TheOne »
https://forums.nicoclub.com/theone-u18820.html
Wed Feb 01, 2006 9:29 am
either you went low on oil or your oil pump just stopped working(mine did after ~185k miles, or maybe it was 1 of the seals that helped it suck oil), but now that yer motor is knocking, especially @ 2-3k rpm's, that most likely means the rod bearings are bad and need replacing, maybe the crank is bad too now.
btw my engine ran fine till 1 day i revved to 6k rpms and the oil light came on:), then i got rod knocking and the cam journals in the head got messed up from low oil.
