alonsorules8 »
https://forums.nicoclub.com/alonsorules8-u68529.html
Sat Aug 29, 2009 4:55 am
Removal and Installation of BCM EKS00IA6REMOVAL1. Remove the glove box. Refer to IP-21, "GLOVE BOX ASSEMBLY" .2. Remove the BCM screws, disconnect the connectors andremove the BCM.INSTALLATIONInstallation is in the reverse order of removal.NOTE: When replacing BCM, it must be configured. Refer to BCS-19, "Configuration" . When replacing BCM, perform initialization of NATS system and registration of all NATS ignition key IDs.Refer to BL-212, "NATS (Nissan Anti-Theft System)" . When replacing BCM, if new BCM does not come with keyfobs attached, all existing keyfobs must be reregistered.WKIA567
