Supercourse »
https://forums.nicoclub.com/supercourse-u87706.html
Mon Jan 28, 2008 7:07 pm
There is not necessarily a standard exit point for the block heater plug once it has been unzipped from its factory position. On the 2007 Sentra, the cord is long enough to go from its "hiding place" on the left side of the engine bay all the way over to a convenient (to me) exit through the main grille way over near the right headlamp. The plug looks as though it would not fit through grille holes, but if you pass the plug cover through first, and then manouver the plug itself through patiently, it works out fine. (The plug and its cover are a close color match to the grille, and they can sit snugly in the grille as to be hardly noticeable.)Of course, the Versa has a totally different grille, but I would expect something similar could be done. I think it best to have the plug up fairly high, for various reasons (keeping it clean, ease of plugging and unplugging, etc.). Make sure the cord is kept away from hot parts, and moving parts, and suitably retained with zip ties.Incidentally, Nissan has always been better than most other manufacturers in providing block heaters as standard. Some people erroneously insist they don't have a block heater because they don't live in a cold climate, when in fact all they need to do is locate the coiled-up connecting cord, or for some models/markets, buy the required cord.Use of a block heater is not limited to -40 degree starting, it has a role in reducing engine wear and quick heat availabilty for demisting, or safety.
