If you have Adobe Acrobat (the priced product, not the free reader) you can build an index across multiple files.CanuckQx4 wrote:Is there a way to search Adobe PDF's entirely for a certain word?? I have to search each category (engine mechanical, cooling and heating etc) categories individually and I never thought the sensor would be in the electrical section I guess
wow that sucker is gonna be HARD to find and get at ehnanit wrote:Engine Cooling System, page LC-19, number 7 on schema.
Then start warmed engine and monitor resistance. Manual says that you should see something like 0.23-0.3 kOhms.CanuckQx4 wrote:Well I did this test today, probed for voltage at the end of the female #3 pin connector, the test says I should have 5V at that pin, I have 4.8 so I think it should be fine
The problem stemmed from my temperature gauge reading incorrect, as soon as I turn the ignition on, it goes to half up the gauge, even if the car is dead cold and frozen, then when I drive, it pegs out to HOT. But I dont think its actually overheating or even getting up to operating temp.
