crisfer wrote:Why doesn’t the service manual indicate when you need to service the 7speed automatic transmission, when to change the power steering fluid, differential fluids, and brake fluids or change drive belts?
It first mentions to change the engine coolant at 60K but after that every 30K so at 90k 120k.
I would just like to know when I should change replace these fluids?
Mine is very precise
crisfer wrote:Why doesn’t the service manual indicate when you need to service the 7speed automatic transmission, ....
If you have a 7 speed auto read the footnotes
crisfer wrote: or change drive belts?
Did you read the 60k mile service page?
On my previous 06 G35 the belts were replaced the same time the plugs were replaced at 106k miles alsong with the coolent.
Telcoman
