mrmarbles »
https://forums.nicoclub.com/mrmarbles-u77020.html
Tue Aug 12, 2008 9:59 am
Well a friend and I first looked at the bad injector closer. It looked like it was shooting gas fine, but it was leaking hardcore. So we swapped the injector again with the newer one I had purchased. Tested, and worked like a charm again. I don't know what originally caused the injector to spew gas at first, but its not doing it anymore.
We then did a compression test. 160-170 across the board, surprisingly. My friend suggested that I just had a ton of crap sitting in the exhaust, and it just needed to burn out of it. The car runs, idles, and accelerates just fine, but still shoots a little bit of smoke at higher RPMS, usually when shifting gears. I knew I burned oil, but it still shoots out a little more smoke than usual. Compression test tells me that the rings and valves are fine. Why else would I burn that much oil?
