I start thinking about this stuff yearly before I make a 6 hr drive across the desert at the hottest and dryest time of the year...
My car now has 41K on it... I bought it with 30K on it. I run synthetic oil.
*Has anyone changed their rear differential fluid?
*ATF fluid?
____Drain and fill or Flush? (I took the engine cover off to get to the dip stick and the ATF fluids looks clean and brand new still)
*What about radiator drain/fill? Looks pretty clean in there too
*Brake fluid?
*Power Steering Fluid?
The dang maintenance manual has both extremes... either change it all the time under PREMIUM or just check it under the the other two service interval options. Just looking for REAL world experiences and if it ended up being a good thing you changed it, or it if ended up just confirming that the fluids still look good... (oh, and at what miles did you do it or skip it)
This is one of those posts that EVERYONE can / should reply to... Just answer NO if you haven't (and why) and YES if you have (and when)...
Don't just lurk...
as a lifetime fluid. For most systems it is the very first fluid change that is most important in the overall life if a car.
