JNM240 »
https://forums.nicoclub.com/jnm240-u395.html
Sun Oct 20, 2002 3:26 pm
Aside from having a crankshaft custom made for you, i seriously doubt that you will be able to increase the stroke. The bore, on the other hand, can change. Mine is going from the stock 89mm up to 90mm, im leaving the head combustion chamber alone (aside from cleaning it up) and doing a mild port/polish, and going with 10.5:1 pistons. Basically, its a total engine rebuild, which is exactly what im doing. Any good machine shop can bore your block, but im not sure what the maximum bore you can get is. Going from 89mm to 90mm bore will change my displacement from 2389cc to 2443cc (techincally still a 2.4L hehe).
What you should look into before even thinking of this is starter stuff like intake, exhaust, header, cams, ECU, ect ect to get more NA. Im rebuilding because i have a blown front main and rear main seal (never good). So while i have it all in pieces, why not make it better?
