float_6969 »
https://forums.nicoclub.com/float-6969-u780.html
Mon May 07, 2012 5:38 am
First off, I don't think the issue is HG related. Look carefully at the area where the oil is leaking. Are you SURE it's the HG and not the valve cover? It's more likely to be the Valve cover. If it IS the HG, simply replace it with a Felpro and be done with it. I've used them for years and seen absolutely no reason to use an MLS gasket.
As for the engine running issue. This seems to be a weak spark issue. From the look of the plugs, it's in the #2 cylinder. There are a few things that can cause a weak spark. I'll start from the plug and work backwards.
First off is a fouled plug, which you obviously have. You did get the plugs replaced, right? If so, pull the plugs again now and see how they look. I'd be willing to bet that the #2 plug is starting to foul again. If it is fouling again, then we need to move on to the next step.
Second is weak spark source. This is caused by either a failing coil pack, or igniter. As load increases (more throttle) demand on the ignition system increases. So a coil/igniter that will work at idle or part throttle, will stop firing, or fire later than it should under load. You should be able to determine this by unplugging a coil, one at a time, and see if the problem gets worse, or stays the same. I would be willing to bet that if you start with the #1 coil, it will barely run, or will just die. When you unplug the #2, the idle will drop, but when you rev it, it will act about the same as it does now. If that's the case, then the #2 coil is bad and needs replaced. If this doesn't happen, then you need to replace the igniter. When the igniter fails, it doesn't supply enough current to the primary windings of the coils. When this happens, the coils produce a very weak spark. It's usually enough to ignite at idle and light load, but not enough for heavy load.
Last is combustion contamination. What this means is that there are limits on what AFR's gasoline will ignite at. If there is too much or too little fuel, the mixture becomes very hard to ignite, or simply won't ignite at all. This is usually caused by under or over fueling. Based on your symptoms, I would guess over fueling. Probably from the #2 injector. I know you ran injector cleaner though it, but if you have an actual piece of debris holding the #2 injector open, no amount of injector cleaner will remove it. Part of the problem with having a vehicle sit for long periods of time is that the fuel becomes corrosive and will deteriorate the surfaces of the fuel system. If this happened, you could literally have a piece of the fuel rail lodged in the #2 injector, holding it open/shut.
