madbouncy »
https://forums.nicoclub.com/madbouncy-u15966.html
Sun Dec 12, 2004 11:16 am
If the car steered with the rear wheels, then wouldn't your back end go into the other lane when you turn? I can't really explain it, but if you steer with the front wheels, then the back of the car tries to follow the front. But if you steered with the back, you would need a wider area because like you've said, your rear end swings out. I knwo at work the jacks steered with the rear, it was annoying as hell in tight spaces because to make the tight turn at low speeds, your front barely moves forward but your backend has to swing way out, which always ended up hitting stuff.
