where is the MAF SENSOR ON A 1994 J30 AND HOW DO I CLEAN IT?
klonfes2000
Car: 1994 infiniti j30
I RECENTLY REPLACED 2 COILS , 6 SPARK PLUGS AND AN INJECTOR ON MY CAR ,BUT STILL HESITATE WHEN PUSHING GAS ,SOME TIMES WHEN I STOP , THE CAR WANNA TAKE OFF BY IT SELF AND WHEN I OPEN THE FUEL CAP,LOTS OF AIR COME OUT SO I FIGURED THAT THE MAF IS BAD .ANY HELP PLZ,
J30inthe sun
Car: 1997 J30
http://www.nicoclub.com/FSM/J30/1994_J30/ec.pdf
Page 6 shows the location. You need a spray can of Mass Air Flow sensor cleaner. CRC makes one.
http://www.crcindustries.com/h...05110
Welcome to NICO!
Infinitiguy19
Car: 1993 Infiniti Q45 188580 Miles
1994 Infiniti Q45a 240000 Miles
How do you know how to replace all the above and not know how to find the MAF sensor?
http://Nicoclub.com/FSM/J30
Welcome to NICO.
klonfes2000
thank u (j30inthe sun) for ur help and for welcoming me at nicoclub.
plz if u have any instructions about how to clean the sensor let me know.
klonfes2000
thanx to nicoclub i was able to do what i did.
J30inthe sun
Car: 1997 J30
If you get the CRC brand the detailed instructions are on the can. You have to remove the MAF 1st.
klonfes2000
is there a trick 2 remove it?
yodawill2000
Car: 94 Infiniti J30
I just took the intake tube off and pulled up on the maf till I could get a good shot at the element inside.Its a thin wire mounted vertically that has a thermistor in the center.I sprayed through the screen that's there.Worked well.
GerryO
Car: 1993 J30t
Pearl White
Black Interior
klonfes2000 wrote:I RECENTLY REPLACED 2 COILS , 6 SPARK PLUGS AND AN INJECTOR ON MY CAR ,1) BUT STILL HESITATE WHEN PUSHING GAS ,2) SOME TIMES WHEN I STOP , THE CAR WANNA TAKE OFF BY IT SELF 3) AND WHEN I OPEN THE FUEL CAP,LOTS OF AIR COME OUT SO I FIGURED THAT THE MAF IS BAD .ANY HELP PLZ,
1) could be any number of things and cleaning the MAF shouldn't hurt2) sounds like the idle speed is staying high at times?3) that's normal/good, as the fuel system is pressurized
