many miles since your last oil change?Any fresh oil stains under the car?Is there smoke in your exhaust?
Buy a compression tester at your favorite auto parts store. Minimum acceptable compression is 145psi, with nominal at 185psi. There should be no more than 14psi difference between any two cylinders. If you have poorly sealing piston rings or a leaky headgasket, it'll show up as poor compression.
tmorales509
Well i think i might be due for oil change, i think its been a few months or getting there since i last changed it. Fresh oil stains, i havent noticed yet, im gonna put some oil in and put a piece of cardboard or something under the car to check it. And smoke i dont think so but once again i havent noticed. I will get back to u in a hour or so.
tmorales509
Man it took 2 1/4 quarts of oil to bring it to normal level. Anyways im just gonna wait awhile and see if any oil leaks, i put a piece of cardboard under the so i can tell. Also i have one of those compression testers but im guessing i'll probly need someone to help with that? Do you have a a guide or something that shows how to do it. I read one but it was for a different car, but im assuming its kinda the same.
lightsout
Car: 00 Nismo Maxima SE
i'll bet you're burning it up b/c of worn out rings
tmorales509
Im guessing if i change the rings im gonna have to change the gasket also since i have to take off the valve covers? Man i swear with this car! If its not one thing its another, I just had to order another window regulator as well after it broke saturday. Well if it is the rings i probly wont be able to change it till next month cause i have no money right now.
lightsout
tmorales509 wrote:Im guessing if i change the rings im gonna have to change the gasket also since i have to take off the valve covers? Man i swear with this car! If its not one thing its another, I just had to order another window regulator as well after it broke saturday. Well if it is the rings i probly wont be able to change it till next month cause i have no money right now.
the passenger window regulator?...mine went bad too. Whatever you do, don't buy a cheap window regulator from EBAY...i got robed, lol.
keep poking around your engine compartment until you find a leak somewhere b/c maybe it only leaks when you drive. If your 02 sensors throw a code it's probably b/c they are getting covered with filth...but it could be something not so serious, so don't get descouraged. We are here to help you figure out and fix this problem with your MAXIMA!!
tmorales509
Oh really? lol yea my passenger side too :D but ive actually bought 2 before, i had to buy the driver side as well a few months back. I did get it on ebay :/ with no problems. Now back to the car, i will check it in a bit.
tmorales509
Also forgot to mention there is no smoke coming out of the exhaust either.
MCovington
Car: 1995 Q45
replacing the rings on the piston is a major job. I did it on my motorcycle and what a pain in the butt. Wouldn't even dream of doing it on a car. Too many small details to follow. Check the compression or have a leak down test done.
tmorales509
Yeah it is quite hard i think. But i talked to my dad about it, he is kind of a mechanic, does it as a side job and he said its probably not the rings because there would be some smoke which there is not.
NutriaforBreakfast
Car: Nissan Maxima 1995 VQDE engine
See if there is oil in the antifreeze
tmorales509
Nope there is not.
NewDad=4drs
Car: 03 I35
Is there oil in your windshield washer reservoir??!!
bigdaddydog21
Car: 91 nissan maxima
dude how would oil get into the washer tank?
Presscott707
Car: 1999 Maxima 5spd
do you have a intake on the car. if you do check the line that comes off of the front valve cover and see if the intake is pulling oil from there.
tmorales509
I do. I will go check. Just to be curious, what does this mean if it is puttling oil thru that line?
tmorales509
Presscott707 wrote:do you have a intake on the car. if you do check the line that comes off of the front valve cover and see if the intake is pulling oil from there.
Well not a full intake,i just have the cone filter. Do you mean the hose that comes off the valve cover and goes into the pcv valve? If so then yes there is oil in there Or would that be the rear valve cover. Whats the front? the side closest to the windshield or furthest from it? lol
tmorales509
Or wait or do you mean the hose that comes off the valve cover and goes into the intake manifold? I guess that would make more sense. Well yes it looks like there is a little bit of oil being sucked in it. What does that mean? is it really bad i hope not!
Presscott707
first i would like to say sorry to allensteiner for taking this pic.this is the line im talking about. my car was sucking oil from there into the intake. so i put a breather filter on the valve cover and close the hole on the intake.
tmorales509
Oh my car is a gxe has the sohc vg30e motor, looks different than that. There is only 2 hoses i see. 1 comes off the valve cover and goes into the intake manifold(i did see a little oil in the hose). And there is one that is directly on the intake but it goes into the iacv i think. Let me see if i can find a pic.
tmorales509
cool i had a pic of my actual car from cardomain :D here is the hose i see. #1 goes from the front valve cover to the intake manifold. #2 goes from the intake to the iacv and #3 goes from the rear valve cover to the pcv valve.
maxhopper
Car: 02 Maxima SE 6spd
From the looks of your picture, it would be #1 or #2.
tmorales509
Yea probably, I chekced #1, it did have some oil, not alot but a little but. I will check #2 tomorrow. I think i might just get one of them breather filter, they look cool plus they help ur motor out :D. How do i put one on? Just put it on the valve cover part then cover the other hole? I seen a maxima on cardomain and he has 2 of them breather filters, one on that #1 hose and on the #3 hose. But the pic is kinda small so i cant see how he put em on.
Presscott707
my bad i was thinking that you had a newer maxima like a 95 to 99. im sorry.
lightsout
have you been able to jack up your car and take a look under the engine and tranny? if not, do so. obviously look for leaks or any oil, dark, grimmy areas under the car. take pix and post here.
tmorales509
Ok will do. I need to get a hold of a camera though so it wont be till later probly.
tmorales509
Well i wasnt able to get a camera yet but i did look and it looks like there is a lot of oil build up around the oil pan and it looks like on the transmission too. Hopefully i can take pics later.
lightsout
do you have a camara phone?
u can purchase a cheap disposable camera and have it developed at walmart with a CD of all the pix!
my guess so far is the both the engine and tranny oil pan gaskets are old and corroding.
tmorales509
OK, i got a camera, here is some pics i took.
This is the Oil pan.
Some thing next to the oil pan, You can see the oil dripping :/.
Transmission
A pic from up above, behind the rear valve cover
Around the oil filter area
The dipstick showin normal, since the last time i put oil in like a week ago.
Modified by tmorales509 at 2:52 PM 9/14/2008
