A founding precept of this Forum that many new members don't understand until several used parts have failed.jonseyq45 wrote:...before any further diagnosis can procede you need to replace all bad parts with known good parts. I say known good, because a new part can be as defective as a used one.
With carburation. it is all abouit jetting to air density. Why all cars are fuel injected now to meet ideal fuel air ratios acroos all seasons, temperatures, and barometric pressures.oldmako wrote:Even the lamest, carbureted engine will produce more power on a cold day than a warm one due to the differing air density.
Actually that's one of the tricks companies use to make their product look better. They dyno the stock setup when it's hot and then then their product on a cold engine and that's where a majority of the power comes from. It's only a few hp and it's only from the engine not being heat soaked.maxnix wrote:
As far as an engine not upt to operationg temperature being more powerful, I just don't think so.
Jonsey, thanks for that great explanation.jonseyq45 wrote:There are basically 3 types of operation in fuel injection.
Open loop and Closed loop.
Fuel injection is a feedback system, that is, it reacts to current conditions, load, and temp. When first started it is in Open loop. It is running on predefined values in the ECU. Only after the engine has reached a predifined temp will it go out and start reading the different sensors. Now it is making choices based on the input it gathers. This is called closed loop.
The other mode is seldomly used, its called get home mode. This is used if one of the sensors has failed and will use a value stored in ram to replace the missing data. If you have a bad O2 sensor, it is using this value.
Now these values are only to keep the engine running well enough to get home and allow repair. A properly working O2 sensor is needed to get the best performance. The value used when first starting up is different than the get home mode, it is based on mapping reflecting the warming up of the engine and that's why it runs ok while cold. It tends to be on the rich side, like a choke on a carb. Engines like rich alot more than lean.
I hope this helps. Get the sensor changed and you should be in Fat City.
Except for many of those who rent (and therefore pay by the minute). Their goal is to get going after all. Fortunately air cooled engines are wonderfully tolerant and designed to withstand sudden, and significant temperature excursions, as well as sloppy and careless technique.maxnix wrote: Notice that no pilots take off before engines are up to operating temperature.
I didn't recall that ever being asserted before, so thanks for the clarification. I remember the old Rochester fuel injection used on SBC. Sprayed continuously into the plenum. So kluge.Q45tech wrote:The Q doesn't use simultaneous at WOT
OMFG. I asked the same question MONTHS ago and all I got was nonsense.paranoidjack wrote:Do any of you guys have the same feel? My Q now has 140 on her, and it seems the throttle is much more responsive, the tranny shifts snappier and better, and just get a sense of more power when the motor is not fully warmed up.
Of course, this is not the time to be beating on the motor, but sometimes I can't resist since it feels so much quicker when cold. Does anyone else have this problem?
It's not as if the car is slow when warm...but it just feels generally sloppier. I have an o2 sensor that is bad that I need to replace though, maybe this has some bearing on it...
Again, I'm not talking about ambient temperature. I feel no difference in the suspension. I am speaking solely about throttle response, and yes, the tranny does seem a bit "snappier." Normal for many cars when cold...I'm referring more to the acuteness of the power response.Haitian_King wrote:
I don't even have to be tough on the motor, it does it by itself. The suspension seems nicer and lessens the road noise, the tranny shifts like brand new, the throttle is ultra responsive. I wiggle my toes and the car is flying. It feels like it just wants more.
At warmer temps, i get the same issue. Yesterday at 59 degrees, the car was great, but later on, it was a little sluggish. I get what you mean about sloppy. The acceleration just isn't there from the beginning as opposed to when it's operating well.
Well, I do notice the change in suspension, but then again, I have a G50.paranoidjack wrote:
Again Haitian...I think you're referring to colder weather, I'm referring to colder oil! But I'm glad we're in agreeance, if only at least partially.Haitian_King wrote:
But yes, throttle response and the way the pedal feels changes (at least to me) in colder weather. Usually below 40.
The increased throttle response tempts me to really cut loose, but better judgement prevails and I don't run the cold engine as hard as I crave to on those nights.
Thanks, no. I've married myself to rehabbing this whole car with OEM parts, from OEM shocks/brakes to small missing screws I find here and there.qsiguy wrote:Nobody's asked so I will, have you modified your intake system? For a while I had a cone filter directly attached to the MAF and there was a very noticeable change in performance within the first 15-20 minutes of driving after the engine bay was warmed up.
Even with the stock system the engine and intake plumbing will get heat soaked after a while and increase intake temps which will decrease performance some.
Well, cold weather is the only sort I've been getting until recently. (62 today)paranoidjack wrote:
LOL, I have an i30 and understand what you mean. Forget the outside temp, when I start the engine and the and the engine itself is cold, it drives great. It's not so fast after warming up.paranoidjack wrote:Do any of you guys have the same feel? My Q now has 140 on her, and it seems the throttle is much more responsive, the tranny shifts snappier and better, and just get a sense of more power when the motor is not fully warmed up.
